Error on startup
Sun Nov 13, 2016 9:23 am
farberm offline
Error on startup
Can anyone help with this. Using Node 7.1 and npm 3.10.9. I am getting the following error on startup.
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
events.js:160
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
at Object.exports._errnoException (util.js:1022:11)
at exports._exceptionWithHostPort (util.js:1045:20)
at Server._listen2 (net.js:1262:14)
at listen (net.js:1298:10)
at Server.listen (net.js:1376:9)
at EventedHTTPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
at HAPServer.listen (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
at Bridge.Accessory.publish (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
at Server._publish (/usr/local/lib/node_modules/homebridge/lib/server.js:111:16)
at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:369:14)
at /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:15:19
at IndigoPlatform.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/index.js:215:13)
at /usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:52:16
at /usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:269:32
at /usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:44:16
at /usr/local/lib/node_modules/homebridge-indigo/index.js:240:29
at IndigoPlatform.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/index.js:288:17)
at IndigoPlatform.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/index.js:362:17)
at /usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:906:35
at _arrayEach (/usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:85:13)
at Request.<anonymous> (/usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:898:17)
at Request._callback (/usr/local/lib/node_modules/homebridge-indigo/node_modules/async/lib/async.js:44:16)
at Request.self.callback (/usr/local/lib/node_modules/homebridge-indigo/node_modules/request/request.js:373:22)
at emitTwo (events.js:106:13)
at Request.emit (events.js:191:7)
Sun Nov 13, 2016 9:24 am
webdeck offline
Re: Error on startup
That means you already have an instance running that you need t stop first.
Sun Nov 13, 2016 9:26 am
farberm offline
I have rebooted and still get that error. How do I go about doing that?
Sun Nov 13, 2016 9:27 am
webdeck offline
If you used launchctl to automatically start it, then it starts again when you reboot. You can unload the launchctl script to stop it and prevent it from restarting: launchctl unload -w ~/Library/LaunchAgents/com.webdeck.homebridge.plist
Sun Nov 13, 2016 9:48 am
farberm offline
I am not using launchct. Just to be sure I entered the command in the terminal and still get the same error
Sun Nov 13, 2016 9:52 am
webdeck offline
This command will tell you what process is using port 51826:
sudo lsof -i :51826
Sun Nov 13, 2016 9:55 am
farberm offline
Response
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
node 543 markfarber 11u IPv6 0xb476f3ed81997703 0t0 TCP *:51826 (LISTEN)
node 543 markfarber 16u IPv6 0xb476f3ed8196e703 0t0 TCP 192.168.1.22:51826->192.168.1.115:54116 (ESTABLISHED)
node 543 markfarber 20u IPv6 0xb476f3ed81997c43 0t0 TCP 192.168.1.22:51826->192.168.1.13:63166 (ESTABLISHED)
node 543 markfarber 24u IPv6 0xb476f3ed8bf34c43 0t0 TCP 192.168.1.22:51826->192.168.1.45:60579 (ESTABLISHED)
node 543 markfarber 28u IPv6 0xb476f3ed8bf44703 0t0 TCP 192.168.1.22:51826->192.168.1.18:62553 (ESTABLISHED)
node 543 markfarber 31u IPv6 0xb476f3ed8bf6a183 0t0 TCP 192.168.1.22:51826->192.168.1.25:49286 (ESTABLISHED)
node 543 markfarber 36u IPv6 0xb476f3ed8bf71703 0t0 TCP 192.168.1.22:51826->192.168.1.24:57787 (ESTABLISHED)
these all look to be other apple devices on the network? iPhones and Apple TV
Sun Nov 13, 2016 10:00 am
webdeck offline
You have homebridge running already. That's what "node" is.
launchctl list | grep homebridge
will probably show it in that list somewhere.
Sun Nov 13, 2016 10:03 am
farberm offline
Farber-Media-Center:~ markfarber$ launchctl list | grep homebridge
543 0 com.homebridge.server
Ok so how do I stop the process and the autoload because I am getting errors from my home app that it is not woking
Sun Nov 13, 2016 10:05 am
webdeck offline
Do you remember how you installed it? You must have done something different from the instructions provided because the launchctl command I gave you would have worked if you had installed it according to the instructions in this forum.
Sun Nov 13, 2016 10:13 am
farberm offline
I originally installed via your instructions several months ago.
I tried to get auto restart to work according the the forum but never seemed to work.
I then recently updated to nodejs6 and npm3 via the forum instructions to uninstall npm2 and nodejs6 and to rm node_modules command. Then installed npm3 and nodejs6.
Lastly I uninstalled nodejs6 and npm3 and installed using the nodejs7 pkg which installs both nom 3.10.9 and nodejs7. I guess my autolaunch command is not working but not sure why now?
I just restarted and auto launch seems to be working. My only question is where can I locate the autolaunch function and what I really have been trying to do is get autolaunch and auto restart to work on a crash.
Suggestions and thanks for your help.
Sun Nov 13, 2016 10:16 am
webdeck offline
WEll the good news is that you have auto launch working because it was running after a reboot.
You can use spotlight to search for homebridge to try and find where you put the launchctl plist file.
Sun Nov 13, 2016 10:29 am
farberm offline
.homebridge is located in my user folder and has folders of accessories and resist and my config.js file.
there is a lanchctl file located in the root/bin folder.
Since auto launch is working that is ok. How do I enable auto restart?
Sun Nov 13, 2016 10:40 am
webdeck offline
They are one in the same. If it is autolaunching it is also auto-restarting.
Sun Nov 13, 2016 10:51 am
farberm offline
What terminal command can I use to show me errors and crashes of is there a log
