uniFiAP Error
Posted: Sun Mar 21, 2021 11:12 am
I am getting the following recurring error.. Not sure why
Thanks for you great plugin work
uniFiAP Error in Line 7763 has error=No JSON object could be decoded
uniFiAP checkAndPrepDict JSON len:59; mca-dump | sed -e 's/^ *//' xxxThisIsTheEndTokenxxx1...... ed -e 's/^ *//' xxxThisIsTheEndTokenxxx1
uniFiAP .... in receiving DICTs for APdict-192.168.1.9; for details check unifi logfile at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
Log File:
21 13:09:12 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.9: timeSinceLastRestart 41 > forcedRestart:999999999 [sec] ; without message:132.1[sec], limitforRestart:130.0[sec], restartCount:0, len(msg):56; lastMSG:mca-dump | sed -e 's/^ *//' xxxThisIsTheEndTokenxxx1<<
2021-03-21 13:09:17.859 ERROR Plugin.checkAndPrepDict in Line 7763 has error=No JSON object could be decoded
21 13:09:17 checkAndPrepDict JSON len:59; mca-dump | sed -e 's/^ *//' xxxThisIsTheEndTokenxxx2...
... ed -e 's/^ *//' xxxThisIsTheEndTokenxxx2
21 13:09:17 .... in receiving DICTs for APdict-192.168.1.8; for details check unifi logfile at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
21 13:09:17 .... ping test: ok
21 13:09:17 .... ssh test: ok
21 13:09:17 .... uid/passwd:>(u'mypassword', u'xcvbnmasdf')<
21 13:09:17 getMessages: consume data needed > 10 secc; APdict-192.168.1.8-0; DT:10.8[sec] len(MSG):59 lastMSG:mca-dump | sed -e 's/^ *//'
21 13:09:26 getMessages: relaunching dictLoop.exp / APdict / 192.168.1.8: timeSinceLastRestart 106 > forcedRestart:999999999 [sec] ; without message:131.9[sec], limitforRestart:130.0[sec], restartCount:0, len(msg):56; lastMSG:mca-dump | sed -e 's/^ *//' xxxThisIsTheEndTokenxxx2<<
2021-03-21 13:09:56.903 ERROR Plugin.checkAndPrepDict in Line 7763 has error=No JSON object could be decoded
21 13:09:56 checkAndPrepDict JSON len:59; mca-dump | sed -e 's/^ *//' xxxThisIsTheEndTokenxxx1...
21 13:09:56 .... in receiving DICTs for APdict-192.168.1.9; for details check unifi logfile at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
21 13:09:56 .... ping test: ok
21 13:09:56 .... ssh test: ok
21 13:09:56 .... uid/passwd:>(u'mypassword', u'xcvbnmasdf')<
21 13:09:56 getMessages: consume data needed > 10 secc; APdict-192.168.1.9-1; DT:10.7[sec] len(MSG):59 lastMSG:mca-dump | sed -e 's/^ *//'
Log File:
