I picked up a couple of the new Unifi AP6 Lite AP's on the early access site, and the LEDs are quite bright, so I wanted to use the plugin to toggle them off at night / on in the morning.
The plugin will turn the LED's OFF as it should.
Getting this error trying to turn the LED's ON from the plugin:
- Code: Select all
uniFiAP Error Connection error: >>192.168.0.252<<
{"meta":{"rc":"error","msg":"api.err.NotFound"},"data":[]}
Controller version 5.14.15
- Code: Select all
Starting plugin "uniFiAP 7.31.262" (pid 44211)
uniFiAP initializing ...
uniFiAP path To files: =================
uniFiAP indigo /Library/Application Support/Perceptive Automation/
uniFiAP installFolder /Library/Application Support/Perceptive Automation/Indigo 7.4/
uniFiAP plugin.py /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
uniFiAP Plugin params /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/
uniFiAP Warning logger enabled for WARNING ==> TEST ONLY
uniFiAP Error logger enabled for ERROR ==> TEST ONLY
uniFiAP Critical Error logger enabled for CRITICAL ==> TEST ONLY
uniFiAP check /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log <<<< for detailed logging
uniFiAP Plugin short Name UniFi
uniFiAP my PID 44211
uniFiAP set params for indigo V 7.4
Started plugin "uniFiAP 7.31.262"
uniFiAP testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
uniFiAP myLogSet setting parameters -- logFileActive= indigo; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log; debugLevel= []
uniFiAP start runConcurrentThread, initializing loop settings and threads ..
uniFiAP initialized ... looping
Action Group test Unifi LED OFF
Action Group test Unifi LED ON
