excluded ID still shows up in Home app
Mon Nov 21, 2016 2:04 pm
and more, it is an action group and shows up as a door!
Any idea how to fix this? I've double checked that the proper ID is listed as an excludeID and it is.
Also, I just edited my config.json to treat some things as switches, and then reran home bridge and got
events.js:160
      throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
    at Object.exports._errnoException (util.js:1026:11)
    at exports._exceptionWithHostPort (util.js:1049:20)
    at Server._listen2 (net.js:1257:14)
    at listen (net.js:1293:10)
    at Server.listen (net.js:1389:5)
    at EventedHTTPServer.listen (/opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
    at HAPServer.listen (/opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
    at Bridge.Accessory.publish (/opt/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
    at Server._publish (/opt/local/lib/node_modules/homebridge/lib/server.js:111:16)
    at Server.<anonymous> (/opt/local/lib/node_modules/homebridge/lib/server.js:369:14)
but it seems to be running.
Sun Nov 27, 2016 1:20 am
webdeck offline
Re: excluded ID still shows up in Home app
EADDRINUSE means you already have an instance of homebridge running. You need to stop all of the instances of homebridge before starting another one.
Sun Nov 27, 2016 11:16 am
Thanks! not sure how that happened. Any ideas about the excluded IDs that still show up? or the action group HB thinks is a door?
