in Line 7741 has error=No JSON object could be decoded
Sun Mar 14, 2021 5:10 pm
moved the discussion to a new thread
thanks a lot
I have installed the new version and now the problem with the password disappeared.
But now I have the logs full of this entry
14. Mar 2021 at 13:39:28
   uniFiAP Error                   in Line 7741 has error=No JSON object could be decoded
   uniFiAP                         checkAndPrepDict JSON len:126; mca-dump | sed -e 's/^ *//' -bash: mca-dump: command not foundroot@UniFi-CloudKey-Gen2-Plus:~# xxxTh...
...  ey-Gen2-Plus:~# xxxThisIsTheEndTokenxxx1
   uniFiAP                         .... in receiving DICTs for GWdict-192.168.2.16;  for details check unifi logfile  at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
Answering to your question regarding mca-dump; I get:
But, .16 is my Controller, not the USG/Gateway.
Marco
the newer unifi software versions of the controller does not support the
mca-dump
command. all communication is done through the http get commands
So i guess your ip numbers in config are not setup properly. it thinks that .16 is the gateway
what is your setup? do you have a UDM?
please post hardware and software
Sun Mar 14, 2021 11:39 pm
MarcoGT offline
Re: in Line 7741 has error=No JSON object could be decoded
No, .16 is controller (Cloudkey-Gen2-Plus)
NO UDM, but USG 3P (IP=.253)
Mon Mar 15, 2021 7:24 am
Then please check your config- the Ip number must be wrong. It is set to be the gateway.
Also wich UniFi software is running on the cloud key ?
Mon Mar 15, 2021 10:56 pm
Also could you send me menu/ print parameters.
It has userid and passwords in it
PleAse send to karlwachs at me com
Wed Mar 17, 2021 6:40 am
MarcoGT offline
There was a typo in the IP address, sorry
Wed Mar 17, 2021 6:50 am
.. so it works now?
