"Wrong ip/password of system down" error
Sun Oct 31, 2021 11:01 pm
DPattee offline
Added two new switches to my stack - USW Enterprise 8 PoEs.
I can successfully ssh in to them with the same user/password as all my other switches. But these two both just repeat the login failure message over and over:
   uniFiAP Error                   getMessages: (1 - test connect)  error for SWdict, ip#: nn.mm.xx.yy, prompt:'not defined'; wrong ip/ password or system down or ssh timed out or ..?
Oct 31, 2021 at 9:52:04 PM
   uniFiAP Error                   getMessages: (1 - test connect)  error for SWdict, ip#: nn.mm.xx.zz, prompt:'not defined'; wrong ip/ password or system down or ssh timed out or ..?
I turned on debugging level 20, and clicked the 'show debug...' buttons for those two switches but don't have access to the logs at the minute (I'm remote)
The ssh intro page for these devices looks like:
BusyBox v1.25.1 () built-in shell (ash)
  ___ ___      .__________.__
 |   |   |____ |__\_  ____/__|
 |   |   /    \|  ||  __) |  |   (c) 2010-2021
 |   |  |   |  \  ||  \   |  |   Ubiquiti Networks, Inc.
 |______|___|  /__||__/   |__|
            |_/                  https://www.ui.com/
      Welcome to UniFi USW-Enterprise-8-PoE!
Office-US.5.64.8# help
UniFi Command Line Interface - Ubiquiti Networks
   info                      display device information
   set-default               restore to factory default
   set-inform <inform_url>   attempt inform URL (e.g. set-inform http://192.168.0.8:8080/inform)
   upgrade <firmware_url>    upgrade firmware (e.g. upgrade http://192.168.0.8/unifi_fw.bin)
   fwupdate --url <firmware_url|firmware_name> [--dl-only] [--md5sum <sum_of_fw>]
            [--keep-firmware] [--keep-running] [--reboot-sys]
                                   new firmware update command
   reboot                    reboot the device
Office-US.5.64.8#
Which is essentially the same as the splash screen on some of the older gen devices that work with the plugin. The only thing I see that is immediately different is the new one is missing hte datetime from between teh parenthesis on the BusyBox line, and it is a slightly newer version (1.25 vs 1.23.2)
Mon Nov 01, 2021 12:22 am
Re: "Wrong ip/password of system down" error
Sorry can’t do any thing until my boxes arrive in Vienna. That might take another 6 + weeks.
Karl.
