1. could you run in a terminal
curl --insecure -I -s --w "%{http_code}" 'https://ip-of-controller:8443'
and
curl --insecure -I -s -w "%{http_code}" 'https://ip-of-controller:443'
naturally replace ip-of-controller with the ip # of your controller
.. and post the result?
you should get something like:
- Code: Select all
HTTP/1.1 200 OK <------- or 302
Vary: Origin
X-DNS-Prefetch-Control: off
X-Frame-Options: SAMEORIGIN
Strict-Transport-Security: max-age=15552000; includeSubDomains
X-Download-Options: noopen
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Accept-Ranges: bytes
X-CSRF-Token: e8cb1e5d-1a49-4a18-88cc-39c4e3c6c8fa
Content-Type: text/html; charset=utf-8
Content-Length: 357
X-Response-Time: 4ms
Set-Cookie: TOKEN=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjc3JmVG9rZW4iOiJlOGNiMWU1ZC0xYTQ5LTRhMTgtODhjYy0zOWM0ZTNjNmM4ZmEiLCJpYXQiOjE2MTEyNjk0ODAsImV4cCI6MTYxMTI3MzA4MH0.s9TVFsOUSN9kR1d8ucPrJBTdeLLN1ipQwNYnNfB6XfQ; path=/; secure; httponly
Date: Thu, 21 Jan 2021 22:51:20 GMT
Connection: keep-alive
with the right port #
and uniFiAP Error in Line 6023 has error=global name 'mac' is not defined
- Screen Shot 2021-01-21 at 16.48.34.png (7.51 KiB) Viewed 3059 times
is a minor bug, has no real impact beside log entries (does not set the expiration timer default settings (you have selected in config to set exp timer to max of device settings and ap/gw/sw repeat read time)
fixed later today
