Custom states : Blocked
Mon Dec 24, 2018 9:05 pm
Asconasny offline
Hi Karl,
Loving this plugin. :D
Im using a some action groups to block/unblock devices on my network, which works great.
but the custom state for the device doesnt seem to change. If a device is blocked the custom state shows blocked=false
Would think that should change to blocked=true or something.
If this is not the case, consider this as a feature req. :)
Then it would be possible to make a controlpage with overview of the current state of the devices.
Regards
Asconasny
Mon Dec 24, 2018 11:52 pm
Re: Custom states : Blocked
it should work w config:
1. use controller : ON
2. get (un) blocked client info from controller every xx secs ,; xx !=off
I am not home and can not check right now, back later this week.
Tue Dec 25, 2018 6:15 am
Asconasny offline
Yes, you are correct! :D
Didnt notice the get (un) blocked client info from controller in config.
Perfect!
Thanks.
Tue Dec 25, 2018 10:46 am
will add a little bit more to the process.
you can
1. can block / unblock on the web
2. un/block in the plugin
currently it is a scheduled check once every xx secs (if use controller : ON )
will added:
- when plugin sets un/block it will check the actual states a few secs later
- if use controller : ON or ON reports
-- when I am back home
Tue Dec 25, 2018 6:10 pm
Asconasny offline
sound good :D
I´ve set it to the lowest schedule 20sec.
A check after a few seconds is even better.
Regards
Asconasny
