Setup errors
Tue May 26, 2020 4:53 pm
MartinG offline
Re: Setup errors
I found the problem. I noticed that the ip port number for the controller in my config is wrong. I had 8433, whereas it should have been 8443. It's right there in the screenshot in my prior post.
At first I thought I had just mistyped it, then I noticed that if I select controller type UDM or unifi controller, and then 'set parameters', the wrong port number (8433) is filled into the config.
If I manually enter 8443, the error messages magically disappear and all is well in the world.
Screenshot 2020-05-26 at 23.41.04.png (171.84 KiB) Viewed 788 times
Tue May 26, 2020 5:03 pm
Setup errors
Thanks for checking. Will fix that.
Glad it’s working now.
