With the 2 more children about to come in a few weeks we definitely need to be able to support a more devices in a few years but 20k is pushing it, unless they've thrown an insane party.
I've lots of old plugin devices created with duplicates of online ones
kw123 wrote:I've lots of old plugin devices created with duplicates of online ones
that should actually not happen.
A new device should only be created when the MAC number of a device is new/different, not when any other property changes ie not when the IP# changes.
if you have 2 devices with the same MAC number PLEASE let me know. I would like to understand how that can happen
try: # normal creation
dev = indigo.device.create(
protocol=indigo.kProtocol.Plugin,
address=MAC,
name=devName + u"_" + MAC,
description=ipx + u"-" + nameCl+"=Wifi",
pluginId=self.pluginId,
deviceTypeId=devType,
folder=self.folderNameCreatedID,
props={u"useWhatForStatus":u"WiFi", u"useWhatForStatusWiFi":u"Expiration",isType:True})
except Exception, e:
if len(unicode(e)) > 5:
indigo.server.log(u"in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
try: # if device not successfully created try to create it again but with random number added
devName += u"_"+( unicode(time.time() - int(time.time())) ).split(".")[1] # create random name
indigo.server.log(u"trying again to create device with differnt name "+devName)
address=MAC,
continue
siclark wrote:kw123 wrote:I've lots of old plugin devices created with duplicates of online ones
Sorry I've deleted everything. But in short I had the plugin running only using access points but then bought a USG. In between getting everything set up correctly I moved the APs around between several different cloud controllers and they changed IP address several times so I had to keep updating the plugin. Plus I think I've changed physical AP is AP1, 2, 3 etc on the plugin. Also changed all the static IP address or device. But as you say, no MAC changes obviously.
Maybe I imagined it but sure I saw 2 rows for my phone, one showing inactive for 4 days. The other one as UP.
Anyway, nice opportunity to start from fresh.
