Power cycle PoE port killed my switch :/
Fri Feb 22, 2019 6:06 pm
DrLove offline
Hi.
I use this plugin for my APs and today I tried to power cycle a port on my unifi switch US-8-60w. The power turned off but now none of my PoE-ports is giving power and I cant turn them on.
I have tried to use power ON to no avail.
PoE injector still works so it's a switch problem.
I cant find a setting in the Unifi GUI to power on the ports again and "#show poe status all" shows
Intf      Detection      Class   Consumed(W) Voltage(V) Current(mA) Temperature(C)
0/5       Open Circuit   Unknown        0.00       0.00        0.00             53
0/6       R Sig Too Low  Unknown        0.00       0.00        0.00             53
0/7       Open Circuit   Unknown        0.00       0.00        0.00             53
0/8       Open Circuit   Unknown        0.00       0.00        0.00             53
0/5 is where my camera is connected
0/6 is an turned off TV, no PoE.
I have factory reset the switch to no avail.
What has happened???
Love Kull (yes it's my name)
Blog (in Swedish)
Sweden
Fri Feb 22, 2019 10:11 pm
Re: Power cycle PoE port killed my switch :/
at the unifi controller:
1. go to devices
2. click on the switch
3. click on ports
4. click on "profile overrides>"
you should then see this:.
Screen Shot 2019-02-22 at 22.04.32.png (57.74 KiB) Viewed 582 times
there try POE off/ on
The plugin POE cycle command does the following:
ssh to the switch and login
telnet localhost 23
enable
configure
interface 0/<<PORT# here>>
poe opmode shutdown
poe opmode auto
exit
exit
exit
exit
exit
see also /Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/cyclePort.exp
Tue Mar 12, 2019 3:27 pm
DrLove offline
Must have been a coincident that my cable decided to fail exactly when I tested the "cycle PoE power" function :) There was a half bad connection that fooled the switch there was nothing connected but my dumb PoE-injector w/o auto sensing worked. After fixing the cable it now works.
//L
Blog (in Swedish)
Sweden
Tue Mar 12, 2019 6:11 pm
Good to hear.
Karl.
