Unify-Video on Debian
Tue Oct 02, 2018 4:41 pm
stevenu offline
I am a big user with both Indigo and Ubiquity. Your plugin is great. The video servers that I have are all running on separate boxes on Debian. Not on a off the shelf Ubiquity NVR or a virtual box.
Two options seem to be;
--- only if you use Unify Video - NVR
and
--- only if you use VM machine
When I use the first with userid, password, ip address
I keep getting;
ssh response, tags ['welcome', 'unifi', 'edge', 'busybox', 'ubiquiti', 'ubnt'] not found :
My systems are responding with <userid>@<ip_address>'s password:
The script doesn't seem to be able to get past the password; prompt
Any input would be great.
Tue Oct 02, 2018 5:45 pm
Re: Unify-Video on Debian
Before it does all the things It tests the response.
If it does not find a string that is acceptable it rejects it and does not continue.
So >>>after<<< you login. What is a text string it can look for.
this is the EXPECT script to login.
set userID [lindex $argv 0 ]
set password [lindex $argv 1 ]
set ipNumber [lindex $argv 2 ]
set timeout 15
spawn  ssh $userID@$ipNumber
expect {
    "(yes/no)? " {
        send "yes\n"
        sleep 0.1
        expect "assword" { send "$password\n"}
    "assword: " {
        send "$password\n"
send "exit\r"
sleep 0.1
expect eof
can you try: open terminal on the indigo mac and
expect '/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/test.exp' userid password ipnumber
and see if it can login.
Wed Oct 03, 2018 6:13 pm
stevenu offline
Re: Unifi-Video on Debian
The first part I got through after finding out passwords with special characters are not liked. Once I put the password in single quotes, it went through.
Now there is an exit before the prompt is displayed and then a second.
mini-me:~ stevenu$ expect '/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/test.exp' stevenu ubntindigo 172.16.96.150
spawn ssh stevenu@172.16.96.150
stevenu@172.16.96.150's password:
exit
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Oct 3 16:44:56 2018 from 172.16.96.47
stevenu@magevid1:~$ exit
logout
Connection to 172.16.96.150 closed.
mini-me:~ stevenu$
Last login: Wed Oct 3 16:57:23 2018 from 172.16.96.47
exit
logout
mini-me:~ stevenu$
Through Terminal, once logged in from the Indigo MAC to the Debian NVR I can;
/usr/bin/tail -F /var/lib/unifi-video/logs/motion.log
Video clips;
/var/lib/unifi-video/videos
Event image ?
/var/lib/unifi-video/snapshot
Wed Oct 03, 2018 7:43 pm
anything but space should be fine for passwords
it should catch the screen .. it looks for login welcome ...
this is what i get .
 expect '/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/uniFiAP.indigoPlugin/Contents/Server Plugin/test.exp' uuid pwd 192.168.1.60
spawn ssh karl@192.168.1.60
karl@192.168.1.60's password:
Welcome to Ubuntu 16.04.4 LTS (GNU/Linux 4.15.0-34-generic x86_64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
115 packages can be updated.
5 updates are security updates.
New release '18.04.1 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
*** System restart required ***
Last login: Wed Oct  3 20:21:22 2018 from 192.168.1.50
the plugin looks for strings like "login" "welcome" in the complete text.lower() you see.
so does it work for you now?
Thu Oct 04, 2018 10:14 am
stevenu offline
<grin>
Debian is now polite as Ubuntu. . . The header message is written by a lawyer I think;
"The programs included with the Debian GNU/Linux system are free software;
permitted by applicable law."
Thu Oct 04, 2018 11:08 am
stevenu offline
Like pealing an onion. . .
I have my password in quotes, The '$' seems to upset something.
Added welcome and login to the top of /etc/motd
" welcome login
individual files in /usr/share/doc/*/copyright."
At this point all of the error login messages have stopped and I see the cameras but their state doesn't look good. . .
Screen Shot 2018-10-04 at 10.01.04 AM.jpg (104.06 KiB) Viewed 2331 times
Thu Oct 04, 2018 2:22 pm
yes the $ is used by EXPECT as variable indicator. Don't know how to escape that.
grey off means it is not recording, that is correct
red rec = recording
can you switch on debug for camera in config?
ps:
I have commands almost ready :
set motion or full-time recording on / off
can do
="recordingSettings": {"postPaddingSecs": 10, "fullTimeRecordEnabled": false, "prePaddingSecs": 10, "motionRecordEnabled": true, "channel": "2"}
='enableStatusLed':False,
="enableSpeaker":False,
channel is 0/1/2 resolution
looking for some other useful settings
Thu Oct 04, 2018 3:46 pm
stevenu offline
Oh. . .
Here is a short run of the debug log for the video. It is a little embarrassing the size of this network. I tried to limit it.
Next step is how to get images and then onto a Control Page. . .
UniFi.log
(12.38 KiB) Downloaded 129 times
Fri Oct 05, 2018 9:21 pm
this looks as if you are getting events... but always the same
I have worked a bit on this release:https://www.indigodomo.com/pluginstore/73/ v.129
if you could try that one.
Besides adding debian as one of the tags for login to unix box , control of cameras was added.
You now can start stop recording as well as switch on/off LED, IR, speaker mic .. in the menu as well as in action items
missing eg start streaming and some other functions. Not all cameras allow eg IR to be switch on/ off. although the camera takes it it does not switch on/off for some models.
the plugin will create a device for the NVR and store the apiKey in that device. Same for the cameras.
You only need to supply the userid/passwords for the NVR web and UNIX login. There is a refresh option in the menu for these keys and names ... It will automatically refresh every 15 minutes on its own and when you load the plugin.
this release seems to work, but not intensively tested
Sat Oct 06, 2018 9:23 pm
stevenu, please try the new release ... .130
