73 Billion Errors.... 'actionControlSensor'
Wed Nov 14, 2018 7:19 pm
DPattee offline
My log just got flooded with like 50 of these:
uniFiAP Error plugin does not define method actionControlSensor
I was running version .145, I just saw a .146 was released a couple days ago so I updated to that and it didn't help - more errors appeared.
Then all of a sudden the errors just stopped?
Wed Nov 14, 2018 9:28 pm
Re: 73 Billion Errors.... 'actionControlSensor'
that statement is correct: "uniFiAP Error plugin does not define method actionControlSensor"... I checked .. in the last 2 months and that method was never in the plugin .. neither in .plugin.py nor in actions nor in menu..
Is there any other error with line# etc ==> first error after you start plugin
This might be indigo calling the plugin in an action .. don't know what this is ..
anything else that was changed?
Thu Nov 15, 2018 11:04 am
actionControlSensor is actually an action that indigo uses.. and the plugin does not have that method.
it is an action that indigo initiates.
put a dummy method in for the time being until I understand what that does ... have not found any description besides that it was introduced some time in indigo 6.x
see v .147 posted
Thu Nov 15, 2018 12:07 pm
From the plugin.py file in the Example Device - Sensor.indigoPlugin:
   # Sensor Action callback
   def actionControlSensor(self, action, dev):
      ###### TURN ON ######
      # Ignore turn on/off/toggle requests from clients since this is a read-only sensor.
      if action.sensorAction == indigo.kSensorAction.TurnOn:
         indigo.server.log(u"ignored \"%s\" %s request (sensor is read-only)" % (dev.name, "on"))
         # But we could request a sensor state update if we wanted like this:
         # dev.updateStateOnServer("onOffState", True)
      ###### TURN OFF ######
      elif action.sensorAction == indigo.kSensorAction.TurnOff:
         indigo.server.log(u"ignored \"%s\" %s request (sensor is read-only)" % (dev.name, "off"))
         # dev.updateStateOnServer("onOffState", False)
      ###### TOGGLE ######
      elif action.sensorAction == indigo.kSensorAction.Toggle:
         indigo.server.log(u"ignored \"%s\" %s request (sensor is read-only)" % (dev.name, "toggle"))
         # dev.updateStateOnServer("onOffState", not dev.onState)
Some sensor devices (like motion sensors) allow you to turn on/off in Indigo. If you can't perform any actions on them, you could just as easily:
        pass
Not sure what he had that was trying to turn on/off/toggle the device, but something did somehow.
Thu Nov 15, 2018 12:46 pm
Ok thanks. Have added hat roughly.
Thu Nov 15, 2018 3:30 pm
DPattee offline
Ah! It was one of my super old scripts :lol:
I have a few 'startup actions' that run normally just once a week at 3 in the morning when my server does a scheduled reboot. But I'd accidentally power-cycled that machine when I was doing maintenance on another one, so those scripts all ran in the middle of the day.
My 'Status Poll' action is just an embedded AppleScript that is delayed 45 seconds after 'startup' and then runs through every device to get its current state, with the intention of getting Indigo's understanding of the world up-to-date with any changes that occurred while it was offline. (Since it would run after a power failure, or after a server reboot, or any number of other events where switches might be toggled without Indigo running). A side effect is it also finds dying switches for me if I pay attention to the log (there will be red 'no acknowledgement' lines for dying switches)
with timeout of 120 seconds
   try
      repeat with curDevice in devices
         status request (curDevice)
         delay 3
      end repeat
   end try
end timeout
Thu Nov 15, 2018 10:40 pm
you know that this apple script will stop all other indigo activities while it is running?
any command like dev = indigo.devices[devID] will likely timeout and create havoc!! :evil: :evil: :evil:
for dev in indigo.devices:
   lastchange = dev.lastChanged
   if "status" in dev.states:
      indigo.server.log(dev.name+"  has status: "+ unicode(dev.states["status"])+"  last changed:" + unicode(lastchange)  )
         indigo.server.log(dev.name+"  has onState: "+unicode(dev.onState)+"  last changed:" + unicode(lastchange))
      except: pass
this should do roughly the same in python:
Script                          UniFi_sw_3_1_kons  has status: up  last changed:2018-10-14 01:11:43
   Script                          UniFi_sw_3_2_kons  has status: up  last changed:2018-10-14 01:11:43
   Script                          windowDinning  has onState: True  last changed:2018-11-15 17:17:04
   Script                          WindowDownstairs1  has onState: False  last changed:2018-09-12 09:29:27
   Script                          windowDownstairs2  has onState: False  last changed:2013-12-07 16:15:17
   Script                          WindowsKons  has onState: False  last changed:2018-09-28 11:49:04
Fri Nov 16, 2018 12:50 pm
Actually, his AppleScript will force all devices to update their state (thus causing tons of traffic on whatever technology he's using: Insteon, Z-Wave, etc). The equivalent Python script is:
        indigo.device.statusRequest(dev)
    except:
        pass
But, I would highly recommend that you NOT do this. Status requests can be expensive, particularly in Insteon networks, and will likely do more harm than good because of all the extra traffic that it'll generate (potentially causing even more failures). If you have specific devices that somehow get out of sync, then you can do those, but going through every device in the system is not advised.
Sat Nov 17, 2018 10:26 am
Jay,
it looks like "indigo.device.statusRequest(dev)"
does not call "actionControlSensor" but should call "actionControlUniversal"
that one has a status request. ?
Added actionControlUniversal also to avoid issues to the unifi plugin,
BUT was not able to call it with indigo.device.statusRequest(dev)
Is this only enabled for certain types of devices?
   # General Action callback
   def actionControlUniversal(self, action, dev):
      ###### BEEP ######
      if action.deviceAction == indigo.kUniversalAction.Beep:
         # Beep the hardware module (dev) here:
         # ** IMPLEMENT ME **
         indigo.server.log(u"sent \"%s\" %s" % (dev.name, "beep request"))
      ###### STATUS REQUEST ######
      elif action.deviceAction == indigo.kUniversalAction.RequestStatus: #####<<<<<<=======
         # Query hardware module (dev) for its current status here:
         indigo.server.log(u"sent \"%s\" %s" % (dev.name, "status request"))
Sat Nov 17, 2018 1:53 pm
Yeah, his errors weren't from a status request given the name of the missing method in the errors.
I think a device has to set supportsStatusRequest property to True in order for that method to get called.
