Bonjour over VPN?
Thu Jul 19, 2018 10:24 am
Different Computers offline
Bonjour over VPN?
Hey, I know this isn't the focus here, but I can't imagine anywhere that has a greater concentration of people who would want to do this with Unifi equipment.
I've upgraded from my crapstastic CenturyLink modem/router combo to transparently bridging it and using a USG. It's working great, and so many super powers!
I've even successfully set up the USG as a VPN server, and have that working fine, except for one thing: Bonjour/Zeroconf is not making it from my "corporate" LAN to my VPN. When I'm remote and connected to the VPN, I can access anything I want that's on my LAN by IP address, but nothing appears, for example, in the Finder sidebar for Devices, and I can't surf to .local web addresses.
I've turned on mDNS, and I've scoured the Unifi boards, and I can't find instructions on how to fix this. Has anyone here gotten this working with a similar configuration?
My setup is
DSL Modem > USG > Dumb Switch > Unifi Wifi AP
And Karl, just saying again: I wouldn't own a single piece of Ubiquiti equipment if it wasn't for your Indigo plugin! Now I'm going to roll it out for our remote work site too.
Thu Jul 19, 2018 11:09 am
Re: Bonjour over VPN?
I'm led to believe that it's possible to configure Bonjour to work over VPN, but I've not had a need so I never looked into it. For the things that I do which would normally rely on Bonjour, I just access the protocol directly [EDIT: when on VPN]. This may not work for everything that you're looking to do.
From within Finder, select 'Go' and then 'Connect to Server'.
smb://192.168.1.1
afp://192.168.1.1
vnc://192.168.1.1
You can save these links in that dialog to make life a little bit easier.
As a side note, in later versions of OS X, I've found SMB to be more stable than AFP (even when home). For example, to run iTunes off a NAS-based iTunes library, I map to the NAS using SMB and it works every time. Using AFP, it might work 10 percent of the time--if that.
So, not a direct answer to your question, but perhaps a reasonable workaround.
Thu Jul 19, 2018 11:56 am
found this: "If you use a L2 VPN setup, then broadcasts like mDNS should work just fine as long as VPN clients are on the >>>>same subnet <<<<< as everything else."
and in USG vpn needs to run on a different subnet... I have internal 192.168.1.x and vpn is 192.168.2.x...
and UniFis vpn is not layer 2
when I was using the OSX vpn solution (which apple turned off in in upgrade :evil: ) it was working, the MAC used 192.168.1.250..255 for VPN which was also part of the internal network
(and my att router is 192.168.0.x, need to do double netting )
Mon Jul 23, 2018 12:59 am
rhanson offline
If you are using L2TP, I think you should add "l2tp0" as an interface on the mDNS repeater. That will do it even if subnets are different.
But this assumes that you have only 1 class of remote user, and they should see everything. Also, if you have multiple simultaneous connections, you will have interfaces l2tp0, l2tp1, etc. created when a new vpn session is established.
I read on the ubnt boards that you can use "l2tp+" as a wildcard for any l2tp interface. You'll need to do this from the command line because it will be rejected as invalid from the EdgeRouter gui (and I don't believe you can even get to this from UniFi gui).
set service mdns repeater interface l2tp+
You might need to use vtun0, tun0, etc. depending on how your network is set up. Basically, get the dynamically-created interface into the mDNS repeater config.
Disclaimer: I am not a network guy, and am only repeating what I've read elsewhere. So, in other words, perfectly dangerous! :-) But I find my ubnt gear to be awesome.
Mon Jul 23, 2018 8:31 am
This must be where the edge of my knowledge is a cliff I fall off.
Trying that lt2p+ command in the USG results in an error.
