ascii codec errors with device names
Mon Oct 05, 2020 8:06 am
juntta offline
Hi!
I dont know if its recommended to edit device names or not, anyway it seems to be working alright. But I ran into one issue today when I renamed one of my Apple Tv's as "AppleTV Yläkerta" and following issue raised into log:
2020-10-05 16:33:17.691   ERROR          Plugin.periodCheck               in Line 5622 has error='ascii' codec can't decode byte 0xc3 in position 16: ordinal not in range(128)
looking at device:  UniFi_AppleTV_Yläkerta
Mon Oct 05, 2020 9:19 am
Re: ascii codec errors with device names
checking
the error is in
text1= dev.name.encode("utf8").ljust(30) + u" status " + status.ljust(10) +"; set to UP, reset by ping "
and I thought that is the right way to do it..
Mon Oct 05, 2020 9:27 am
kw123 wrote:
checking
the error is in
That last string needs to be unicode as well, since. you're concatenating them. A better way to do it is:
text1 = u"{} status {};   set to UP,  reset by ping".format(dev.name.encode("utf8").ljust(30), status.ljust(10))
Mon Oct 05, 2020 12:26 pm
yes. i got it
need to add the u before the " AND drop the encode("utf8")
z =  u"{} status {};   bla bla  ".format(dev.name.ljust(30), status.ljust(10))
works fine
the conversion to python 3 will be "exciting"
Mon Oct 05, 2020 1:45 pm
You can also use formatting specifiers inside the brackets to do your padding and get rid of the .ljust() calls as well.
Mon Oct 05, 2020 1:49 pm
Or:
u"{0:30} status {1:10};   bla bla  ".format(dev.name, status)
which works in Python 2.x and 3.x.
Mon Oct 05, 2020 2:28 pm
DaveL17 wrote:
Or:
+1 - though, rumor has it that the u"" syntax will be removed at some point. But that's in the future...
Tue Oct 06, 2020 2:37 am
juntta offline
Version 7.33.285 fixed this issue! Now devices get updated even what characters their names got!
Thanks Karl
Tue Oct 06, 2020 9:49 am
thanks for the feedback. it is always nice to get a positive feedback when things work .
and thanks for your patience
