Page 1 of 2
New Plugin: FreePBX
PostPosted: Fri Jun 22, 2018 4:45 pm
by Colorado4Wheeler
FreePBX
"Control your Asterisk based FreePBX phone system with Indigo!
In case you never heard of FreePBX it is a completely free full featured PBX that will run on just about any old computer you have sitting around and is more full featured than most $15,000 professional phone systems (PBX's) out there."
NAVIGATE: Plugin Store Download | GitHub Downloads & Release Notes | Manual
Introduction
This new plugin gives you control over your FreePBX phone system from Indigo. While this is an ongoing development project and many more features are planned, right now the plugin will allow you to control your Do Not Disturb, Call Forwarding and Call Flow features on FreePBX so long as you install the RestAPI module.
I don't know how many Indigo users use FreePBX but I have used it and Asterisk for my home and businesses for many years and have always wanted to have a good API into it. Their documentation is vapor so I've had to really dig through the source of FreePBX to get this working and it's nice to finally have this functionality.
If you haven't ever looked at FreePBX for your house I would highly recommend you do, it's a fantastic way to control your home phone system and gives you infinite control and capabilities. Once you add a few SIP lines to your normal inbound POTS (Plain Old Telephone Service) lines that you likely have now then you have super robust multi lined phone system for your home. Pair this with the Twilio plugin (Twilio can be your SIP line provider if you want) and you really get an amazing tool for your Home Automation.
If you have general FreePBX questions I can probably answer a good deal of those, I've used and supported it for ages.
PBX Server
Screen Shot 2018-06-22 at 4.40.05 PM.png (46.29 KiB) Viewed 14205 times
PBX Extension
Screen Shot 2018-06-22 at 4.40.16 PM.png (35.09 KiB) Viewed 14205 times
Call Forwarding
Screen Shot 2018-06-22 at 4.40.39 PM.png (94.4 KiB) Viewed 14205 times
Actions
Screen Shot 2018-06-22 at 4.40.57 PM.png (24.09 KiB) Viewed 14205 times
Extension States
Screen Shot 2018-06-22 at 4.42.54 PM.png (35.03 KiB) Viewed 14205 times
Re: New Plugin: FreePBX (Beta)
PostPosted: Fri Jun 22, 2018 4:56 pm
by FlyingDiver
You still have a POTS line to your house? How 20th Century of you. :shock:
But thanks for the Twilio plug. ;)
PostPosted: Fri Jun 22, 2018 4:59 pm
by Colorado4Wheeler
Well, sort of, I have Xfinity phone service because SIP isn't always spot on, sometimes there are jitters and if the other side has problems I can call them back on that. Plus if the Internet goes down then most of the time the phone line is still up.
I actually didn't for the longest time, I was on Vonage from the time the started up until they went far south, I've only had "POTS" (not really, Xfinity is digital) for a couple years.
PostPosted: Fri Jun 22, 2018 5:00 pm
by Colorado4Wheeler
Oh, and I LOVE Twilio, it's a great SIP service and your plugin is most amazing to use with it. I haven't done too much with it but it's certainly on the map.
PostPosted: Fri Jun 22, 2018 5:01 pm
by FlyingDiver
Feature requests always welcome.
I keep meaning to dig into the API more. I keep thinking there might be a way to create Studio flows or Functions via the API, so users wouldn't need to use the Twilio Dashboard to set complex things up.
PostPosted: Fri Jun 22, 2018 5:03 pm
by FlyingDiver
We used Vonage when we moved from VA to CA in '04. Ported our VA number to Vonage, and my wife's customers in VA just kept calling the same number they used before. Kept it until we went full-time in the RV in '08 (including a move to TX). But since '04 we've been cell phone only.
PostPosted: Fri Jun 22, 2018 5:05 pm
by Colorado4Wheeler
I wouldn't do that, the Twilio Studio dashboard is pretty good IMO. In fact, aren't I the one who recommended that to you as a feature request on Twilio? :wink:
You could use the studio to build a "PBX" IVR, but it's not very robust. FreePBX can be set up on a 15 year old computer and run beautifully and give you all sorts of functionality.
If my cell service was better I would consider going cell only because I can pipe my cell through FreePBX too, but for some reason my property is an AT&T dead zone and I don't like the other providers so.... POTS and SIP ;)
PostPosted: Fri Jun 22, 2018 7:28 pm
by DaveL17
Wow -- that's pretty cool. Never heard of FreePBX before.
PostPosted: Sun Jun 24, 2018 3:21 pm
by Colorado4Wheeler
PostPosted: Sun Jun 24, 2018 4:07 pm
by howartp
Cool, I looked at *pbx couple of years ago.
Time to look again.
PostPosted: Thu Jul 05, 2018 11:30 am
by Colorado4Wheeler
Out of beta, version 1.0.0 has been submitted to the plugin store and is suitable for public consumption.
PostPosted: Fri Mar 20, 2020 9:10 am
by sandconformgorgecloud
Hi
Do you think there is a way to work on PBX 15?
I'm stuck with this one now :(
PostPosted: Tue Apr 21, 2020 5:40 am
by raoul
+1 to FreePBX 15 update.
Looked at adding to my system but running FreePBX 15 and as such I'm getting the following error;
illegal state key onOffState defined by plugin
I'm guessing this is an incompatibility with the current FreePBX?
PostPosted: Wed Apr 22, 2020 12:23 am
by howartp
That sounds more like an Indigo problem than anything to do with version of pbx.
Can you post the full error then we can have a look?
(Author not been online since January)
PostPosted: Fri Apr 24, 2020 4:18 am
by raoul
Thanks for your reply.
Yes, on revisting I found that I had an invalid Key ID, I've now edited that within python.py however my error (on reload is);
EPS - FreePBX Error Invalid response to FreePBX RestAPI on Office PBX: {
"status": "error",
"msg": "Route not found"
I have double checked the Server Token and Token Key.
If I go to edit the Device within Indigo I get the following error;
Error (client) illegal state key onOffState defined by plugin -- native state keys cannot be overriden (ignoring)
Thanks in advance.
