new plugin installed and enabled - no configuration option
Sat Sep 15, 2018 10:57 pm
odavis offline
subject says it all. can't configure the plugin. 7.19.122 running on latest version of indigo on macOS 10.10.5
plugin attempts to run and then stops. only options for plugin menu are "disable", "reload" and "about"
event log pasted below. the IP address referenced is not on my network or the indigo host.
any hints appreciated.
I've manually uninstalled / reinstalled plugin.
Loading plugin "uniFiAP 7.19.122"
Starting plugin "uniFiAP 7.19.122" (pid 82763)
uniFiAP Error Error in plugin execution InitializeMain:
SyntaxError: ('invalid syntax', ('plugin.py', 3579, 36, ' self.broadcastIP = 192.168.1.255\n'))
Stopping plugin "uniFiAP 7.19.122" (pid 82763)
Stopped plugin "uniFiAP 7.19.122"
Sun Sep 16, 2018 1:35 am
mat offline
Re: new plugin installed and enabled - no configuration opti
Have you tried:
Disable plugin
Delete the config file for this plugin (in folder indigo x\Preferences\plugins) Karls usually start com.karlwachs.xxxxx....indiPref
Restart plugin
Late 2018 mini 10.14
Sun Sep 16, 2018 4:25 am
That’s a bug. Will post a fix later today.
Sun Sep 16, 2018 8:49 am
should be fixed in v.7.19.123
Sun Sep 16, 2018 10:57 am
odavis offline
Thanks. New version fixed It immediately.
