How to control shades
Mon Dec 12, 2016 7:55 am
MarcoGT offline
Running still on I6, therefore no HomeBridge plugin.
After having creating scenes in Home iOS App I can execute actions directly using Siri.
I have at home some shades that I would like to control; as said, I can do it via predefined actions, but if I want to set that shades to a % that does not have any corresponding actions, which command shall I give? The "dim" command? (of course translated into Italian, which is hard to find out) :D
Mon Dec 12, 2016 9:37 am
Colorado4Wheeler offline
Re: How to control shades
Yes, it's pretty much like the dim command:
"Siri, open curtains to 50%".
Mon Dec 12, 2016 11:25 am
MarcoGT offline
What is not clear to me is why the Fibaro Roller Shutter are not seen by HomeBridge...or maybe I did something wrong? They are not of course inside the excludedIds
Mon Dec 12, 2016 12:04 pm
Did you add them in the "treatAsWindowCoveringIds" in your config.json?
Mon Dec 12, 2016 3:14 pm
MarcoGT offline
Yes...I will post my config.json
Tue Dec 13, 2016 2:38 am
MarcoGT offline
I have config.json with "excludeIds" and "treatAsWindowCoveringIds" but the shades devices do not appear even in Homebride output, but for example the wall plug yes.
I thought I also had to include those ID using "includeIds" but the wall plugs are not, althought they are shown in HomeBridge/HomeKit...strange
Tue Dec 13, 2016 3:34 am
Is the remote tickbox ticked? if not it won't see it!
Tue Dec 13, 2016 3:47 am
MarcoGT offline
Yes, because I see them in Indigo Touch.
Tue Dec 13, 2016 10:26 am
webdeck offline
What type of device are the shades? Homebridge only recognized a limited set of native Indigo devices. You may need to create a virtual device in Indigo that homebridge can recognize.
Tue Dec 13, 2016 10:32 am
Also, along those lines, if you are including EVERYTHING in your HB config then you may have exceeded the 100 device limit and aren't seeing your shades because of that.
Tue Dec 13, 2016 12:47 pm
MarcoGT offline
They are Fibaro Roller Shutter.
No, I am definitely below the 100 devices limit...
I will try with the Virtual Device, thanks.
Tue Dec 13, 2016 12:51 pm
What model roller shutter is it? I can confirm my one works FGRM222
Tue Dec 13, 2016 12:55 pm
MarcoGT offline
Yes, FGRM222.
Does it work with Virtual Device or without?
Here my config.json
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "031-45-154"
    "description": "This is an example configuration file to configure the Indigo platform plugin. See README.md for more details.",
    "platforms": [
            "platform": "Indigo",
            "name": "Home",
            "protocol": "http",
            "host": "127.0.0.1",
            "port": "8176",
            "path": "",
            "username": "xyz",
            "password": "zyx",
            "includeActions": true,
            "excludeIds": ["1983912366","814592847", "662075182", "212594107", "160330803", "1448443570", "1629450832", "1246609318", "1658581234", "1733813060", "1571059388", "1845922280", "1274203767", "1225289142", "144170272", "1950599464", "279688259", "549497745", "1089854562", "1553177968", "1808450162", "1557887232", "1733668389", "894672293", "198416157", "558122221", "493203839", "70262964", "1083368649", "210961798", "845285540", "891507022", "758775317", "772069004", "800086025", "899977255", "1762622151", "1465013623", "660894531", "1934612088", "402839728", "360992331", "1853139542", "999769893", "839788032", "1739726912", "1772151188", "1994620087", "603539388", "792519451", "1288769269", "1756276246", "1352257630", "1040917004", "1831782226", "24187631", "274816165", "667469232", "1605098867", "1366211908", "1816299658", "143985151", "606357692", "557880474", "90422420", "983644484", "264786261", "1312028030", "1789047901", "1832395221", "1227466386", "1971180444", "415877625", "830825286", "1983912366", "814592847", "662075182", "212594107", "160330803", "1448443570", "1629450832", "1246609318", "1658581234", "1733813060", "1571059388", "1845922280", "1325819187", "874458873", "477854509", "23196367", "293694453", "1066261345", "1486127284", "1158612934", "435332506", "446124490", "20572975", "70262964", "1083368649", "210961798", "845285540", "1627531774", "975919813", "891507022", "1679231844", "1158598227"],
            "treatAsSwitchIds": [ "1089109190", "1156545517", "1464509557", "1610743372", "1423497852", "790512852" ],
         "treatAsWindowCoveringIds" : [ "1066261345", "1486127284", "1158612934", "435332506", "446124490" ],
            "thermostatsInCelsius": true,
            "accessoryNamePrefix": ""
    "accessories": [
Tue Dec 13, 2016 12:59 pm
Works perfectly fine without a virtual device.
Perhaps try deleting the device in indigo and create a new one?
Tue Dec 13, 2016 1:11 pm
Or blow away Homebridge in your HomeKit app and start it again.
