Event Log Error
Wed May 30, 2018 9:12 am
dkillmer offline
Event Log Error
This is a wonderful plug-in and the most effective at determining when we are home.
I am getting the following error in the event log on a regular basis and I am not sure if there is something I should do.
uniFiAP in Line '4557' has error='unsupported operand type(s) for -: 'int' and 'unicode''
Thu May 31, 2018 5:31 am
Re: Event Log Error
Which version are you using?
Sun Sep 09, 2018 3:58 pm
dnomode offline
Re: Event Log Error
Great plugin, thanks.
Im getting the following error:
 in Line '5967' has error='coercing to Unicode: need string or buffer, list found'
Im on 7.18.120. What am I missing?
Thank you
Edmond
Sun Sep 09, 2018 5:17 pm
Re: Event Log Error
fixed in .121,
was not properly tested , should be ok now
Sun Sep 09, 2018 5:38 pm
dnomode offline
Re: Event Log Error
Wow, your awesome.
Sun Sep 09, 2018 6:07 pm
dnomode offline
Re: Event Log Error
Hello Karl,
I've got another error
  uniFiAP Error                   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
I noticed this error with the last version .120
I only saw it once and it went away.
What you think?
Edmond
Sun Sep 09, 2018 8:54 pm
Re: Event Log Error
if it does not repeat .. don't know what to do
Thu Sep 13, 2018 12:48 pm
DrLove offline
Re: Event Log Error
for me it does come back, every 10 seconds :)
uniFiAP Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 3650, in runConcurrentThread
IndexError: list index out of range
Never had this working (installed today) I might have done something wrong w/ setup :/ Or unicode error (I live in sweden).
EDIT: Never mind, my bad. It works now. I had to put in the IP of my APs, it did not find it automatically (from the cloud key) for some reason.
Best regards, L
Love Kull (yes it's my name)
Blog (in Swedish)
Sweden
Thu Sep 13, 2018 2:41 pm
Re: Event Log Error
should be fixed in v .122
Tue Oct 02, 2018 8:54 pm
dkillmer offline
Re: Event Log Error
I am running v. 7.21.126 and the plug-in does exactly what I want it to do, but I get the following error in the event log often. Any thoughts?
uniFiAP in Line '5066' has error='unsupported operand type(s) for -: 'int' and 'unicode''
Tue Oct 02, 2018 9:27 pm
Re: Event Log Error
are you using the camera NVR feature?
if not: switch of the camera userid ( set to "" ) in config
if yes: try to reset the event count
will added a check for that
adding some more reporting for cameras AND adding commands like start recording/ stop recording .. enable /disable recording
Tue Oct 02, 2018 9:45 pm
dkillmer offline
Re: Event Log Error
Thanks, Karl!
I was not using the video option and I had to remove the IP address of my NVR to prevent the event log error.
This plug-in is the most reliable method that I have found in Indigo to determine if we are home or away.
Thanks again!
Tue Oct 02, 2018 9:58 pm
Re: Event Log Error
ok that can explain it .. if ip is defined.. do the camera things ..
