new error
Fri Mar 27, 2020 8:18 pm
farberm offline
new error
Karl:
I upgraded the plugin recently and now notice the following error. Not sure why. I have not changed my username or pw or ip address of the USG
uniFiAP Error UNIFI executeCMDOnController error: (wrong UID/passwd, ip number?) ...>>{"meta":{"rc":"error","msg":"api.err.Invalid"},"data":[]}<<
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 49 0 0 100 49 0 34 0:00:01 0:00:01 --:--:-- 34
100 106 100 57 100 49 26 22 0:00:02 0:00:02 --:--:-- 48
Connection
Fri Mar 27, 2020 9:31 pm
Re: new error
could you open config and check if the userid /pass wd are correct.
You can also do menu "PRINT parameters to logfile" / "PRINT Config parameters to logfile "
the output will be in /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log
Fri Mar 27, 2020 9:55 pm
Re: new error
Also could you switch debug expect on
Email me the plugin.log file
It will contain userid and passwords!!
Sat Mar 28, 2020 9:00 am
farberm offline
Re: new error
Thanks for your help.
I updated the USG controller software which which now recognized capital letters and lowercase differently. I adjusted my login name which had a capital instead of a lower case letter in it
They only error now is the following which is standard I think.
Correct?
uniFiAP Error logger enabled for ERROR ==> TEST ONLY
uniFiAP Critical Error logger enabled for CRITICAL ==> TEST ONLY
Sat Mar 28, 2020 9:12 am
Re: new error
Yes as it states: It’s a test.
Should show you what kind of logging is enabled.
Thu Apr 02, 2020 10:01 am
Different Computers offline
Re: new error
Same error?
uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"a4:f1:e8:12:f1:1a","msg":"api.err.UnknownStation"},"data":[]}<<
100   137  100    90  100    47    707    369 --:--:-- --:--:-- --:--:--   708
Not regular, and the plugin appears to be working correctly, with no recent changes to my setup.
Thu Apr 02, 2020 10:57 am
Re: new error
how often does it happen? Anything < 3 minutes could be a problem , if it happens infrequently , the box might be busy and does not answer properly, and it is fixed in the next cycle
Fri May 22, 2020 6:15 pm
DPattee offline
Re: new error
I started getting the user/pass error too immediately after upgrading the plugin. No changes to the user/pass on my controller in a long time, and the Indigo plugin UI shows the correct info still.
   uniFiAP Error                   UNIFI executeCMDOnController error: (wrong UID/passwd, ip number?10.0.4.2) ...>>{"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}<<
100   132  100    63  100    69    465    509 --:--:-- --:--:-- --:--:--   511
Plugin v: 7.30.238
Controller type is a Cloud Key Plus v2
Fri May 22, 2020 10:10 pm
Re: new error
could you switch on debug (7) and (8)
connection and expect
then restart the plugin, in plugin.log check the "expect" statements if the proper userid / password are used.
you are looking for a line w
... curl --insecure -c /tmp/unifiCookie -H \"Content-Type: application/json\" --data {"username":youruserid,"password":yourpasswd,"strict":self.useStrictToLogin}) ...
and
...curl+" --insecure -b /tmp/unifiCookie " ... + " 'https://" ...
Sat May 23, 2020 7:51 pm
DPattee offline
Re: new error
Okay, so here's some more information...
In the plugin settings, in the 'user IDs' section I have:
1. http fopr controller: <name1>, <password1>
2. ssh: <name2>, <password2>
And those match teh accounts that I've set in the UniFi dashbaord:
1. <name1><password1> is a custom Admins : Network Administrator, given the Administrator role
2. <name2><password2> is the Network Settings : Device Authenticaion : SSH Authentication : SSH Username & password
What I see in the logs is:
18:47:40 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "<name1>", "strict": false, "password": "<password1>"}' 'https://10.0.4.2:8443/api/s/'
2020-05-23 18:47:40.740   ERROR          Plugin.executeCMDOnController    UNIFI executeCMDOnController error: (wrong UID/passwd, ip number?10.0.4.2) ...>>{"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}<<
Happening either every few seconds or minutes depending on... maybe when I restart the plugin it does it a bunch in a row then settles in to the minute or so timing.
Sat May 23, 2020 8:34 pm
Re: new error
could you open a terminal and try:
/usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "<name1>", "strict": false, "password": "<password1>"}' 'https://10.0.4.2:8443/api/login/'
put in userid and password
your config should look like:
Screen Shot 2020-05-23 at 21.31.33.png (34.96 KiB) Viewed 2111 times
Sun May 24, 2020 10:49 am
DPattee offline
Re: new error
  /usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "<user1>", "strict": false, "password": "<pass1>"}' 'https://10.0.4.2:8443/api/login/'
And that screenshot doesn't match what I see in the config... Specifically the http: Api Login Page: is set to /api/s. I'll edit that and see what happens.
Screen Shot 2020-05-24 at 9.47.49 AM.png (84.28 KiB) Viewed 2080 times
Sun May 24, 2020 10:54 am
Re: new error
1. site ID should be default --Only if you have done MAJOR configs w several sites this parameter could be something else than default
2. the lines under login and web site are the known options to be used.
==>> YOU NEED TO PICK THE RIGHT ONE!! the option fields are setup as a text field (read only) so that you can copy the text
Sun May 24, 2020 1:35 pm
DPattee offline
Re: new error
Yes, my site id is correct
Sure. I've updated it and that seems to have solved the problem. My point is that I used to have a working install, I updated, and it stopped working. Something caused that field to become corrupt/wrong/ changed/etc, because I certainly didn't type "s" in there :) I didn't even look at that part of the settings as part of troubleshooting, because I was paying attention to the username/password as the problem. Perhaps an error message could be created that identifies when a parameter is set to something unexpected / unrecommended.
Sun May 24, 2020 2:27 pm
Re: new error
I understand your frustration, I am not perfect
as for the options: I have made it a free text field to enable the user to put in anything they need
A menu option would limit it to fixed options.
It looks as if UNIFI is changing web pages and other things frequently without notice.
That is why I thought a text field is the proper choice. Limiting the choices to the known options makes it less flexible. Thats why I added the option fields to list the know variations.
Users browsing this forum: No registered users and 19 guests
