New Error after updating plugin
Sat Nov 30, 2019 2:08 pm
dnomode offline
Hello Karl,
My system has been running for months without me doing anything. Well last week I decided to update all my plugins and now I'm getting the following errors from the Unifi plugin. Also my devices are no longer updating the variable list showing how many are away or home from the group.
   Enabling plugin "uniFiAP 7.26.168"
   Starting plugin "uniFiAP 7.26.168" (pid 81285)
   uniFiAP                         initializing    ...
   uniFiAP                         path To files:          =================
   uniFiAP                         indigo                  /Library/Application Support/Perceptive Automation/
   uniFiAP                         installFolder           /Library/Application Support/Perceptive Automation/Indigo 7.4/
   uniFiAP                         plugin.py               /Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/
   uniFiAP                         Plugin params           /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/
   uniFiAP Warning                 logger  enabled for     WARNING        ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     ERROR          ==> TEST ONLY
   uniFiAP Critical Error          logger  enabled for     CRITICAL       ==> TEST ONLY
   uniFiAP                         check                   /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log  <<<<    for detailed logging
   uniFiAP                         Plugin short Name       UniFi
   uniFiAP                         my PID                  81285
   uniFiAP                         set params for indigo V 7.4
   Started plugin "uniFiAP 7.26.168"
   uniFiAP                         testing if variable enableTimeTracking_UniFi is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
   uniFiAP                         myLogSet setting parameters -- logFileActive= ; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.karlwachs.uniFiAP/plugin.log;  debugLevel= []
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:23:34:uy","msg":"api.err.UnknownDevice"},"data":[]}<<
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100    89  100    89    0     0    432      0 --:--:-- --:--:-- --:--:--   432
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:67:hj","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    428      0 --:--:-- --:--:-- --:--:--   429
   uniFiAP                          start   runConcurrentThread, initializing loop settings and threads ..
   uniFiAP                         initialized ... looping
Thanks for your help.
Edmond
Sat Nov 30, 2019 3:06 pm
Re: New Error after updating plugin
Can you check your ip# settings in the config menu?
Some of the names might have changed and then the info got lost.
Sat Nov 30, 2019 4:23 pm
The Unix prompt is not set in config
Mon Dec 02, 2019 9:51 am
dnomode offline
Hello Karl,
I checked the IP address of the controller, USG, APs and Switch and all are correct. I also set the Unix prompt to US.v
I'm still getting errors.
What should I try next?
Thanks, Edmond
Mon Dec 02, 2019 10:35 am
Could you switch on debug for ssh or connect... need to see the connect command string and the response
It contains the userid and password. Xxx before posting.
Mon Dec 02, 2019 10:56 am
dnomode offline
Here you go...
Edmond
10:48:13 restart  apPrompt changed VIDEO ipNumber   changed;
02 10:48:29 logger  enabled for     THREADDEBUG    ==> TEST ONLY
02 10:48:29 logger  enabled for     DEBUG          ==> TEST ONLY
10:48:29 logger  enabled for     INFO           ==> TEST ONLY
10:48:29 logger  enabled for     WARNING        ==> TEST ONLY
2019-12-02 10:48:29.220   ERROR          Plugin.__init__                  logger  enabled for     ERROR          ==> TEST ONLY
2019-12-02 10:48:29.221   CRITICAL       Plugin.__init__                  logger  enabled for     CRITICAL       ==> TEST ONLY
10:48:30 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:12:e1
2019-12-02 10:48:31.636   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:23:12:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    444      0 --:--:-- --:--:-- --:--:--   445
10:48:31 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:a5:7c
2019-12-02 10:48:31.867   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:a5:7c","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    440      0 --:--:-- --:--:-- --:--:--   442
10:48:32 runConcurrentThread.....
10:48:32 ..getting missing vendor names for MAC #
10:48:33 ..starting threads for 2 APs 1 sec apart (MSG-log and db-DICT)
10:48:33 getMessages: launching listener for: APtail  @ 192.168.2.186
10:48:34 getMessages: launching listener for: APdict  @ 192.168.2.186
10:48:35 getMessages: launching listener for: APtail  @ 192.168.2.11
10:48:36 getMessages: launching listener for: APdict  @ 192.168.2.11
10:48:37 ..starting threads for GW (MSG-log and db-DICT)
10:48:37 getMessages: launching listener for: GWtail  @ 192.168.2.1
10:48:38 getMessages: launching listener for: GWdict  @ 192.168.2.1
10:48:39 ..starting threads for 1 SWs 11 sec apart (db-DICT only)
10:48:39 getMessages: launching listener for: SWdict  @ 192.168.2.193
02 10:49:01 logger  enabled for     THREADDEBUG    ==> TEST ONLY
02 10:49:01 logger  enabled for     DEBUG          ==> TEST ONLY
10:49:01 logger  enabled for     INFO           ==> TEST ONLY
10:49:01 logger  enabled for     WARNING        ==> TEST ONLY
2019-12-02 10:49:01.433   ERROR          Plugin.__init__                  logger  enabled for     ERROR          ==> TEST ONLY
2019-12-02 10:49:01.433   CRITICAL       Plugin.__init__                  logger  enabled for     CRITICAL       ==> TEST ONLY
10:49:02 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:12:e1
2019-12-02 10:49:03.838   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:23:12:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    434      0 --:--:-- --:--:-- --:--:--   436
10:49:03 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:a5:7c
2019-12-02 10:49:04.073   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:a5:7c","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    429      0 --:--:-- --:--:-- --:--:--   427
10:49:04 runConcurrentThread.....
10:49:04 ..getting missing vendor names for MAC #
10:49:05 ..starting threads for 2 APs 1 sec apart (MSG-log and db-DICT)
10:49:05 getMessages: launching listener for: APtail  @ 192.168.2.186
10:49:06 getMessages: launching listener for: APdict  @ 192.168.2.186
10:49:07 getMessages: launching listener for: APtail  @ 192.168.2.11
10:49:08 getMessages: launching listener for: APdict  @ 192.168.2.11
10:49:09 ..starting threads for GW (MSG-log and db-DICT)
10:49:09 getMessages: launching listener for: GWtail  @ 192.168.2.1
10:49:10 getMessages: launching listener for: GWdict  @ 192.168.2.1
10:49:11 ..starting threads for 1 SWs 11 sec apart (db-DICT only)
10:49:11 getMessages: launching listener for: SWdict  @ 192.168.2.193
11:40:36 restart  apPrompt changed VIDEO ipNumber   changed;
02 11:40:51 logger  enabled for     THREADDEBUG    ==> TEST ONLY
02 11:40:51 logger  enabled for     DEBUG          ==> TEST ONLY
11:40:51 logger  enabled for     INFO           ==> TEST ONLY
11:40:51 logger  enabled for     WARNING        ==> TEST ONLY
2019-12-02 11:40:51.583   ERROR          Plugin.__init__                  logger  enabled for     ERROR          ==> TEST ONLY
2019-12-02 11:40:51.583   CRITICAL       Plugin.__init__                  logger  enabled for     CRITICAL       ==> TEST ONLY
11:40:52 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:12:e1
11:40:52 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "XXXXXXX", "password": “XXXXXX”}’ 'https://192.168.2.207:8443/api/login'
11:40:53 Connection: {"meta":{"rc":"ok"},"data":[]}
11:40:53 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/f0:9f:c2:23:15:yu'
2019-12-02 11:40:54.003   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:23:15:yu","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    445      0 --:--:-- --:--:-- --:--:--   447
11:40:54 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:a5:7c
11:40:54 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "XXXXXXX", "password": “XXXXXXX”}’ 'https://192.168.2.207:8443/api/login'
11:40:54 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/80:2a:a8:d3:15:yu'
2019-12-02 11:40:54.237   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:15:yu","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    435      0 --:--:-- --:--:-- --:--:--   436
11:40:54 runConcurrentThread.....
11:40:54 ..getting missing vendor names for MAC #
11:40:55 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "XXXXXXX", "password": “XXXXXXXX”}’ 'https://192.168.2.207:8443/api/login'
11:40:55 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
11:40:55 Connection: {"meta":{"rc":"ok"},"data":[]}
11:40:56 ..starting threads for 2 APs 1 sec apart (MSG-log and db-DICT)
11:40:56 getMessages: launching listener for: APtail  @ 192.168.2.186
11:40:57 getMessages: launching listener for: APdict  @ 192.168.2.186
11:40:58 getMessages: launching listener for: APtail  @ 192.168.2.11
11:40:59 getMessages: launching listener for: APdict  @ 192.168.2.11
11:41:00 ..starting threads for GW (MSG-log and db-DICT)
11:41:00 getMessages: launching listener for: GWtail  @ 192.168.2.1
11:41:01 getMessages: launching listener for: GWdict  @ 192.168.2.1
11:41:02 ..starting threads for 1 SWs 11 sec apart (db-DICT only)
11:41:02 getMessages: launching listener for: SWdict  @ 192.168.2.193
11:43:55 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
11:43:55 CONNtest  execLog.exp exists, now doing ping
11:43:55 CONNtest  expect is running
11:44:02 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "XXXXXXX", "password": “XXXXXXXX”}’ 'https://192.168.2.207:8443/api/login'
11:44:03 Connection: {"meta":{"rc":"ok"},"data":[]}
11:44:03 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
11:44:04 Connection: {"meta":{"rc":"ok"},"data":[]}
02 11:46:46 logger  enabled for     THREADDEBUG    ==> TEST ONLY
02 11:46:46 logger  enabled for     DEBUG          ==> TEST ONLY
11:46:46 logger  enabled for     INFO           ==> TEST ONLY
11:46:46 logger  enabled for     WARNING        ==> TEST ONLY
2019-12-02 11:46:46.743   ERROR          Plugin.__init__                  logger  enabled for     ERROR          ==> TEST ONLY
2019-12-02 11:46:46.743   CRITICAL       Plugin.__init__                  logger  enabled for     CRITICAL       ==> TEST ONLY
11:46:47 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:12:e1
11:46:47 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "XXXXXXX", "password": “XXXXXXX”}’ 'https://192.168.2.207:8443/api/login'
11:46:48 Connection: {"meta":{"rc":"ok"},"data":[]}
11:46:48 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/f0:9f:c2:23:15:yu'
2019-12-02 11:46:49.210   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:23:15:yu","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    448      0 --:--:-- --:--:-- --:--:--   449
11:46:49 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:a5:7c
11:46:49 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "XXXXXXX", "password": “XXXXXXXX”}’ 'https://192.168.2.207:8443/api/login'
11:46:49 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/80:2a:a8:d3:15:yu'
2019-12-02 11:46:49.441   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:15:yu","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    441      0 --:--:-- --:--:-- --:--:--   442
11:46:50 runConcurrentThread.....
11:46:50 ..getting missing vendor names for MAC #
11:46:50 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "XXXXXXX", "password": “XXXXXXXX”}’ 'https://192.168.2.207:8443/api/login'
11:46:50 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
11:46:51 Connection: {"meta":{"rc":"ok"},"data":[]}
11:46:51 ..starting threads for 2 APs 1 sec apart (MSG-log and db-DICT)
11:46:51 getMessages: launching listener for: APtail  @ 192.168.2.186
11:46:52 getMessages: launching listener for: APdict  @ 192.168.2.186
11:46:53 getMessages: launching listener for: APtail  @ 192.168.2.11
11:46:54 getMessages: launching listener for: APdict  @ 192.168.2.11
11:46:55 ..starting threads for GW (MSG-log and db-DICT)
11:46:55 getMessages: launching listener for: GWtail  @ 192.168.2.1
11:46:56 getMessages: launching listener for: GWdict  @ 192.168.2.1
11:46:57 ..starting threads for 1 SWs 11 sec apart (db-DICT only)
11:46:57 getMessages: launching listener for: SWdict  @ 192.168.2.193
11:49:51 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
11:49:51 CONNtest  execLog.exp exists, now doing ping
11:49:51 CONNtest  expect is running
11:49:56 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "XXXXXXX", "password": “XXXXXXXX”}’ 'https://192.168.2.207:8443/api/login'
11:49:57 Connection: {"meta":{"rc":"ok"},"data":[]}
11:49:57 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
Mon Dec 02, 2019 11:44 am
Need the unifi.....plugin.log file
The indigo log shows only the errors
The detailed logging is in the plugin log file
Mon Dec 02, 2019 2:00 pm
dnomode offline
I though that was it. How about this? I took it from /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP
Edmond
Edmond
[code]10:48:13 restart  apPrompt changed VIDEO ipNumber   changed;
10:48:30 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:92:we
2019-12-02 10:48:31.636   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:45:43:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
10:48:31 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:92:we
2019-12-02 10:48:31.867   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:92:we","msg":"api.err.UnknownDevice"},"data":[]}<<
10:49:02 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:92:we
2019-12-02 10:49:03.838   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:45:43:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
10:49:03 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:92:we
2019-12-02 10:49:04.073   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:92:we","msg":"api.err.UnknownDevice"},"data":[]}<<
11:40:52 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:92:we
11:40:52 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:40:53 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/f0:9f:c2:23:92:we'
2019-12-02 11:40:54.003   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:45:43:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
11:40:54 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:92:we
11:40:54 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:40:54 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/80:2a:a8:d3:92:we'
2019-12-02 11:40:54.237   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:92:we","msg":"api.err.UnknownDevice"},"data":[]}<<
11:40:55 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:44:02 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:46:47 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:92:we
11:46:47 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:46:48 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/f0:9f:c2:23:92:we'
2019-12-02 11:46:49.210   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:45:43:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
11:46:49 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:92:we
11:46:49 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:46:49 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/80:2a:a8:d3:92:we'
2019-12-02 11:46:49.441   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:92:we","msg":"api.err.UnknownDevice"},"data":[]}<<
11:46:50 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:49:56 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:52:59 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:53:00 Connection: {"meta":{"rc":"ok"},"data":[]}
11:53:00 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
11:53:05 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
11:53:05 CONNtest  execLog.exp exists, now doing ping
11:53:06 CONNtest  expect is running
11:56:02 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:56:03 Connection: {"meta":{"rc":"ok"},"data":[]}
11:56:03 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
11:56:19 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
11:56:19 CONNtest  execLog.exp exists, now doing ping
11:56:19 CONNtest  expect is running
11:57:11 restart  apPrompt changed VIDEO ipNumber   changed;
02 11:57:22 logger  enabled for     THREADDEBUG    ==> TEST ONLY
02 11:57:22 logger  enabled for     DEBUG          ==> TEST ONLY
11:57:22 logger  enabled for     INFO           ==> TEST ONLY
11:57:22 logger  enabled for     WARNING        ==> TEST ONLY
2019-12-02 11:57:22.822   ERROR          Plugin.__init__                  logger  enabled for     ERROR          ==> TEST ONLY
2019-12-02 11:57:22.823   CRITICAL       Plugin.__init__                  logger  enabled for     CRITICAL       ==> TEST ONLY
11:57:23 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:92:we
11:57:23 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:57:24 Connection: {"meta":{"rc":"ok"},"data":[]}
11:57:24 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/f0:9f:c2:23:92:we'
2019-12-02 11:57:25.172   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:45:43:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    414      0 --:--:-- --:--:-- --:--:--   413
11:57:25 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:92:we
11:57:25 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:57:25 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/80:2a:a8:d3:92:we'
2019-12-02 11:57:25.403   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:92:we","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    436      0 --:--:-- --:--:-- --:--:--   438
11:57:26 runConcurrentThread.....
11:57:26 ..getting missing vendor names for MAC #
11:57:26 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
11:57:26 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
11:57:27 Connection: {"meta":{"rc":"ok"},"data":[]}
11:57:27 ..starting threads for 2 APs 1 sec apart (MSG-log and db-DICT)
11:57:27 getMessages: launching listener for: APtail  @ 192.168.2.186
11:57:28 getMessages: launching listener for: APdict  @ 192.168.2.186
11:57:29 getMessages: launching listener for: APtail  @ 192.168.2.11
11:57:30 getMessages: launching listener for: APdict  @ 192.168.2.11
11:57:31 ..starting threads for GW (MSG-log and db-DICT)
11:57:31 getMessages: launching listener for: GWtail  @ 192.168.2.1
11:57:32 getMessages: launching listener for: GWdict  @ 192.168.2.1
11:57:33 ..starting threads for 1 SWs 11 sec apart (db-DICT only)
11:57:33 getMessages: launching listener for: SWdict  @ 192.168.2.193
12:00:26 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:00:26 CONNtest  execLog.exp exists, now doing ping
12:00:26 CONNtest  expect is running
12:00:32 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:00:33 Connection: {"meta":{"rc":"ok"},"data":[]}
12:00:33 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:00:34 Connection: {"meta":{"rc":"ok"},"data":[]}
12:03:37 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:03:38 Connection: {"meta":{"rc":"ok"},"data":[]}
12:03:38 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:03:40 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:03:40 CONNtest  execLog.exp exists, now doing ping
12:03:40 CONNtest  expect is running
12:06:41 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:06:42 Connection: {"meta":{"rc":"ok"},"data":[]}
12:06:42 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:06:53 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:06:53 CONNtest  execLog.exp exists, now doing ping
12:06:54 CONNtest  expect is running
12:09:44 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:09:45 Connection: {"meta":{"rc":"ok"},"data":[]}
12:09:45 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:10:08 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:10:08 CONNtest  execLog.exp exists, now doing ping
12:10:08 CONNtest  expect is running
12:12:47 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:12:48 Connection: {"meta":{"rc":"ok"},"data":[]}
12:12:48 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:13:21 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:13:21 CONNtest  execLog.exp exists, now doing ping
12:13:21 CONNtest  expect is running
12:15:51 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:15:52 Connection: {"meta":{"rc":"ok"},"data":[]}
12:15:52 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:16:34 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:16:34 CONNtest  execLog.exp exists, now doing ping
12:16:35 CONNtest  expect is running
12:18:59 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:19:00 Connection: {"meta":{"rc":"ok"},"data":[]}
12:19:00 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:19:48 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:19:48 CONNtest  execLog.exp exists, now doing ping
12:19:48 CONNtest  expect is running
12:22:02 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:22:03 Connection: {"meta":{"rc":"ok"},"data":[]}
12:22:03 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:23:03 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:23:03 CONNtest  execLog.exp exists, now doing ping
12:23:03 CONNtest  expect is running
12:25:04 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:25:05 Connection: {"meta":{"rc":"ok"},"data":[]}
12:25:05 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:25:06 Connection: {"meta":{"rc":"ok"},"data":[]}
12:26:17 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:26:17 CONNtest  execLog.exp exists, now doing ping
12:26:17 CONNtest  expect is running
12:28:31 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:28:33 Connection: {"meta":{"rc":"ok"},"data":[]}
12:28:33 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:29:31 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:29:31 CONNtest  execLog.exp exists, now doing ping
12:29:31 CONNtest  expect is running
12:31:35 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:31:36 Connection: {"meta":{"rc":"ok"},"data":[]}
12:31:36 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:32:45 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:32:45 CONNtest  execLog.exp exists, now doing ping
12:32:45 CONNtest  expect is running
12:34:37 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:34:38 Connection: {"meta":{"rc":"ok"},"data":[]}
12:34:38 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:35:59 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:35:59 CONNtest  execLog.exp exists, now doing ping
12:35:59 CONNtest  expect is running
12:37:39 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:37:40 Connection: {"meta":{"rc":"ok"},"data":[]}
12:37:40 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:37:41 Connection: {"meta":{"rc":"ok"},"data":[]}
12:40:44 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:40:45 Connection: {"meta":{"rc":"ok"},"data":[]}
12:40:45 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:40:46 Connection: {"meta":{"rc":"ok"},"data":[]}
12:41:37 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:41:37 CONNtest  execLog.exp exists, now doing ping
12:41:37 CONNtest  expect is running
12:43:47 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:43:48 Connection: {"meta":{"rc":"ok"},"data":[]}
12:43:48 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:43:49 Connection: {"meta":{"rc":"ok"},"data":[]}
12:44:29 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:44:29 CONNtest  execLog.exp exists, now doing ping
12:44:29 CONNtest  expect is running
12:46:50 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:46:51 Connection: {"meta":{"rc":"ok"},"data":[]}
12:46:51 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:46:52 Connection: {"meta":{"rc":"ok"},"data":[]}
12:47:42 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:47:42 CONNtest  execLog.exp exists, now doing ping
12:47:42 CONNtest  expect is running
12:49:53 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:49:54 Connection: {"meta":{"rc":"ok"},"data":[]}
12:49:54 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:50:56 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:50:56 CONNtest  execLog.exp exists, now doing ping
12:50:56 CONNtest  expect is running
12:52:56 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:52:57 Connection: {"meta":{"rc":"ok"},"data":[]}
12:52:57 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:54:11 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:54:11 CONNtest  execLog.exp exists, now doing ping
12:54:12 CONNtest  expect is running
12:55:59 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:56:00 Connection: {"meta":{"rc":"ok"},"data":[]}
12:56:00 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:57:26 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
12:57:26 CONNtest  execLog.exp exists, now doing ping
12:57:26 CONNtest  expect is running
12:59:01 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
12:59:02 Connection: {"meta":{"rc":"ok"},"data":[]}
12:59:02 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
12:59:03 Connection: {"meta":{"rc":"ok"},"data":[]}
13:00:40 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:00:40 CONNtest  execLog.exp exists, now doing ping
13:00:40 CONNtest  expect is running
13:02:04 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:02:06 Connection: {"meta":{"rc":"ok"},"data":[]}
13:02:06 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:03:53 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:03:53 CONNtest  execLog.exp exists, now doing ping
13:03:53 CONNtest  expect is running
13:05:08 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:05:09 Connection: {"meta":{"rc":"ok"},"data":[]}
13:05:09 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:07:08 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:07:08 CONNtest  execLog.exp exists, now doing ping
13:07:08 CONNtest  expect is running
13:08:11 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:08:12 Connection: {"meta":{"rc":"ok"},"data":[]}
13:08:12 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:08:13 Connection: {"meta":{"rc":"ok"},"data":[]}
13:10:21 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:10:21 CONNtest  execLog.exp exists, now doing ping
13:10:21 CONNtest  expect is running
13:11:15 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:11:15 Connection: {"meta":{"rc":"ok"},"data":[]}
13:11:15 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:11:16 Connection: {"meta":{"rc":"ok"},"data":[]}
13:13:34 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:13:34 CONNtest  execLog.exp exists, now doing ping
13:13:34 CONNtest  expect is running
13:14:17 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:14:18 Connection: {"meta":{"rc":"ok"},"data":[]}
13:14:18 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:16:49 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:16:49 CONNtest  execLog.exp exists, now doing ping
13:16:49 CONNtest  expect is running
13:17:20 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:17:21 Connection: {"meta":{"rc":"ok"},"data":[]}
13:17:21 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:17:22 Connection: {"meta":{"rc":"ok"},"data":[]}
13:20:03 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:20:03 CONNtest  execLog.exp exists, now doing ping
13:20:03 CONNtest  expect is running
13:20:23 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:20:24 Connection: {"meta":{"rc":"ok"},"data":[]}
13:20:24 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:23:17 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:23:17 CONNtest  execLog.exp exists, now doing ping
13:23:17 CONNtest  expect is running
13:23:25 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:23:26 Connection: {"meta":{"rc":"ok"},"data":[]}
13:23:26 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:23:27 Connection: {"meta":{"rc":"ok"},"data":[]}
13:26:28 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:26:30 Connection: {"meta":{"rc":"ok"},"data":[]}
13:26:30 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:26:32 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:26:32 CONNtest  execLog.exp exists, now doing ping
13:26:32 CONNtest  expect is running
13:29:31 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:29:33 Connection: {"meta":{"rc":"ok"},"data":[]}
13:29:33 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:29:45 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:29:45 CONNtest  execLog.exp exists, now doing ping
13:29:45 CONNtest  expect is running
13:32:34 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:32:35 Connection: {"meta":{"rc":"ok"},"data":[]}
13:32:35 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:33:00 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:33:00 CONNtest  execLog.exp exists, now doing ping
13:33:00 CONNtest  expect is running
13:33:33                          -myLogSet setting parameters -- logFileActive= indigo; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log;  debugLevel= ['Connection']
13:33:33 restart  apPrompt changed VIDEO ipNumber   changed;
02 13:33:46 logger  enabled for     THREADDEBUG    ==> TEST ONLY
02 13:33:46 logger  enabled for     DEBUG          ==> TEST ONLY
13:33:46 logger  enabled for     INFO           ==> TEST ONLY
13:33:46 logger  enabled for     WARNING        ==> TEST ONLY
2019-12-02 13:33:46.554   ERROR          Plugin.__init__                  logger  enabled for     ERROR          ==> TEST ONLY
2019-12-02 13:33:46.554   CRITICAL       Plugin.__init__                  logger  enabled for     CRITICAL       ==> TEST ONLY
13:33:46                          -myLogSet setting parameters -- logFileActive= indigo; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log;  debugLevel= ['Connection']
13:33:47 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:92:we
13:33:47 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:33:48 Connection: {"meta":{"rc":"ok"},"data":[]}
13:33:48 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/f0:9f:c2:23:92:we'
2019-12-02 13:33:48.741   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:45:43:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    431      0 --:--:-- --:--:-- --:--:--   432
13:33:48 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:92:we
13:33:48 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:33:48 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/80:2a:a8:d3:92:we'
2019-12-02 13:33:48.968   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:92:we","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    446      0 --:--:-- --:--:-- --:--:--   447
13:33:49 runConcurrentThread.....
13:33:49 ..getting missing vendor names for MAC #
13:33:50 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:33:50 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:33:50 Connection: {"meta":{"rc":"ok"},"data":[]}
13:33:50 ..starting threads for 2 APs 1 sec apart (MSG-log and db-DICT)
13:33:50 getMessages: launching listener for: APtail  @ 192.168.2.186
13:33:51 getMessages: launching listener for: APdict  @ 192.168.2.186
13:33:52 getMessages: launching listener for: APtail  @ 192.168.2.11
13:33:53 getMessages: launching listener for: APdict  @ 192.168.2.11
13:33:54 ..starting threads for GW (MSG-log and db-DICT)
13:33:54 getMessages: launching listener for: GWtail  @ 192.168.2.1
13:33:55 getMessages: launching listener for: GWdict  @ 192.168.2.1
13:33:56 ..starting threads for 1 SWs 11 sec apart (db-DICT only)
13:33:56 getMessages: launching listener for: SWdict  @ 192.168.2.193
13:36:55 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:36:59 Connection: {"meta":{"rc":"ok"},"data":[]}
13:36:59 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:39:25 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:39:25 CONNtest  execLog.exp exists, now doing ping
13:39:25 CONNtest  expect is running
13:40:01 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:40:02 Connection: {"meta":{"rc":"ok"},"data":[]}
13:40:02 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:42:17 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:42:17 CONNtest  execLog.exp exists, now doing ping
13:42:18 CONNtest  expect is running
13:43:03 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:43:04 Connection: {"meta":{"rc":"ok"},"data":[]}
13:43:04 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:45:31 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:45:31 CONNtest  execLog.exp exists, now doing ping
13:45:31 CONNtest  expect is running
13:46:06 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:46:08 Connection: {"meta":{"rc":"ok"},"data":[]}
13:46:08 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:48:45 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:48:45 CONNtest  execLog.exp exists, now doing ping
13:48:45 CONNtest  expect is running
13:49:10 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:49:11 Connection: {"meta":{"rc":"ok"},"data":[]}
13:49:11 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:51:59 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:51:59 CONNtest  execLog.exp exists, now doing ping
13:51:59 CONNtest  expect is running
13:52:13 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:52:14 Connection: {"meta":{"rc":"ok"},"data":[]}
13:52:14 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:52:15 Connection: {"meta":{"rc":"ok"},"data":[]}
13:55:12 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:55:12 CONNtest  execLog.exp exists, now doing ping
13:55:12 CONNtest  expect is running
13:55:17 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:55:18 Connection: {"meta":{"rc":"ok"},"data":[]}
13:55:18 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:58:20 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
13:58:21 Connection: {"meta":{"rc":"ok"},"data":[]}
13:58:21 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
13:58:22 Connection: {"meta":{"rc":"ok"},"data":[]}
13:58:26 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
13:58:26 CONNtest  execLog.exp exists, now doing ping
13:58:26 CONNtest  expect is running
14:01:23 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:01:24 Connection: {"meta":{"rc":"ok"},"data":[]}
14:01:24 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:01:25 Connection: {"meta":{"rc":"ok"},"data":[]}
14:01:40 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:01:40 CONNtest  execLog.exp exists, now doing ping
14:01:40 CONNtest  expect is running
14:04:26 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:04:27 Connection: {"meta":{"rc":"ok"},"data":[]}
14:04:27 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:04:28 Connection: {"meta":{"rc":"ok"},"data":[]}
14:04:54 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:04:54 CONNtest  execLog.exp exists, now doing ping
14:04:55 CONNtest  expect is running
14:07:31 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:07:33 Connection: {"meta":{"rc":"ok"},"data":[]}
14:07:33 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:08:09 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:08:09 CONNtest  execLog.exp exists, now doing ping
14:08:09 CONNtest  expect is running
14:10:40 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:10:41 Connection: {"meta":{"rc":"ok"},"data":[]}
14:10:41 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:11:23 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:11:23 CONNtest  execLog.exp exists, now doing ping
14:11:23 CONNtest  expect is running
14:13:43 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:13:44 Connection: {"meta":{"rc":"ok"},"data":[]}
14:13:44 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:14:37 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:14:37 CONNtest  execLog.exp exists, now doing ping
14:14:37 CONNtest  expect is running
14:16:45 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:16:46 Connection: {"meta":{"rc":"ok"},"data":[]}
14:16:46 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:17:51 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:17:51 CONNtest  execLog.exp exists, now doing ping
14:17:51 CONNtest  expect is running
14:19:48 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:19:49 Connection: {"meta":{"rc":"ok"},"data":[]}
14:19:49 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:21:05 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:21:05 CONNtest  execLog.exp exists, now doing ping
14:21:05 CONNtest  expect is running
14:22:51 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:22:52 Connection: {"meta":{"rc":"ok"},"data":[]}
14:22:52 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:24:19 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:24:19 CONNtest  execLog.exp exists, now doing ping
14:24:19 CONNtest  expect is running
14:25:53 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:25:55 Connection: {"meta":{"rc":"ok"},"data":[]}
14:25:55 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:27:33 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:27:33 CONNtest  execLog.exp exists, now doing ping
14:27:33 CONNtest  expect is running
14:28:56 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:28:57 Connection: {"meta":{"rc":"ok"},"data":[]}
14:28:57 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:30:47 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:30:47 CONNtest  execLog.exp exists, now doing ping
14:30:47 CONNtest  expect is running
14:31:58 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:32:00 Connection: {"meta":{"rc":"ok"},"data":[]}
14:32:00 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:34:11 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:34:11 CONNtest  execLog.exp exists, now doing ping
14:34:11 CONNtest  expect is running
14:35:01 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:35:03 Connection: {"meta":{"rc":"ok"},"data":[]}
14:35:03 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:37:24 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:37:24 CONNtest  execLog.exp exists, now doing ping
14:37:24 CONNtest  expect is running
14:38:04 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:38:05 Connection: {"meta":{"rc":"ok"},"data":[]}
14:38:05 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:40:37 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:40:37 CONNtest  execLog.exp exists, now doing ping
14:40:38 CONNtest  expect is running
14:41:07 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:41:08 Connection: {"meta":{"rc":"ok"},"data":[]}
14:41:08 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:43:51 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:43:51 CONNtest  execLog.exp exists, now doing ping
14:43:51 CONNtest  expect is running
14:44:09 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:44:11 Connection: {"meta":{"rc":"ok"},"data":[]}
14:44:11 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:47:05 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:47:05 CONNtest  execLog.exp exists, now doing ping
14:47:05 CONNtest  expect is running
14:47:12 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:47:13 Connection: {"meta":{"rc":"ok"},"data":[]}
14:47:13 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:47:14 Connection: {"meta":{"rc":"ok"},"data":[]}
14:50:15 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:50:16 Connection: {"meta":{"rc":"ok"},"data":[]}
14:50:16 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:50:20 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:50:20 CONNtest  execLog.exp exists, now doing ping
14:50:20 CONNtest  expect is running
14:53:17 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:53:18 Connection: {"meta":{"rc":"ok"},"data":[]}
14:53:18 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:53:35 CONNtest  testing if 192.168.2.1/usr/bin/expect execLog.exp is running
14:53:35 CONNtest  execLog.exp exists, now doing ping
14:53:35 CONNtest  expect is running
02 14:53:54 logger  enabled for     THREADDEBUG    ==> TEST ONLY
02 14:53:54 logger  enabled for     DEBUG          ==> TEST ONLY
14:53:54 logger  enabled for     INFO           ==> TEST ONLY
14:53:54 logger  enabled for     WARNING        ==> TEST ONLY
2019-12-02 14:53:54.175   ERROR          Plugin.__init__                  logger  enabled for     ERROR          ==> TEST ONLY
2019-12-02 14:53:54.175   CRITICAL       Plugin.__init__                  logger  enabled for     CRITICAL       ==> TEST ONLY
14:53:54                          -myLogSet setting parameters -- logFileActive= indigo; logFile= /Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.karlwachs.uniFiAP/plugin.log;  debugLevel= ['Connection']
14:53:55 unifi-Report getting _id for AP Y-Basement AP  /stat/device/f0:9f:c2:23:92:we
14:53:55 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:53:56 Connection: {"meta":{"rc":"ok"},"data":[]}
14:53:56 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/f0:9f:c2:23:92:we'
2019-12-02 14:53:56.512   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:45:43:e1","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    432      0 --:--:-- --:--:-- --:--:--   434
14:53:56 unifi-Report getting _id for AP Y-Master AP  /stat/device/80:2a:a8:d3:92:we
14:53:56 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:53:56 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/device/80:2a:a8:d3:92:we'
2019-12-02 14:53:56.735   ERROR          Plugin.executeCMDOnController     Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:92:we","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    453      0 --:--:-- --:--:-- --:--:--   454
14:53:57 runConcurrentThread.....
14:53:57 ..getting missing vendor names for MAC #
14:53:58 Connection: /usr/bin/curl --insecure -c /tmp/unifiCookie --data '{"username": "xxxxxxx", "password": "xxxxxxx"}' 'https://192.168.2.207:8443/api/login'
14:53:58 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie  --data '{"type": "all", "conn": "all"}'  -X PUT  'https://192.168.2.207:8443/api/s/default/stat/alluser'
14:53:58 Connection: {"meta":{"rc":"ok"},"data":[]}
14:53:58 ..starting threads for 2 APs 1 sec apart (MSG-log and db-DICT)
14:53:58 getMessages: launching listener for: APtail  @ 192.168.2.186
14:53:59 getMessages: launching listener for: APdict  @ 192.168.2.186
14:54:00 getMessages: launching listener for: APtail  @ 192.168.2.11
14:54:01 getMessages: launching listener for: APdict  @ 192.168.2.11
14:54:02 ..starting threads for GW (MSG-log and db-DICT)
14:54:02 getMessages: launching listener for: GWtail  @ 192.168.2.1
14:54:03 getMessages: launching listener for: GWdict  @ 192.168.2.1
14:54:04 ..starting threads for 1 SWs 11 sec apart (db-DICT only)
14:54:04 getMessages: launching listener for: SWdict  @ 192.168.2.193
[/code]
Mon Dec 02, 2019 5:06 pm
it seems that the listeners are running fine.
these errors:
{"rc":"error","mac":"80:2a:a8:d3:a5:7c","msg":"api.err.UnknownDevice"}...
indicate that the MAC numbers are wrong..
could you do some of these reports:
Screen Shot 2019-12-02 at 17.01.22.png (113.27 KiB) Viewed 592 times
and check if the mac numbers are correct and /or if the controllers / Ams are answering properly
some examples:
16:59:41 unifi-Report getting _id for AP AP_3_study  /stat/device/f0:9f:c2:xxxxx::2f
16:59:42 unifi-Report  _id in data  :5a11d79xxxxx71cfb113
16:59:42 unifi-Report getting _id for AP AP_4_server  /stat/device/f0:9f:xxx:15
16:59:42 unifi-Report  _id in data  :5a11d69eexxxxxb0f0
16:59:42 unifi-Report getting _id for AP AP_5_gameRoom  /stat/device/b4:fxxxx5:e0
16:59:42 unifi-Report  _id in data  :5c23exxxcb
17:00:32 unifi-Report getting _id for AP AP_3_study  /stat/device/f0:xxx
17:00:32 unifi-Report  _id in data  :5a11dxxx13
17:00:32 unifi-Report getting _id for AP AP_4_server  /stat/device/f0:9fxxx5
17:00:32 unifi-Report  _id in data  :5a11d69exxxcfb0f0
17:00:32 unifi-Report getting _id for AP AP_5_gameRoom  /stat/device/b4:fbxxx
17:00:32 unifi-Report  _id in data  :5cxxxc5cb
17:01:06 Connection: == Device print: /stat/device/f0:xxx==
17:01:06  Connection  info
    "_id": "5a11xxx3",
    "_uptime": 372738,
    "adopt_ip": "192xxxxx",
    "adopt_url": "http://192.16xxxxx:8080/inform",
    "adoptable_when_upgraded": false,
    "adopted": true,
    "antenna_table": .....
Mon Dec 02, 2019 5:43 pm
dnomode offline
The first 4 items are "print info for system devices" and the MAC address listed are correct for the APs and the switch, However I noticed that the MAC address for the USG is incorrect.
The last 4 items are "print info for client devices" and the MAC address is correct for the USG
Edmond
Screenshot 2019-12-02 18.42.13.png (130.67 KiB) Viewed 537 times
 uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"fc:ec:da:d1:1b:c5","msg":"api.err.UnknownDevice"},"data":[]}<<
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:61:67:we","msg":"api.err.UnknownDevice"},"data":[]}<<
100    89  100    89    0     0    451      0 --:--:-- --:--:-- --:--:--   451
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:67:we","msg":"api.err.UnknownDevice"},"data":[]}<<
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100    89  100    89    0     0    454      0 --:--:-- --:--:-- --:--:--   454
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:23:67:we","msg":"api.err.UnknownDevice"},"data":[]}<<
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"fc:ec:da:d1:67:we","msg":"api.err.UnknownStation"},"data":[]}<<
100    90  100    90    0     0    447      0 --:--:-- --:--:-- --:--:--   450
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:61:67:we","msg":"api.err.UnknownStation"},"data":[]}<<
100    90  100    90    0     0    463      0 --:--:-- --:--:-- --:--:--   463
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"f0:9f:c2:23:67:we","msg":"api.err.UnknownStation"},"data":[]}<<
100    90  100    90    0     0    455      0 --:--:-- --:--:-- --:--:--   456
   uniFiAP Error                    Connection error: >>{"meta":{"rc":"error","mac":"80:2a:a8:d3:67:we","msg":"api.err.UnknownStation"},"data":[]}<<
100    90  100    90    0     0    467      0 --:--:-- --:--:-- --:--:--   466
[/code]
Mon Dec 02, 2019 6:03 pm
Re: New Error after updating plugin
Could you check if the mac numbers are correct? In device states
Mon Dec 02, 2019 6:49 pm
dnomode offline
Sure, If you please tell me how :oops:
Mon Dec 02, 2019 7:04 pm
list the unified devices and there you should see the mac numbers in the address field
Screen Shot 2019-12-02 at 19.02.58.png (108.12 KiB) Viewed 569 times
Mon Dec 02, 2019 7:13 pm
dnomode offline
The USG is in here twice. I don't remember why. And the first one has the correct MAC
What you think
Screenshot 2019-12-02 20.11.03.png (74.35 KiB) Viewed 537 times
