Control camera IR
Sun Nov 04, 2018 12:01 pm
lochnesz offline
Re: Control camera IR
It is a Ubiquiti hardware NVR
[code]root@UniFi-Video:~# uname -a
Linux UniFi-Video 3.18.26-ubnt #1 SMP Fri Jan 29 09:21:00 UTC 2016 x86_64 GNU/Linux/code]
I am not following, where do I change to "request"? I looked in the plugin, and probably it is right before my eyes, but I don't see where to make the change.
Sun Nov 04, 2018 12:11 pm
in config:
Screen Shot 2018-11-04 at 12.09.08.png (20.46 KiB) Viewed 2213 times
and could you try in a terminal window:
/usr/bin/curl --insecure -c /tmp/nvrCookie --data '{"username": "xxx", "password": "xxx"}' https://192.168.9.35:7443/api/login
with your userid and password for the NVR unix box
and could you do a sys update on the unix box?
karl
Sun Nov 04, 2018 12:47 pm
lochnesz offline
I thought that the controller info was for the USG, so I disabled that during these tests. However, the IP address there is for the USG.
I changed to python requests, but it doesn't work, I get this message.
4 Nov 2018 at 19:42:42
   Action Group                    carport ir off
   uniFiAP                         in Line '1451' has error='[Errno 1] _ssl.c:499: error:140773F2:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert unexpected message'
   Connection                      in Line '3711' has error='[Errno 1] _ssl.c:499: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol'
I am thinking about removing all config and starting from the beginning with new config. Do I need to configure a USG controller in the plugin if I only want to test Unifi Video? I have a USG, but I was thinking of having a clean config just to get the NVR working first.
Sun Nov 04, 2018 12:57 pm
that error message seems to be kind of the same problem. SSL on the NVR box is different or on your MAC
Which OSX are you running ?
it should work w/o the controller
Sun Nov 04, 2018 1:01 pm
lochnesz offline
I am on 10.7.5. I will move to a newer Mac soon, I can't run a newer OS on this hardware. Just need to find the time...
So my MacOS release might be the problem?
Sun Nov 04, 2018 1:18 pm
well it might be both ...
10.7 only supports open SSL v 1.0.x (which is used by the installed python/requests) .. newer web servers require higher level SSL.. thats why I added cURL.
try: curl -V to get the installed cUrl version
If you have a newer MAC / laptop ( eg sierra) try
there . If that works its the MAC if not its the NVR
you might want to reinstall curl (a newer version .. comes with its own SSSL libs) on you mac : https://simonecarletti.com/blog/2016/01/http2-curl-macosx/ but that will install cURL in /usr/local/bin/curl .. but we can add that option to point there
when / if you have installed a newer version of curl try:
/usr/local/bin/curl--insecure -c /tmp/nvrCookie --data '{"username": "xxx", "password": "xxx"}' https://192.168.9.35:7443/api/login
Sun Nov 04, 2018 3:00 pm
lochnesz offline
You are correct, I only get the error with the old MacOS. I tried to install a new version of curl but ran into an error when the dependency cunit was about to download.
==> Installing curl dependency: cunit
==> Downloading https://downloads.sourceforge.net/project/cunit/CUnit/2.1-3/CUnit-2.1-3.tar.bz2
curl: (35) Unknown SSL protocol error in connection to downloads.sourceforge.net:443
Error: Failed to download resource "cunit"
Download failed: https://downloads.sourceforge.net/project/cunit/CUnit/2.1-3/CUnit-2.1-3.tar.bz2
I am not sure what to do about it.
I think I will make the Indigo move to my new Mac instead, now I know that it will probably work fine with UniFiAP one I have made the move.
Thanks for all your support!
Sun Nov 04, 2018 3:19 pm
so you even can not download (w ssl) any new software !!! .. yes I guess then its time to go to new hw/opsys
Sun Nov 04, 2018 5:37 pm
last thing you could try is to copy the curl executable from your laptop to /usr/bin/curl on your indigo mac (make a copy first) ..
then try it again
if it is self-contained it might work .. if it calls on other libs likely not
Wed Nov 07, 2018 1:08 pm
lochnesz offline
I installed it on my newer Mac, and I can now control the IR on my cameras :D
I do get some error messages on plugin start, what can be causing these errors?
Starting plugin "uniFiAP 7.25.143" (pid 9394)
   uniFiAP                         setting parameters for indigo version: >>7<<
   Started plugin "uniFiAP 7.25.143"
   uniFiAP                         initializing    ... variables
  deleted...
   uniFiAP                         initialized ... looping
Wed Nov 07, 2018 5:16 pm
have you set the site name? .. default is "default" ....
switch on debug for (6) I believe , you then should see the complete connect string (then do print/ get info ... first item thats the same command that is executed at the beginning )
Screen Shot 2018-11-07 at 17.15.50.png (14.95 KiB) Viewed 2117 times
Screen Shot 2018-11-07 at 17.13.56.png (18.15 KiB) Viewed 2117 times
Sun Nov 11, 2018 8:05 am
lochnesz offline
The site matches with NVR and Indigo config.
What do you mean by
What option should I chose?
Another thing that I noticed is that two cameras that I have removed from the Unifi NVR shows up as cameras in Indigo. Is that correct?
Screenshot 2018-11-11 at 15.01.06.png (231.39 KiB) Viewed 2056 times
Sun Nov 11, 2018 8:15 am
Control camera IR
Click on to top / first button “get ....
Deleting cameras on the nvr web page does not delete cameras from its internal dB. So when indigo gets the dB dump the deleted cameras are still there.
I have moved an old camera to a junk folder.
Have not figured out how to jd deleted caneras.
Karl.
Sun Nov 11, 2018 8:34 am
lochnesz offline
Ah, I see. I am sending you the output as a PM.
The thing is that everything works as far as I can see, it is just that the error message appears quite frequently in the log. Maybe something isn't working that I haven't noticed?
Sun Nov 11, 2018 10:42 am
you have 3 IDs defined on the NVR, one has a apiKey disabled. -see >>>> <<<<<
This one has access disabled and very little other things enabled
{u'enablePush': True, u'enableEmail': True, u'userGroupId': u'xx', u'disabled': False, u'sysDisconnectPushAlert': True, >>>>u'enableApiAccess': False, <<<<<u'enableLocalAccess': True, u'adoptionKey': u'TypdrChV', u'_id': u'xx', u'sysDisconnectEmailAlert': True, u'motionAlertSchedules': {}, u'accountId': u'xx'},
these are ok , but do you need 2?
 {u'sysDisconnectPushAlert': True, u'mobileKey': xx', u'apiKey': xx', u'enableEmail': True, u'userGroupId': u'xx', u'subscribedCameraConnection': [u'xx', u'xx', u'xx'], u'disabled': False, u'enablePush': True, u'enableApiAccess': True, u'enableLocalAccess': True, u'motionAlertSchedules': {}, u'_id': u'xx', u'sysDisconnectEmailAlert': True, u'adoptionKey': xx', u'accountId': u'xx'},
 {u'sysDisconnectPushAlert': True, u'apiKey': u'xx', u'enableEmail': False, u'userGroupId': u'xx', u'disabled': False, u'enablePush': True, u'enableApiAccess': True, u'enableLocalAccess': True, u'motionAlertSchedules': {}, u'_id': u'xx', u'sysDisconnectEmailAlert': True, u'adoptionKey': xx', u'accountId': u'xx'}]
I am adding an " if not enableApiAccess:" to skip these IDs
I was trying to catch apiKey not defined.
look at it as a warning for now, not an error, will suppress if not debug video enabled in next release
