Feature Requests -- UDM Pro Support and backup file archival
Wed Jul 08, 2020 7:31 pm
Ramias offline
Re: Feature Requests -- UDM Pro Support and backup file arch
This is what I get in the debug log:
21:29:08 sensorValues cmd ret data: spawn ssh root@192.168.0.1
Welcome to UbiOS
By logging in, accessing, or using the Ubiquiti product, you
acknowledge that you have read and understood the Ubiquiti
License Agreement and agree to be bound by its terms.
root@192.168.0.1's password:
  ___ ___      .__________.__
 |   |   |____ |__\_  ____/__|
 |   |   /    \|  ||  __) |  |   (c) 2010-2020
 |   |  |   |  \  ||  \   |  |   Ubiquiti Inc.
 |______|___|  /__||__/   |__|
            |_/                  http://www.ui.com
      Welcome to UniFi Dream Machine!
err:extra characters after close-quote
    while executing
"expect "$promptOnServer"{
    send sensors -u\n
send "exit\r"
sleep 0.1
expect eof
    (file "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/UDM-pro-sensors.exp" line 22)
21:29:08 temp values found:  1:, 2:, 3:
21:29:23 getMessages: launching listener for: GWtail  @ 192.168.0.1
Wed Jul 08, 2020 8:08 pm
Wed Jul 08, 2020 8:51 pm
Ramias offline
Now getting this:
22:49:10 sensorValues cmd ret data: spawn ssh root@192.168.0.1
Welcome to UbiOS
err:
22:49:10 temp values found:  1:, 2:, 3:
22:50:02 get sensorValues from UDMpro cmd: /usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/UDM-pro-sensors.exp'  'root'  '' 192.168.0.1 #
22:50:11 sensorValues cmd ret data: spawn ssh root@192.168.0.1
Welcome to UbiOS
err:
22:50:11 temp values found:  1:, 2:, 3:
Wed Jul 08, 2020 9:46 pm
on the indigo server open terminal and do:
then
/usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/UDM-pro-sensors.exp'  'root'  '' 192.168.0.1 \#
and post results
Thu Jul 09, 2020 7:00 am
Ramias offline
Looks like they both work fine.
First one:
 % /usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/UDM-pro-sensors.exp'  'root'  'MYPASSWORD' 192.168.0.1 #
Welcome to UbiOS
# sensors -u
adt7475-i2c-4-2e
Adapter: i2c-0-mux (chan_id 3)
in1:
  in1_input: 0.885
  in1_min: 0.000
  in1_max: 2.988
  in1_alarm: 0.000
+3.3V:
  in2_input: 3.261
  in2_min: 0.000
  in2_max: 4.388
  in2_alarm: 0.000
fan1:
  fan1_input: 2787.000
  fan1_min: 0.000
  fan1_alarm: 0.000
fan2:
  fan2_input: 4671.000
  fan2_min: 0.000
  fan2_alarm: 0.000
fan3:
  fan3_input: 0.000
  fan3_min: 0.000
  fan3_alarm: 0.000
fan4:
  fan4_input: 0.000
  fan4_min: 0.000
  fan4_alarm: 0.000
temp1:
  temp1_input: 38.750
  temp1_max: 191.000
  temp1_min: -63.000
  temp1_crit: 100.000
  temp1_crit_hyst: 96.000
  temp1_alarm: 0.000
  temp1_fault: 0.000
  temp1_offset: 0.000
Board Temp:
  temp2_input: 37.500
  temp2_max: 191.000
  temp2_min: -63.000
  temp2_crit: 100.000
  temp2_crit_hyst: 96.000
  temp2_alarm: 0.000
  temp2_offset: 0.000
temp3:
  temp3_input: 38.250
  temp3_max: 191.000
  temp3_min: -63.000
  temp3_crit: 100.000
  temp3_crit_hyst: 96.000
  temp3_alarm: 0.000
  temp3_fault: 0.000
  temp3_offset: 0.000
# exit
Connection to 192.168.0.1 closed.
second one:
% /usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/UDM-pro-sensors.exp'  'root'  'MYPASSWORD' 192.168.0.1 \#
Welcome to UbiOS
# sensors -u
adt7475-i2c-4-2e
in1:
  in1_input: 0.885
  in1_min: 0.000
  in1_max: 2.988
  in1_alarm: 0.000
+3.3V:
  in2_input: 3.261
  in2_min: 0.000
  in2_max: 4.388
  in2_alarm: 0.000
fan1:
  fan1_min: 0.000
  fan1_alarm: 0.000
fan2:
  fan2_input: 4675.000
  fan2_min: 0.000
  fan2_alarm: 0.000
fan3:
  fan3_input: 0.000
  fan3_min: 0.000
  fan3_alarm: 0.000
fan4:
  fan4_input: 0.000
  fan4_min: 0.000
  fan4_alarm: 0.000
temp1:
  temp1_input: 38.750
  temp1_max: 191.000
  temp1_min: -63.000
  temp1_crit: 100.000
  temp1_alarm: 0.000
  temp1_fault: 0.000
  temp1_offset: 0.000
Board Temp:
  temp2_input: 37.500
  temp2_max: 191.000
  temp2_min: -63.000
  temp2_crit: 100.000
  temp2_alarm: 0.000
  temp2_offset: 0.000
temp3:
  temp3_input: 38.250
  temp3_max: 191.000
  temp3_min: -63.000
  temp3_crit: 100.000
  temp3_alarm: 0.000
  temp3_fault: 0.000
  temp3_offset: 0.000
# exit
Thu Jul 09, 2020 11:43 am
try this one:
https://github.com/kw123/unifi/releases/tag/v7.30.252
i still don't understand "expect" well..
Thu Jul 09, 2020 12:52 pm
Ramias offline
It's getting closer. Temps are showing in the logs. But the temperature field of the UDMP Switch device is not updating. I deleted the UDMP and restarted the plugin; it recreated and still no temp value.
14:50:02 get sensorValues from UDMpro cmd: /usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/UDM-pro-sensors.exp'  'root'  'MYPASSWORD' 192.168.0.1 #
14:50:07 sensorValues cmd ret data: spawn ssh root@192.168.0.1
Welcome to UbiOS
# sensors -u
adt7475-i2c-4-2e
in1:
  in1_input: 0.888
  in1_min: 0.000
  in1_max: 2.988
  in1_alarm: 0.000
+3.3V:
  in2_input: 3.261
  in2_min: 0.000
  in2_max: 4.388
  in2_alarm: 0.000
fan1:
  fan1_input: 2783.000
  fan1_min: 0.000
  fan1_alarm: 0.000
fan2:
  fan2_min: 0.000
  fan2_alarm: 0.000
fan3:
  fan3_input: 0.000
  fan3_min: 0.000
  fan3_alarm: 0.000
fan4:
  fan4_input: 0.000
  fan4_min: 0.000
  fan4_alarm: 0.000
temp1:
  temp1_input: 37.500
  temp1_max: 191.000
  temp1_min: -63.000
  temp1_crit: 100.000
  temp1_alarm: 0.000
  temp1_fault: 0.000
  temp1_offset: 0.000
Board Temp:
  temp2_input: 36.250
  temp2_max: 191.000
  temp2_min: -63.000
  temp2_crit: 100.000
  temp2_alarm: 0.000
  temp2_offset: 0.000
temp3:
  temp3_input: 37.000
  temp3_max: 191.000
  temp3_min: -63.000
  temp3_crit: 100.000
  temp3_alarm: 0.000
  temp3_fault: 0.000
  temp3_offset: 0.000
# exit
err:
14:50:07 temp values found:  1:37.5, 2:36.3, 3:37.0
Thu Jul 09, 2020 2:08 pm
almost there, decoded the temperatures, ... last step is to fill the device states of the "gateway" device
do you have a unifi - gateway device?
this has debug for updating the dev-states..
https://github.com/kw123/unifi/releases/tag/v7.30.253
Thu Jul 09, 2020 6:21 pm
Ramias offline
I have debug logging turned but don't see where it is updating the device state. Should I have another log option enabled?
Thu Jul 09, 2020 6:22 pm
That indicates that you don’t have an Indigo Gateway device
Thu Jul 09, 2020 6:40 pm
Ramias offline
Oh yeah sorry I missed that. I just have the Unifi UDM Pro, three switches and 3 wireless APs. but no GW. The UDM Pro performs that function.
Thu Jul 09, 2020 6:44 pm
The plugin normally generates that device.
If you have a GW, UDM , or UDM-pro
So why did yours not do that?
Thu Jul 09, 2020 7:43 pm
Ramias offline
Ah. UDM Pro shows up as a switch with a blank temp value.
I have other devices that showed with different mac addresses and my public IP in the notes field, but no temperature field.
I deleted all of the Unifi System devices and restarted the plugin. Now those devices that previously had the public IP of my UDMPRO now do not display a public IP in the notes field. Nor do they even show a temperature field.
Could you write the temperature value to the UDM Pro Switch device?
Thu Jul 09, 2020 7:54 pm
The UDM pro should show up as 3 devices:
Switch
Ap
Gateway.
Thu Jul 09, 2020 8:14 pm
Ramias offline
No devices prefixed with GW. I have GW enabled in my plugin config.
Screen Shot 2020-07-09 at 10.10.32 PM.jpg (369.97 KiB) Viewed 2671 times
Screen Shot 2020-07-09 at 10.11.12 PM.png (108.96 KiB) Viewed 2671 times
