Re: uniFi WiFi AP: download
Posted: Mon Jun 13, 2016 11:32 am
posted v 0.8.6
fixed
- timing of reconnect and connect to the AP was not done properly ( too often)
- For the APa we don't do a login to test if the device is up, but the AP will send an alive messages every time it reads the DICT via the log file listener. This will also make sure that the log file rotation (hen a log file is to big a new log file gets started and the tool tail -f does not work with renamed files (( tail -F is not available on the APs)) )
- Some error debugging itself had problems
added
if you change a parameter (in config) that requires a restart the plugin will do that automatically now. This is required to reset / set the threads that listen to the AP GW messages properly. Doing that inside the plugin is a bit of programming.
fixed
added
