Feature Requests -- UDM Pro Support and backup file archival
Sat Feb 15, 2020 10:46 pm
Ramias offline
Re: Feature Requests -- UDM Pro Support and backup file arch
I did some tinkering on Karl's code to get this working for the Controller piece of my UDM Pro. But failing on the curl login to the controller (so... not getting very far at all).
This is what I'm entering:
/usr/bin/curl --insecure -c /tmp/fooCookie  --data '{"username": "MyUser", "password": "MyPassword"}' 'https://192.168.0.1:443/proxy/network/api/login'
Getting back
{"meta":{"rc":"error","msg":"api.err.Invalid"},"data":[]}%
Any idea what I'm doing wrong?
Sun Feb 16, 2020 10:09 am
kw123 online
this one works for me.
/usr/bin/curl --insecure -c /tmp/fooCookie  --data '{"username": "xx", "password": "xx"}' 'https://192.168.x.x:8443/api/login'
you have >> /proxy/network/<<
added..
and yours is 443 not 8443, but I guess that is by design.
Sun Feb 16, 2020 11:30 am
Ramias offline
/usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "xx", "strict": "True", "password": "xx"}' 'https://192.168.0.1:443/api/auth/login'
Ok this works and issues a cookie (though I'm not certain if this is the right login URL; was told this was for the websocket connection and that /proxy/network/api/login should work for the controller login; but I can't get that to work.
But this returns "Not Found":
/usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.0.1:443/proxy/network/api/s/default/stat/alluser'
Sun Feb 16, 2020 12:22 pm
kw123 online
could you try to drop
proxy/network/
from the address
Sun Feb 16, 2020 1:14 pm
Ramias offline
/proxy/network is needed for the UDM Pro.
For example, if I go here: https://192.168.0.1:443/proxy/network/a ... at/alluser in a browser tab from a browser I'm already logged into the UDMP with, I get several pages of json.
If I drop the /proxy/network it just takes me back to the main UDMP page.
If I try this with curl: https://192.168.0.1:443/api/login it just gives this:
<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width,initial-scale=1"><link href="/2.css" rel="stylesheet"></head>
<body>
<div id="root"></div>
<script type="text/javascript" src="/vendor.270c6910.chunk.js"></script><script type="text/javascript" src="/main.0a9cc80e.js"></script></body>
</html>
Sun Feb 16, 2020 1:45 pm
Ramias offline
This is in php but looks like line 161 shows for the UDM Pro that /api/auth/login is the login path.
https://github.com/Art-of-WiFi/UniFi-AP ... Client.php
Line 169 shows them also sending the application-type header which I also had to do:
curl_setopt($ch, CURLOPT_HTTPHEADER, ['content-type: application/json; charset=utf-8']);
And then their line 3997 shows /proxy/network added to the base url for the various api calls.
Now, what is interesting for me:
/usr/bin/curl --insecure -b /tmp/unifiCookie -X GET 'https://192.168.0.1:443/proxy/network/api/s/default/stat/alluser'
returns a ton of JSON. If I drop the -b and cookie path, it fails with LoginRequired.
But this: (the code from your exiting plugin, modified for the new baseURL) fails with Not Found:
Sun Feb 16, 2020 3:41 pm
kw123 online
returns a ton of JSON. If I drop the -b and cookie path, it fails with LoginRequired.<<
could you send me the json output?
this might has some config info in there, so may be do not post it ==> karlwachs me com
ps
not having one makes it really difficult to test.
Normally i need 20-30 tries then it works. Over the forum that would take weeks, doing everything at home ~ 1 day.
And they are not returnable so just $400 for trying looks expensive. And it does not have enough ports for me
Sun Feb 16, 2020 4:30 pm
Ramias offline
The /alluser JSON output is just a bunch of elements for each of my devices. I suspect the same as a "regular" controller.
Is there a better API URL. you'd like me to call that may have more info? Or dump something via SSH?
There will of course be some debugging because the UDM itself (As a switch) has some new items (but those can be had via SSH).
For example, these lines make a repeat appearance:
   uniFiAP Error                   getMessages: forcing restart of listener for: dictLoop.exp   @ SWdict  after 192.168.0.1 sec without message180
   uniFiAP Error                   in Line 7250 has error=u'network_table'
   uniFiAP Warning                 getMessages: ListenProcess started for uType: SWdict;  ip: 192.168.0.1  pid:40168
   uniFiAP Error                   in Line 8248 has error=u'overheating'
But for the controller piece, I think once I get the correct syntax and path for the Curl we may be much closer.
Mon Feb 24, 2020 11:47 am
kw123 online
@Ramias
https://www.dropbox.com/s/scaceyhzayi4hlb/uniFiAP.indigoPlugin.zip?dl=1
try this version.
in config select UDM as controller type
set GW on and pick ip number
select switch 12 w the same ip number as for the gateway
Tue Feb 25, 2020 7:08 am
evansgo offline
I just tried it and am getting error connection errors for the dashboard
This is the URL for the dashboard now, note the 8443 has gone.
https://192.168.10.1/network/site/default/dashboard
This is for the controller settings page
https://192.168.10.1/settings/general
Tue Feb 25, 2020 4:35 pm
kw123 online
this seems to work for UDM - pro (80% of functions)
still some tuning and clean up left to do
Wed Feb 26, 2020 7:13 am
evansgo offline
Not sure what I'm doing wrong but this is what I see, using the build above, I'll keep trying..
    ogin (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10a6dbb90>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    uniFiAP Error in Line 3887 has error=HTTPSConnectionPool(host='192.168.10.1', port=8443): Max retries exceeded with url: /api/auth/login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x109e39ad0>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    uniFiAP Error in Line 3887 has error=HTTPSConnectionPool(host='192.168.10.1', port=8443): Max retries exceeded with url: /api/auth/login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10a6dbb10>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    uniFiAP Error in Line 3887 has error=HTTPSConnectionPool(host='192.168.10.1', port=8443): Max retries exceeded with url: /api/auth/login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10a70c750>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    uniFiAP Error in Line 3887 has error=HTTPSConnectionPool(host='192.168.10.1', port=8443): Max retries exceeded with url: /api/auth/login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10a6dbc50>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    uniFiAP start runConcurrentThread, initializing loop settings and threads ..
    uniFiAP Error in Line 3887 has error=HTTPSConnectionPool(host='192.168.10.1', port=8443): Max retries exceeded with url: /api/auth/login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x109e39fd0>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    uniFiAP Error in Line 3887 has error=HTTPSConnectionPool(host='192.168.10.1', port=8443): Max retries exceeded with url: /api/auth/login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10a6db4d0>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    uniFiAP initialized ... looping
    uniFiAP Error getMessages: (1) error connecting to ip#: 192.168.10.1 wrong ip/ password or system down or ssh timed out or ..?
    26 Feb 2020 at 17:10:28
    Z-Wave received "Qubino - Temperature" sensor update to -20.1 °C
    uniFiAP Error in Line 3887 has error=HTTPSConnectionPool(host='192.168.10.1', port=8443): Max retries exceeded with url: /api/auth/login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10a6db690>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    26 Feb 2020 at 17:10:58
    26 Feb 2020 at 17:11:13
    uniFiAP Error in Line 3887 has error=HTTPSConnectionPool(host='192.168.10.1', port=8443): Max retries exceeded with url: /api/auth/login (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10a6db150>: Failed to establish a new connection: [Errno 61] Connection refused',)) Connection
    26 Feb 2020 at 17:11:28
    26 Feb 2020 at 17:11:44
Wed Feb 26, 2020 8:08 am
kw123 online
could you email me karlwachs me com
menu / print config
screen copy of your config, ie parameters you used for UDM setup
you can xxx your ids and passwords
Thu Feb 27, 2020 5:40 am
evansgo offline
OK some progress :)
So I decided to take a gamble and install the UDM Pro firmware as I had read that even through it said pro only it would work. Well it does, you have to fully reset to factory defaults the UDM, but I am now on controller version 5.12.59 and FW 1.6.4.2306.
What this did for me was to give me a SSH switch in the Controller area (it may have been there before but I didn't notice it if it was) which was off. I have turned it on and thanks to @Ramias used the user name of root and added the same password as I had for the other devices SSH and now its much improved.....
I'm getting this reported a lot
27 Feb 2020 at 15:37:05
uniFiAP Error in Line 3909 has error=local variable 'ret' referenced before assignment Connection
uniFiAP Error error:>> <Response [401]> Reconnect
Still happy for you to log in if we can align timezones, but it feels a lot closer now :)
and I'll send you another log file
Thu Feb 27, 2020 7:05 am
evansgo wrote:
OK some progress :)
I’m amazed that worked.. but also quite impressed! How does the devices page look when you’re looking at the port settings for the switch, etc?
