- Code: Select all
unifi-Report getting _id for AP Access Point 1 /stat/device/fc:ec:da:d4:60:57
Connection error: (wrong UID/passwd, ip number?) ...>>{ "data" : [ ] , "meta" : { "msg" : "api.err.Invalid" , "rc" : "error"}}<<
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 125 100 72 100 53 74 55 --:--:-- --:--:-- --:--:-- 74
unifi-Report getting _id for AP AP_b4:fb:e4:23:e9:15 /stat/device/b4:fb:e4:23:e9:15
100 125 100 72 100 53 81 59 --:--:-- --:--:-- --:--:-- 81
For example this section has "wrong UID/passwd" errors for my two access points. Using the same user/pwd and IPs that I defined in the plugin configuration screen, I am able to ssh in to those two APs.
SSHing in to my USH, the 2 APs, and my Switch, the user/pass works properly and the Prompt patterns match what the plugin prompts are set to for each of those types of devices.
Additionally the following errors appear about a missing userid:
- Code: Select all
Connection VDdict login disabled, userid is empty
uniFiAP executeCMDonNVR has error, no json object returned: ('', ' % Total % Received % Xferd Average Speed Time Time Time Current\n Dload Upload Total Spent Left Speed\n\r 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) Failed to connect to port 7443: Connection refused\n')
