USG4 gateway stability issue
Tue Oct 27, 2020 9:20 pm
my setup:
1GB ATT -- ATT modem -- unifi GW USG-pro4
When I set the ATT modem to "bridge" mode = send all traffic to the USG I get ~ 3-5 times a day network interruptions = no internet for about 30-60 secs
When I set the ATT modem to regular router w double NATting (ATT+ USG) everything works fine
I can run ping to google.com and the ATT modem and both stop at the same time = connection between USG and ATT modem is not working , it is the same time when regular internet access stops too.
I thought that setting ATT modem to bridge mode would be the easier, better solution ..
any ideas / suggestions?
Wed Oct 28, 2020 3:50 am
Re: USG4 gateway stability issue
Any alerts or events logged in the UniFi controller?
Wed Oct 28, 2020 8:46 am
Korey offline
Force the WAN port of the USG to 1000FDX, it may be an auto negotiation issue, I know this can be a fix for UDMP, have not heard of it for the USG4. Might be worth a shot.
I also had to use static DNS servers as oppose to the ones provided via DHCP form my ISP. (assuming your ISP is serving IP va DHCP)
Korey
Wed Oct 28, 2020 2:36 pm
no
that should affect both setups, no change in hardware
interesting, could that affect a simple ping to the ATT modem? ping to the modem does not need dns and that ping stops too.
