New error Line 8019
Tue May 04, 2021 4:48 am
Turribeach offline
Re: New error Line 8019
kw123 wrote:
you are right, i did not publish the fixed version..
I am getting the same error on 7.39.365:
   Upgrading plugin uniFiAP to newer version 7.39.365 (previous version moved to trash)
   Loading plugin "uniFiAP 7.39.365"
   Starting plugin "uniFiAP 7.39.365" (pid 89555)
   Error                           Unable to connect to IndigoDomo.com.
   uniFiAP                         initializing  ...
   uniFiAP                         path To files:          =================
   uniFiAP                         indigo                  /Library/Application Support/Perceptive Automation/
   uniFiAP                         installFolder           /Library/Application Support/Perceptive Automation/Indigo 7.5/
   uniFiAP                         plugin.py               /Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
   uniFiAP                         Plugin params           /Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/com.karlwachs.uniFiAP/
   uniFiAP                         logger  enabled for     INFO           ==> TEST ONLY
   uniFiAP Warning                 logger  enabled for     WARNING        ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     ERROR          ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     CRITICAL       ==> TEST ONLY
   uniFiAP                         check                   /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log  <<<<    for detailed logging
   uniFiAP                         Plugin short Name       UniFi
   uniFiAP                         my PID                  89555
   uniFiAP                         set params for indigo V 7.5
   Started plugin "uniFiAP 7.39.365"
   uniFiAP                         testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   uniFiAP                         myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.5/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log;  debugLevel= []
   uniFiAP                         MAP2Vendor initializing
   uniFiAP                         MAP2Vendor initializing  finished, read from mac2Vendor.json file
   uniFiAP Error                   error in  Line# 5999 ;  error='key name Unifi_Camera_with_Event not found in database'
   uniFiAP                          start   runConcurrentThread, initializing loop settings and threads ..
   uniFiAP                         initialized ... looping
Tue May 04, 2021 5:03 pm
please try v ...368
should fix the camera error.
and have fixed some restart issues with listeners when the unifi device reboots.
Fri May 07, 2021 10:49 pm
MarcoGT offline
With v365 error disappeared
Sat May 08, 2021 6:18 pm
Turribeach offline
Hi, I have upgraded to v368 and I can confirm the camera error it's gone now, thanks Karl. Also my downgraded all APs to the previous firmware version (4.3.24) are happy bunnies and I am not seeing recurring "No JSON object could be decoded" errors. So looks to me lile Ubiquiti introduced a bug with the 4.3.28 firmware since the 4.3.24 is a lot more stable.
Sat May 08, 2021 7:39 pm
I had only problems once a month or so.
Now running on 4.3.28 and no error message for a week.
Karl.
