Mac Commander Plugin (Legacy Ver 1.1.0)
Mon Jun 25, 2018 12:34 pm
ckeyes888 offline
Re: Mac Commander Plugin (Legacy Ver 1.1.0)
Here's a sample script that I save as an app on the remote machine.
tell application "Google Chrome" to set URL of active tab of window 1 to "http://192.168.1.80:8176/controlpage?name=Calendar&useJS=True"
I was able to get this script to work between my two 10.12 machines.
set remMachine to "eppc://TV:xx@192.168.1.80"
tell application "Finder" of machine remMachine
   open file "Macintosh HD:Applications:iTunes"
end tell
I assume that means the script should work eventually to the remote 10.6 machine.
The remote machine is only running one app, Google, so I never thought much of upgrading it's OS but now it seems like something to try.
Carl
Mon Jun 25, 2018 12:38 pm
Colorado4Wheeler offline
I suppose it's possible that there was some security changes between 10.6 and 10.12 that would prevent it from being run remotely but I don't know of any off the top of my head. If it works 10.12 to 10.12 then that tells you a lot and that upgrading will probably solve your problem.
Mon Jun 25, 2018 4:23 pm
ckeyes888 offline
Got an newer mini on order running 10.12. I’ll post back how it goes.
Carl
Thu Apr 04, 2019 9:22 am
jltnol offline
I don't see the plugin anymore in the Plugin Store. I'm guessing this uses AppleScript so won't work in the near future? Is that correct?
Thu Apr 04, 2019 9:24 am
You mean this plugin on the Plugin Store?
Even if there is AppleScript it is encapsulated inside of Python calls so it's not part of the phasing out of AppleScript in Indigo.
Thu Apr 04, 2019 9:25 am
jltnol offline
Sorry
I Typed Too Fast.
Was looking fo "E" PS Mac Commander... not just "M"ac commander...
