New Plugin: FreePBX
Fri May 01, 2020 7:01 am
raoul offline
Re: New Plugin: FreePBX
Following further investigation, I found that part of my problem had been the lack of a module; Follow Me (not one I've ever had cause to use over the years). Anyway activating this caused another error with the php.
Long story short, I'm at a brick wall now of;
Error (client) illegal state key onOffState defined by plugin -- native state keys cannot be overridden (ignoring)
I don't seem to be able to find the underlying problem. As such I'll just have to put it down to an incompatibility with RestAPI 15 unless anyone else can confirm they've had it working.
A shame, what I was really after was to have call forwarding based on Geo location, handled by Indigo.
Fri May 01, 2020 8:00 am
Sorry, forgot about this thread.
I’ll look shortly.
Peter
Fri May 01, 2020 12:59 pm
Ok.
Two changes you need to make.
One - replace all occurances of "onOffState" throughout plugin.py and Devices.xml with "onOff_State".
Two - change line 88 in plugin.py from:
      server = indigo.devices[1644005444] # "PBX - House"
to
      for s in indigo.devices.iter("self.Server"):
         server = s #Assuming there's only one server, pick it
Make sure the indents are tabbed correctly.
That should sort out the inherent errors.
Peter
Fri May 01, 2020 1:23 pm
I've uploaded fixed version to my github.
https://github.com/howartp84/FreePBX/releases/tag/1.0.1
It also handles a non-existent Server (ie when a user first installs).
@Jay @Matt do you want to try contacting @C4W or do you want to swap the plugin store to mine? (Or remove it and I'll push it to store)
Peter
Tue May 05, 2020 4:57 am
raoul offline
Thanks so much for that. Unfortunately that's still not really working for me. The Follow Me plug-in kicks up a php error (I could send direct via pm or email if it'll help). Previously I'd been hashing out lines around 92 to get around this given that normally don't use that module.
Any advise would be gratefully received.
Thanks.
Tue May 05, 2020 5:07 am
Feel free to PM me.
I don’t have a PBX to test so I’m coding blind, but happy to look.
Peter
