Blocked/unblocked status
Thu Sep 20, 2018 3:29 pm
mat offline
Karl,
Thanks for the plugin - it seems to be working splendidly!
I'm just playing around with it for the first time tonight. Loving the idea of being able to quickly block and unblock the kids. Is there any chance of adding the block/unblocked to the status list please? Suggest blocked = true/false?
No problem, if its a problem, and keep up the great plugin work!
Cheers
Mat
Late 2018 mini 10.14
Thu Sep 20, 2018 8:52 pm
Re: Blocked/unblocked status
Will check
Thu Sep 20, 2018 10:42 pm
can be done..
command ex :
/usr/bin/curl --insecure -c /tmp/cookie   --data '{"username": "xxx", "password": "xxx"}' https://192.168.1.9:8443/api/login
then
/usr/bin/curl --insecure -b /tmp/cookie  -X PUT https://192.168.1.9:8443/api/s/default/stat/user/2c:76:8a:c8:5b:c9
for eg device w mac#2c:76:8a:c8:5b:c9
challenge: this is data from the controller not fro any of the unifi devices that are queried regularly. if we want to do this for all devices this might create some load
this will also give some info .. but a large dump .. also on blocked/unblocked devices:
/usr/bin/curl --insecure -b /tmp/cookie  -X PUT https://192.168.1.9:8443/api/s/default/list/user/
what would be the update frequency that makes sense? This is not pushed from the controller, but must be pulled. we could query the db once/ minute or so..
still thinking about it
Thu Sep 20, 2018 11:14 pm
mat offline
Hi karl
That’s great will have a play tonight. Thank you.
I would say once every minute and probably for 10 devices. Once every 30 seconds would be even better.
The use case is to take the kids internet control into a wife friendly control page.
Fri Sep 21, 2018 8:11 am
have a version ready with dev.state["blocked"] with a boolean value true/false.
runs once a minute and seems to be performing.
will let it run for a while and then post
Fri Sep 21, 2018 8:27 am
mat offline
Karl,
You are a superstar! Thank you.
Fri Sep 21, 2018 8:48 am
Tell my w!!
Fri Sep 21, 2018 9:04 am
mat offline
I know that feeling, I installed unifi on Wednesday and have had three very late nights tinkering - mine just doesn't understand the benefits hahaha
Fri Sep 21, 2018 9:31 am
posted v7.20.124 with the (un) blocked feature.
you can select update frequency in config 20...120 secs or off
also added : first seen and use fixedIP dev states... updated once/ hour
Fri Sep 21, 2018 12:26 pm
mat offline
Karl,
Will test tonight, thanks so much. You might have made the other 1/2 very happy!
Thank you.
Mat
Fri Sep 21, 2018 5:11 pm
mat offline
Hi Karl,
Just installed, and I can see the blocked status, but doesn't appear to be updating the status for "blocked". Both blocked and unblocked devices are showing false.
I can set the blocked and unblocked from indigo and thats working fine.
I have switched, key and AP's, but no USG for your info
Mat
Fri Sep 21, 2018 7:21 pm
first it takes a minute or so to propagate from setting blocked to seeing blocked.
second could you run at the report ""print & get ../Print all user info. it should look like this:
00:55:08 unifi-Report             -
00:55:08 unifi-Report             -== ALL USER report ==
##  mac               hostname             name                 first_seen           last_seen            vendor    fixedIP         us_f-ip wired blckd guest  durationMin       rx_KBytes     rx_Packets       rx_KBytes     tx_Packets
1   b8:e8:56:42:69:fe laptop-II                                 2018-02-25 21:17:45  2018-09-21 00:23:41  Apple     192.168.1.58    True    True        False       49,772       4,611,292     22,085,589      41,257,347     32,718,984
2   f0:9f:c2:d8:df:2f                                           2018-08-11 16:27:33  2018-09-21 00:12:48  Ubiquiti                          True        False           21               0              0               0              0
3   f0:f6:1c:d5:51:16 iPad                 ipad-mini            2016-06-03 00:28:00  2018-09-21 00:12:42  Apple     192.168.1.95    True    False       False      927,424     115,752,108    603,397,330   1,005,472,928    802,893,611
4   2c:76:8a:c8:5b:c9 HPBF51A1             hp-ink               2016-06-07 21:07:47  2018-09-20 23:32:46  HewlettP  192.168.1.43    True    True  False False       13,388           2,257         26,411             926         16,365
5   18:65:90:6a:b9:0c kristins-iPhone      iphone Kristin       2016-10-05 21:02:01  2018-09-20 20:42:14  Apple     192.168.1.94    True    False       False      657,014     215,654,572    359,166,870     360,428,144    348,514,709
6   1c:36:bb:97:c0:85 iPhone               iphone Karl          2018-01-05 15:36:04  2018-09-20 17:32:33  Apple     192.168.1.93    True    False False False      464,820     132,208,516    205,982,426     223,353,412    222,530,303
7   b8:27:eb:5c:0d:c6 clock_1              rpi-38-zero          2017-06-07 19:07:56  2018-09-20 09:07:21  Raspberr  192.168.1.38    True    False       False        9,906          85,755        641,051          52,711        896,961
you should see some in the blocked column with true. If not there will be no blocked=true states in the devices. .. If yes, i need more info
Fri Sep 21, 2018 7:48 pm
found the bug.. it work only at start of plugin. the time window check was wrong . new version is posted
Sat Sep 22, 2018 2:01 am
mat offline
Hi Karl,
Thanks for the update, unfortunately still not showing in the Custom State Panel.
This is after waiting around 10 minutes just to make sure:
Extract of the requested below. (no 16) is blocked = true
Screenshot of Indigo Custom State for same showing custom state as being false. It looks like the first report is picking the "blocked" status up correctly, but the custom state in indigo is not changing.
mat
Screen Shot 2018-09-22 at 08.59.20.png (103.22 KiB) Viewed 3215 times
Screen Shot 2018-09-22 at 08.55.32.png (47.23 KiB) Viewed 3215 times
Sat Sep 22, 2018 2:38 am
Is the device enabled? That’s another it does
Mine works fine Tested several times.
Do you have the right version? May be I uploaded an old one.
