Problem Installing Homebridge-Indigo
Mon Dec 26, 2016 11:51 pm
nchiles offline
Hi, I am new at this and keep getting this when trying to install this plugin:
npm WARN deprecated node-uuid@1.4.7: use uuid module instead
/opt/local/lib
└── homebridge-indigo@0.3.4
Can anyone point me in the right direction?
Tue Dec 27, 2016 12:24 am
webdeck offline
Re: Problem Installing Homebridge-Indigo
It's a warning that should be safe to ignore.
Tue Dec 27, 2016 8:28 am
nchiles offline
Thanks for the reply. When I try to run homebridge, I'm getting this:
/bin/sh: /opt/local/bin/npm: /opt/local/bin/node: bad interpreter: No such file or directory
[12/27/2016, 9:10:03 AM] Loaded plugin: homebridge-indigo
[12/27/2016, 9:10:03 AM] Registering platform 'homebridge-indigo.Indigo'
[12/27/2016, 9:10:03 AM] ---
[12/27/2016, 9:10:03 AM] ====================
[12/27/2016, 9:10:03 AM] ERROR LOADING PLUGIN homebridge-indigo-master:
[12/27/2016, 9:10:03 AM] Error: Cannot find module 'request'
    at Function.Module._resolveFilename (module.js:469:15)
    at Function.Module._load (module.js:417:25)
    at Module.require (module.js:497:17)
    at require (internal/module.js:20:19)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo-master/index.js:67:15)
    at Module._compile (module.js:570:32)
    at Object.Module._extensions..js (module.js:579:10)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
[12/27/2016, 9:10:03 AM] Loaded plugin: homebridge-nest
[12/27/2016, 9:10:03 AM] Registering platform 'homebridge-nest.Nest'
[12/27/2016, 9:10:03 AM] Loaded config.json with 0 accessories and 1 platforms.
[12/27/2016, 9:10:03 AM] Loading 1 platforms...
[12/27/2016, 9:10:03 AM] [HomeServer] Initializing Indigo platform...
[12/27/2016, 9:10:03 AM] [HomeServer] Indigo base URL is http://127.0.0.1:8176
[12/27/2016, 9:10:03 AM] Loading 0 accessories...
[12/27/2016, 9:10:03 AM] [HomeServer] Listening on port 8177
[12/27/2016, 9:10:03 AM] [HomeServer] Indigo request: http://127.0.0.1:8176/devices.json/
[12/27/2016, 9:10:03 AM] [HomeServer] Error parsing Indigo response for /devices.json/
Exception: SyntaxError: Unexpected token < in JSON at position 0
Response: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en">
   <head>
      <title>Indigo Home Control Server</title>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <link rel="stylesheet" media="screen" type="text/css" href="/css/global4.css" />
      <link rel="stylesheet" media="screen" type="text/css" href="/css/indigo4.css" />
      <link rel="stylesheet" media="screen" type="text/css" href="/css/fonts.css" />
   </head>
   <body>
      <center>
   access denied
      </center>
   </body>
</html>
   <head>
   </head>
   <body>
      <center>
   access denied
      </center>
   </body>
</html>
[12/27/2016, 9:10:03 AM] [HomeServer] Created 0 accessories
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
    │ 031-45-154 │
fs.js:640
  return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
Error: EACCES: permission denied, open '/Users/nathanchiles/.homebridge/persist/AccessoryInfo.CC223DE3CE32.json'
    at Error (native)
    at Object.fs.openSync (fs.js:640:18)
    at Object.fs.writeFileSync (fs.js:1333:33)
    at Object.persistKeySync (/opt/local/lib/node_modules/homebridge/node_modules/node-persist/local-storage.js:457:12)
    at Object.setItemSync (/opt/local/lib/node_modules/homebridge/node_modules/node-persist/local-storage.js:275:14)
    at Object.nodePersist.setItemSync (/opt/local/lib/node_modules/homebridge/node_modules/node-persist/node-persist.js:99:29)
    at AccessoryInfo.save (/opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/model/AccessoryInfo.js:161:11)
    at Bridge.Accessory.publish (/opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:439:23)
    at Server._publish (/opt/local/lib/node_modules/homebridge/lib/server.js:114:16)
    at Server.<anonymous> (/opt/local/lib/node_modules/homebridge/lib/server.js:372:14)
    at /opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:15:19
    at IndigoPlatform.<anonymous> (/opt/local/lib/node_modules/homebridge-indigo/index.js:218:13)
    at /opt/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:52:16
    at /opt/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:264:21
    at /opt/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:44:16
    at IndigoPlatform.<anonymous> (/opt/local/lib/node_modules/homebridge-indigo/index.js:235:17)
    at IndigoPlatform.<anonymous> (/opt/local/lib/node_modules/homebridge-indigo/index.js:368:21)
    at /opt/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:906:35
    at _arrayEach (/opt/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:85:13)
    at Request.<anonymous> (/opt/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:898:17)
    at Request._callback (/opt/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:44:16)
    at Request.self.callback (/opt/local/lib/node_modules/homebridge-indigo/node_modules/request/request.js:373:22)
Do you think this is a problem with my config.json file? I'm wondering if moved something when trying to fix the first warning, and should start fresh.
Thanks again for your help, and for making this plugin!
Tue Dec 27, 2016 8:44 am
Colorado4Wheeler online
That almost looks like you did
npm install {package}
instead of
npm install -g  {package}
I say that because of the access denied messages. You could uninstall the package and try to reinstall it to see if that resolves the issue.
Tue Dec 27, 2016 9:13 am
webdeck offline
And the other issue is that you don't have the correct login information for your Indigo server in your config.json
Tue Dec 27, 2016 12:19 pm
nchiles offline
Thanks guys. I restored from a backup and started over, trying to follow the installation instructions better. I think I'm closer, because it's showing my accessories (Dining Room Lights, Front Door Light) in terminal , but they still aren't showing up in the Home app, just the Nest is.
I've had homebridge running with my nest for a while before trying to install homebridge-indigo. Do you think that could be interfering with the installation?
Here is what the terminal is showing when I run homebridge:
[12/27/2016, 12:52:37 PM] Loaded plugin: homebridge-indigo
[12/27/2016, 12:52:37 PM] Registering platform 'homebridge-indigo.Indigo'
[12/27/2016, 12:52:37 PM] ---
[12/27/2016, 12:52:38 PM] Loaded plugin: homebridge-nest
[12/27/2016, 12:52:38 PM] Registering platform 'homebridge-nest.Nest'
[12/27/2016, 12:52:38 PM] ---
[12/27/2016, 12:52:38 PM] Loaded config.json with 0 accessories and 1 platforms.
[12/27/2016, 12:52:38 PM] Loading 1 platforms...
[12/27/2016, 12:52:38 PM] [My Indigo Server] Initializing Indigo platform...
[12/27/2016, 12:52:38 PM] [My Indigo Server] Indigo base URL is http://127.0.0.1:8176
[12/27/2016, 12:52:38 PM] Loading 0 accessories...
[12/27/2016, 12:52:38 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices.json/
[12/27/2016, 12:52:39 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Dining%20Room%20Lights.json
[12/27/2016, 12:52:39 PM] [My Indigo Server] Discovered Dimmable Power Switch (ID 1346994522): Dining Room Lights
[12/27/2016, 12:52:39 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Front%20Door%20Light.json
[12/27/2016, 12:52:39 PM] [My Indigo Server] Discovered Relay Power Switch (ID 1540531918): Front Door Light
[12/27/2016, 12:52:39 PM] [My Indigo Server] Indigo request: http://127.0.0.1:8176/actions.json/
[12/27/2016, 12:52:39 PM] [My Indigo Server] Created 2 accessories
[12/27/2016, 12:52:39 PM] [My Indigo Server] Initializing platform accessory 'Dining Room Lights'...
[12/27/2016, 12:52:39 PM] [My Indigo Server] Initializing platform accessory 'Front Door Light'...
    │ 031-45-154 │
events.js:160
      throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
    at Object.exports._errnoException (util.js:1022:11)
    at exports._exceptionWithHostPort (util.js:1045:20)
    at Server._listen2 (net.js:1259:14)
    at listen (net.js:1295:10)
    at Server.listen (net.js:1391:5)
    at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
    at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
    at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
    at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:114:16)
    at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:372:14)
    at /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:15:19
    at IndigoPlatform.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/index.js:218:13)
    at /usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:52:16
    at /usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:269:32
    at /usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:44:16
    at /usr/local/lib/node_modules/homebridge-indigo/index.js:243:29
    at iterate (/usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:260:24)
    at Object.async.forEachOfSeries.async.eachOfSeries (/usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:281:9)
    at Object.async.forEachSeries.async.eachSeries (/usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:214:22)
    at IndigoPlatform.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/index.js:238:23)
    at IndigoPlatform.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/index.js:371:17)
After googling
, I did
sudo killall homebridge
and restarted homebridge. Now the Nest is not responding either :?
Sorry for all the questions, I appreciate your help so far.
Tue Dec 27, 2016 12:41 pm
So it looks like you have two HB servers running on the same port now. In your config change the port to something different and, while you are there, change the user name from the default to something else by changing one character. The user name will be something like "CD:22:DD:E3:CE:30", just change one of those characters to an F to force HomeKit to reacquire the server. HK will cache previous servers and if they are not properly removed while the server is operational they can get stuck in the HK database.
Tue Dec 27, 2016 12:56 pm
nchiles offline
That did it! Thank you so much!
Tue Dec 27, 2016 1:01 pm
Awesome!
Dear Diary,
Today I was actually right for a change, perhaps 2017 WILL be my year after all. Hopefully this also means I can eat more brownies without gaining weight but that may be tempting fate too much.
Yours truly,
C4W
Tue Dec 27, 2016 1:09 pm
nchiles offline
Colorado4Wheeler wrote:
Awesome!
Dear Diary,
Yours truly,
C4W
Hahahahaha :lol:
Fri Dec 30, 2016 7:21 pm
webdeck offline
FYI, I published an update that resolves the deprecation warning.
