JSON error from controller
Posted: Thu Feb 13, 2020 10:09 am
Hi, I have the uniFi controller running on the same mac as indigo and tell the plugin to connect to the controller. I keep seeing these error messages.
Is there something special that needs to be configured on the controller side I am missing?
Starting plugin "uniFiAP 7.27.169" (pid 77825)
uniFiAP initializing ...
uniFiAP path To files: =================
uniFiAP indigo /Library/Application Support/Perceptive Automation/
uniFiAP installFolder /Library/Application Support/Perceptive Automation/Indigo 7.4/
uniFiAP plugin.py /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
uniFiAP Plugin params /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/
uniFiAP Warning logger enabled for WARNING ==> TEST ONLY
uniFiAP Error logger enabled for ERROR ==> TEST ONLY
uniFiAP Critical Error logger enabled for CRITICAL ==> TEST ONLY
uniFiAP check /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log <<<< for detailed logging
uniFiAP Plugin short Name UniFi
uniFiAP my PID 77825
uniFiAP set params for indigo V 7.4
Started plugin "uniFiAP 7.27.169"
uniFiAP testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
uniFiAP myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log; debugLevel= []
uniFiAP Error UNIFI executeCMDOnController has error, no json object returned: ('', ' % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\n')
uniFiAP start runConcurrentThread, initializing loop settings and threads ..
uniFiAP Error UNIFI executeCMDOnController has error, no json object returned: ('', ' % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0\r100 30 0 0 100 30 0 2008 --:--:-- --:--:-- --:--:-- 2142\n')
uniFiAP initialized ... looping
