added new version 7.15.110 in plugin store
https://www.indigodomo.com/pluginstore/73/ & GitHub
https://github.com/kw123/unifiActions / settings options:For UniFi system devices1. switch PoE ports on/off/powercycle (either through switch#, port # or selecting the UniFi client)
2. suspend a UniFi system device: it will make the plugin ignore any message, status changes from the unifi system device, will set status to “susp”
3. disable / enable UniFi AP. will do same as in controller /Config/managedevice/disable-enable, will also set the indigo device to suspended
4. reboot a UniFi device
5. set LEDs on AP devices on/off/blink
For clients:1. block / unblock access for a regular device / client
2. reconnect a wifi client
For NVR / camera system and Virtual box running NVR system1. start vmbox
2 stop vmbox
3. backup VM disk
4. compress vm disk
5. (re) mount video disk on vmbox
6. start NVR system on unix box
7. stop NVR system on unix box
