Running Unifi Controller on Linux?
Sun Dec 01, 2019 8:19 am
Different Computers offline
Since there doesn't seem to be an easily installed controller software version for Catalina (wow do I hate Java) and because I'm also spinning up a linux Plex server, I thought I'd try running the controller software on the linux box.
Does the UNIFI plugin care what kind of OS the controller software runs on?
Sun Dec 01, 2019 10:02 am
Re: Running Unifi Controller on Linux?
Any Unix should work
As long as it supports
ssh
tail
Sun Dec 01, 2019 4:47 pm
agame offline
I have two instances of Unifi Controller running on Catalina with no problems at all, BTW.
Sun Dec 01, 2019 5:55 pm
As for putting it in Catalina, whew!
What docs I've found for it seem crazily complicated.
Mon Dec 02, 2019 7:41 am
Putting the unifi cobtroller on Catalina? Nope.. just install the java runtime engine then install the latest controller software... unless I’m missing something?
Mon Dec 02, 2019 8:21 am
This is the part that scared me off, but perhaps I searched for the wrong terms. Got a link to the Catalina JRE installer? Every link I followed involved a dozen steps.
Edit: Never mind. Guess I just had bad luck at first finding the right installer. Got the hated JRE running on a test machine now, and I'll install it on the Mac that needs it tonight.
Last edited by Different Computers on Mon Dec 02, 2019 9:21 am, edited 1 time in total.
Mon Dec 02, 2019 8:28 am
Ah I suppose Oracles instructions for it are over complicated (aren’t they always).. all you need to do is download it, right click and open to bypass gatekeeper then install as normal!
