USG as Indigo Device blocking management?
Sun Jul 15, 2018 12:10 pm
Different Computers online
So this is weird, and it may well be just because I'm brand new with this USG--It has been up and running for less than an hour, and it is the first one I've ever configured.
I was in the midst of doing a upgrade to the USG via the Unifi app/web page, and I went ahead and configured the USG portion of the Unifi-AP plugin, and that's not generating any errors. I was also able to log in to the USG via its IP address, but now that the Indigo plugin is configured, I can neither manage it via the Unifi app, nor log in.
Is it maybe just half stuck after the upgrade? Seems like not, because in the middle of typing this other networking things went south, and I tried disabling the USG portion of the indigo plugin, then immediately the Unifi app listed the USG as "Provisioning" instead of "Disconnected."
Any insights?
Sun Jul 15, 2018 1:22 pm
Re: USG as Indigo Device blocking management?
When you mess around with the USg you should disable the UniFi plugin as it connects to the usg - logged in via ssh. That might disrupt the upgrade.
I had no problem so far having the plugin running while upgrading. But you never know.
Sun Jul 15, 2018 2:55 pm
Seems like things have settled down, but I may try it again in a bit.
What big features do I gain from adding the USG to Indigo?
Sun Jul 15, 2018 6:01 pm
Some reports on network config
And it automatically discovers and adds new UniFi devices.
And some other stuff ... need to check.
In cinema
Sun Jul 15, 2018 8:39 pm
movie: "1945" from hungary .. very depressing, but honest movie. strongly recommended
Adding USG to the scope:
if you use DHCP on the USG :
gets DHCP data for clients (shows uptime , age of last IP info ). useful for expiration/connection time for regular devices
and if new client joins creates new indigo device
GW info:
Screen Shot 2018-07-15 at 21.35.17.png (39.07 KiB) Viewed 1310 times
this
"Some reports on network config
And it automatically discovers and adds new UniFi devices. "
was for the controller . If the controller is included you get these reports and you can block clients and some other functions.
