I am attempting to change the Performance Options from Realtime Device Updating to Periodic Polling but every time I try to save it, I get a "Communication with the plugin timed out" box and a "Error validating fields. Hover over the red field labels above to see the error reason" message in the bottom left corner of the window. The only available fields are Interval and Frequency and neither are red.
I need to set it to periodic polling (every 15 seconds) because I am mainly using the plugin to calculate elapsed minutes since last weather observation time. The issue I am running into with it set to realtime updating is that the elapsed time is always 0 minutes after it updates unless I reload the plugin. I want to use the elapsed time as part of a weather announcement ("Weather data was last updated XX minutes ago"); I prefer it in relative terms vs telling me the actual last observation time since I'm more interested in how long since the last update vs an exact time of day.
