Bug? base64 required for authentication
Tue Nov 17, 2020 4:08 pm
boisy offline
I ran across an error using a URL Extension device in this plugin with authentication. I need to add the following line at the top of the plug.py file:
import base64
After that, the authentication worked.
Tue Nov 17, 2020 4:41 pm
boisy offline
Re: Bug? base64 required for authentication
I found two more issues in plugin.py for this plugin:
1. For my application, I need to read the result of the urllib2.open() in _updateURL():
            ret = urllib2.urlopen(url)
         res = ret.read()
         indigo.server.log(unicode(ret))
So I added the "res = ret.read()" line. Without this, my Arduino code would lock up. I don't expect this will hurt anything in any case, and should be added.
2. There's a bug on line 567 of the onDevicecommandTurnOff() function:
            if self.urlDeviceAction (dev, dev.pluginProps["onCommand"]) == False:
That array subscript should be "offCommand".
With these two fixes and the base64 in the first message, this plugin works fine for me now.
Mon Jan 04, 2021 2:50 pm
boisy offline
No one seems to be responding to this feedback. Is the developer active?
I found what I think is another issue with this plugin.
Line 770 in plugin.py is:
            ret = urllib2.urlopen(ret, url)
The second parameter should not be there. Instead, the line should read:
            ret = urllib2.urlopen(ret)
Mon Jan 04, 2021 2:59 pm
Colorado4Wheeler has left the Indigo world and is not supporting any Indigo plugins going forward. He said (on GitHub) that he would be open to developers taking over the Indigo plugins and is willing to transfer the repos.
Mon Jan 04, 2021 3:58 pm
boisy offline
I just caught up on his departure from another post. Thanks for alerting me to this.
FlyingDiver expressed some interest in fixing bugs in this very plug-in. That would be a great start.
