Blocked/unblocked status
Sat Sep 22, 2018 5:12 am
mat offline
Re: Blocked/unblocked status
Hi Karl,
Plugin version is 7.20.125
Comms to the device are enabled in indigo. the device is physically off, but the same happens with my iPhone.
Switched check blocked off in the plugin config, and restarted
Switched check block onto 60 seconds in plugin config and restarted.
Anything else i can provide?
Sorry
Late 2018 mini 10.14
Sat Sep 22, 2018 9:57 am
could you download this version (same v #) and enable special debug. then post the output of a cycle for lines with "checkForBlockedClients"
https://www.dropbox.com/s/lrbkt6hvh3qbokz/uniFiAP.indigoPlugin.zip?dl=1
like these:
10:56:22 checkForBlockedClients   -data[0:200]: [{u'oui': u'Apple', u'is_wired': False, u'name': u'iphone Karl', u'rx_bytes': 135656406533, u'network_id': u'5750f2bae4b04dab3d3d0d54', u'usergroup_id': u'', u'fixed_ip': u'192.168.1.93', u'hostname':
10:56:22 checkForBlockedClients   -client: {u'oui': u'Apple', u'is_wired': False, u'name': u'iphone Karl', u'rx_bytes': 135656406533, u'network_id': u'5750f2bae4b04dab3d3d0d54', u'usergroup_id': u'', u'fixed_ip': u'192.168.1.93', u'hostname': u'iPhone', u'site_id': u'5750f2ade4b04dab3d3d0d4f', u'rx_packets': 207106196, u'tx_bytes': 230892873381, u'last_seen': 1537627044, u'mac': u'1c:36:bb:97:c0:85', u'use_fixedip': True, u'duration': 27996999, u'is_guest': False, u'first_seen': 1515188164, u'_id': u'5a4fefc4e4b0b9db03902d97', u'tx_packets': 223663430, u'noted': True, u'blocked': False}
10:56:22 checkForBlockedClients   -client: {u'oui': u'HewlettP', u'is_wired': True, u'name': u'hp-ink', u'rx_bytes': 2557249, u'network_id': u'5750f2bae4b04dab3d3d0d54', u'fixed_ip': u'192.168.1.43', u'hostname': u'HPBF51A1', u'site_id': u'5750f2ade4b04dab3d3d0d4f', u'rx_packets': 29185, u'tx_bytes': 1061542, u'last_seen': 1537580677, u'mac': u'2c:76:8a:c8:5b:c9', u'use_fixedip': True, u'duration': 877155, u'is_guest': False, u'first_seen': 1465351667, u'_id': u'57577df4e4b0e87e4d51b358', u'tx_packets': 18092, u'noted': True, u'blocked': False}
10:56:22 checkForBlockedClients   -client: {u'oui': u'Raspberr', u'is_wired': False, u'name': u'rpi-zero-36', u'rx_bytes': 7513575965, u'network_id': u'5750f2bae4b04dab3d3d0d54', u'fixed_ip': u'192.168.1.36', u'hostname': u'raspberrypi', u'site_id': u'5750f2ade4b04dab3d3d0d4f', u'rx_packets': 257643494, u'tx_bytes': 364894325, u'last_seen': 1535527945, u'mac': u'b8:27:eb:ed:a5:3e', u'use_fixedip': True, u'duration': 5001898, u'is_guest': False, u'first_seen': 1468819287, u'_id': u'578c6758e4b07e6d2836404c', u'tx_packets': 3479050, u'noted': True, u'blocked': False}
10:56:22 checkForBlockedClients   -client: {u'oui': u'Microchi', u'is_wired': True, u'name': u'mother M3 Karry Lisbeth', u'network_id': u'5750f2bae4b04dab3d3d0d54', u'fixed_ip': u'192.168.1.63', u'hostname': u'MOTHER         ', u'site_id': u'5750f2ade4b04dab3d3d0d4f', u'use_fixedip': True, u'last_seen': 1517326613, u'mac': u'00:1e:c0:e7:4d:38', u'is_guest': False, u'first_seen': 1465355538, u'_id': u'57578d13e4b0e87e4d51b3f2', u'noted': True, u'blocked': False}
10:56:22 checkForBlockedClients   -client: {u'oui': u'Private', u'is_wired': True, u'network_id': u'5750f2bae4b04dab3d3d0d54', u'fixed_ip': u'192.168.1.81', u'site_id': u'5750f2ade4b04dab3d3d0d4f', u'use_fixedip': False, u'last_seen': 1510190679, u'mac': u'10:00:00:28:54:be', u'is_guest': False, u'first_seen': 1467107272, u'_id': u'577247c9e4b0eeb7e3f8f85b', u'noted': False, u'blocked': True}
10:56:22 checkForBlockedClients   -listOfBlockedClients: {u'10:00:00:28:54:be': True, u'00:1e:c0:e7:4d:38': False, u'2c:76:8a:c8:5b:c9': False, u'1c:36:bb:97:c0:85': False, u'b8:27:eb:ed:a5:3e': False}
10:56:22 checkForBlockedClients   -UniFi-hp-printer 2c:76:8a:c8:5b:c9  False  False
10:56:22 checkForBlockedClients   -UniFi-rpi-36-zerow b8:27:eb:ed:a5:3e  False  False
10:56:22 checkForBlockedClients   -UniFi_Karl_iPhone 1c:36:bb:97:c0:85  False  False
Sat Sep 22, 2018 10:16 am
and is this
Screen Shot 2018-09-22 at 11.15.42.png (42.64 KiB) Viewed 1346 times
ON?
Sat Sep 22, 2018 1:00 pm
mat offline
Will do karl. Thanks for your help. Away for the evening but will try tomorrow evening.
Sun Sep 23, 2018 12:01 pm
mat offline
Karl,
Really embarrassed and thanks for your help - it was the report settings was "on reports only". sorry had left it on the default.
I owe you one.
And thanks as always for the great support.
Regard
Mat
Sun Sep 23, 2018 12:27 pm
Good to hear
I had set my Postgres dB set to Canada eastcost time. And thought it was indigo.
Must have been some “400 pounds “ Canadian hacker on his sofa
