New error: No JSON object could be decoded
Sat Nov 28, 2020 11:05 am
MartinG offline
This has started appearing in my event log. I haven't (to my knowledge!) changed anything recently.
uniFiAP Error in Line 6746 has error=No JSON object could be decoded,receiving DICTs for 192.168.1.5; check unifi logfile; if this happens to often increase DICT timeout
uniFiAP Error ... APdict 192.168.1.5 error in the JSON data, #of bytes:95
uniFiAP Error ... JSON=Study-BZ.v4.0.80# mca-dump | sed -e 's/^ *//' Study-BZ.v4.0.80# xxxThisIsTheEndTokenxxx1...
... udy-BZ.v4.0.80# xxxThisIsTheEndTokenxxx1
uniFiAP Error APdict 192.168.1.5 forcing restart of msg after due to error count in json
Sat Nov 28, 2020 3:54 pm
Re: New error: No JSON object could be decoded
How often does it happen?
It is an indication the that link to the UniFi device is not working properly. Eg. It only gets half the json.
If it happens sporadically ( > 15 minutes) it’s not a problem. If it happens every 2 minutes we need to look into it
Thu Dec 03, 2020 2:32 am
MartinG offline
Hi Karl,
Apologies for the slow response - head down on work stuff the last few days.
It's a bit random, but frequent. Here are times of the last few instances. I can't see any regularity to it, or relate it to what's happening elsewhere, either in Indigo, or devices moving physically around the house.
08:13:35
08:17:04
08:17:57
08:18:26
08:19:35
08:23:06
08:23:56
08:24:41
08:25:06
08:29:53
This last one was a variant I haven't noticed before:
3 Dec 2020 at 08:29:53
   uniFiAP Error                   ... APdict  192.168.1.5 error in the JSON data, #of bytes:156
   uniFiAP Error                   ... JSON=echo ThisIsTheAliveTestFromUnifiToPlugin >> /var/log/messagesStudy-BZ.v4.0.80# mca-dump | sed -e 's/...
...  udy-BZ.v4.0.80# xxxThisIsTheEndTokenxxx2
Thu Dec 03, 2020 8:55 am
it seems that sometimes it works
08:13:35
it receives 1/minute .. this is 3.5 minutes, no error message
08:17:04
and then it does not:
08:17:04
08:17:57
08:18:26
08:19:35
could you switch on debug for 5 minutes
Screen Shot 2020-12-03 at 08.52.50.png (12.2 KiB) Viewed 1663 times
then post
/Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log
for those minutes,
or better send me in email to karlwachs at me com
Fri Dec 04, 2020 3:48 am
MartinG offline
Email sent - thanks!
Tue Dec 08, 2020 2:08 pm
MartinG offline
After a bit of emailing back and forth between Karl and me, something magical happened....
TL;DR: keep your Unifi controller & AP firmware up to date.
Hi Karl,
This isn't very helpful for your debugging, but I dug into your comment about old software on the AP.
My Unifi controller wasn't reporting any firmware upgrades available for the APs, but I did notice that the controller software was ~18months old. So I updated that.
Then firmware upgrades for the APs were notified, so I updated those.
My network definitions didn't survive the upgrades properly, so I recreated the networks.
And hey presto... no more errors from the plugin, presence is reported properly, and everything is working fine once again!
So the good news is my problem has been solved. The bad news is that we may never find out what the problem actually was.
Thanks for your help!
