Finally finding the time to troubleshoot what may well be a variety of problems with my Unifi plugin.
Under "UDM active" I see "This will automatically activate switch#12, AP#4 and Controller at the same IP number as the UDM"
Is switch#12 the switch built into the UDM?
Is AP#4 the AP built into the UDM?
Also if I have checked UDM active, I don't need GW active, correct? even though the UDM is my gateway? Just not a USG.
And I'm going to tack the problem on this post, just for organization.
I have double checked that I have the correct username and pwd for the UDM web login. But I still see this in the log constantly:
- Code: Select all
11:58:38 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "DC", "strict": true, "password": "the-correct-pwd"}' 'https://192.168.0.1:8443/api/login'
11:58:39 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie --data '{"_limit": 25, "_sort": "+time"}' -X GET 'https://192.168.0.1:8443/api/s/Dog Hill/stat/event'
2020-07-14 11:58:39.160 ERROR Plugin.executeCMDOnController UNIFI executeCMDOnController to 192.168.0.1 has error, no json object returned: >><<
I've also double checked that the UDM ssh login is correct. Version 7.3.247
