The config parameter for the web page login is wrong
Not api/s but the one with login
uniFiAP Error UNIFI executeCMDOnController login cmd:/usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "UserName", "strict": true, "password": "PassWord"}' 'https://10.0.1.1:8443/api/s/login'
gives error: {"meta":{"rc":"error","msg":"api.err.LoginRequired"},"data":[]}
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 126 100 63 100 63 1517 1517 --:--:-- --:--:-- --:--:-- 1536
uniFiAP Error getMessages: (1 - test connect) error for SWdict, ip#: 10.0.1.83 wrong ip/ password or system down or ssh timed out or ..?
uniFiAP Error testServerIf ssh connection to server failed, cmd: /usr/bin/expect '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/test.exp' 'UserName' 'PassWord' 10.0.1.84
uniFiAP Error getMessages: (1 - test connect) error for SWdict, ip#: 10.0.1.84 wrong ip/ password or system down or ssh timed out or ..?
uniFiAP Error getMessages: (1 - test connect) error for APtail, ip#: 10.0.1.95 wrong ip/ password or system down or ssh timed out or ..?
uniFiAP Error UNIFI executeCMDOnController login cmd:/usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "USERNAME", "strict": false, "password": "PASSWORD"}' 'https://10.0.1.1:8443/api/login'
gives error: {"meta":{"rc":"error","msg":"api.err.Ubic2faTokenRequired"},"data":[]}
100 134 100 70 100 64 68 62 0:00:01 0:00:01 --:--:-- 68
