Home bridge newbie question
Thu Sep 15, 2016 5:06 pm
scs offline
Hey Yall,
I run the latest version of Indigo 6 on a modern Mac Mini, (Yosemite) and it controls about 30 devices, split evenly between Insteon and Z-Wave.
I installed the Homebridge last night, and after sorting out the port number and password this morning , it connected to the URL ( http://http://192.168.0.21:8176/devices/ ) and enumerated the devices.
Not knowing much about this, I connected to the home bridge with the "Home" app on my iPad (IOS 10), entered the PIN , and all the devices showed up. They're all represented as icons in the app , but they all have a "!" next to them and are labeled as "No response". The actual Homebridge is also listed as a device the same way "No Response" and if you click on it , it reports "This accessory is not responding "
I find it odd that it was able to populate the entire device list, but the home bridge can't read status/control them .
Any help would be appreciated .
I 'll post my logs in a few minutes
Indigo 7 w/ Insteon and Z-Wave lights and outlets
Security integration.
Energy monitoring
Thu Sep 15, 2016 5:08 pm
scs offline
Re: Home bridge newbie question
MacMini:.homebridge admin$ homebridge -D
[9/15/2016, 8:49:19 AM] Loaded plugin: homebridge-indigo
[9/15/2016, 8:49:19 AM] Registering platform 'homebridge-indigo.Indigo'
[9/15/2016, 8:49:19 AM] ---
[9/15/2016, 8:49:19 AM] Loaded config.json with 0 accessories and 1 platforms.
[9/15/2016, 8:49:19 AM] Loading 1 platforms...
[9/15/2016, 8:49:19 AM] [MacMini] Initializing Indigo platform...
[9/15/2016, 8:49:19 AM] [MacMini] Indigo base URL is http://192.168.0.21:8176
[9/15/2016, 8:49:19 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices.json/
[9/15/2016, 8:49:19 AM] Loading 0 accessories...
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Back%2 ... ensor.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Open/Close Sensor (ID 1278189473): Back Door Sensor
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Bonus% ... h-011.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Dimmable Scene Switch (ID 58817566): Bonus Rm Dimmable Switch-011
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Bonus% ... 0Bulb.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered 8 Watt LED Bulb (2672) (ID 16281606): Bonus Rm LED Bulb
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Chicke ... eLinc.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered ApplianceLinc (ID 135534876): Chicken Coop ApplianceLinc
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Chicke ... 0Bulb.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered 8 Watt LED Bulb (2672) (ID 1093333866): Chicken Run LED Bulb
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Crawl% ... ensor.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Open/Close Sensor (ID 1484638669): Crawl Space Door Sensor
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Leak Sensor (ID 259343481): Crawl Space Leak Sensor
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Deck%2 ... 20003.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Dimmable Scene Switch (ID 134262514): Deck Dimmable Switch- 003
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Foscam%20FI8910W.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Foscam IP Camera (ID 65955827): Foscam FI8910W
[9/15/2016, 8:49:20 AM] [MacMini] Ignoring unknown accessory type Foscam IP Camera
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Front% ... h-008.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Dimmable Scene Switch (ID 30178809): Front Porch Dimmable Switch-008
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Garage ... 0Bulb.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered 8 Watt LED Bulb (2672) (ID 1530354763): Garage LED Bulb
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Gayles ... ensor.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Open/Close Sensor (ID 1656427349): Gayles garage Sensor
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Hottub ... A-010.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Relay Power Switch (ID 306361713): Hottub Relay Power Switch 20A-010
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Kitche ... plinc.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered LampLinc (dual-band) (ID 317642048): Kitchen Cabinet Lamplinc
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Kitche ... 0-006.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Dimmable Scene Switch (ID 418329349): Kitchen Dimmable Switch -006
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Living ... nc%20.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered LampLinc (dual-band) (ID 275211201): Livingroom Lamplinc
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Multis ... idity.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Multi Sensor (DSB05) (ID 1148797664): Multisensor - Humidity
[9/15/2016, 8:49:20 AM] [MacMini] Ignoring unknown accessory type Multi Sensor (DSB05)
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Multis ... nance.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Multi Sensor (DSB05) (ID 91264028): Multisensor - Luminance
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Multis ... ensor.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Multi Sensor (DSB05) (ID 1906296277): Multisensor - Motion Sensor
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Multis ... ature.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Multi Sensor (DSB05) (ID 226569755): Multisensor - Temperature
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Network.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Relay Power Switch (ID 140160089): Network
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/NOAA%20Weather.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Weather Station (ID 1830850739): NOAA Weather
[9/15/2016, 8:49:20 AM] [MacMini] Ignoring unknown accessory type Weather Station
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Office ... h-004.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Dimmable Scene Switch (ID 1303316071): Office Dimmable Switch-004
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Patio% ... nc%20.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered LampLinc (dual-band) (ID 1330981502): Patio LampLinc
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Roamin ... elinc.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered ApplianceLinc (ID 220569250): Roaming Appliancelinc
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Shed%20LED%20Bulb.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered 8 Watt LED Bulb (2672) (ID 682319189): Shed LED Bulb
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Side%2 ... h-007.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Dimmable Scene Switch (ID 779465955): Side Porch Dimmable Switch-007
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Stairs ... 0bulb.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered 8 Watt LED Bulb (2672) (ID 1957293234): Stairs LED bulb
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Steves ... ensor.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Open/Close Sensor (ID 1280009570): Steves Garage Sensor
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Tree%2 ... 0Bulb.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered 8 Watt LED Bulb (2672) (ID 690998874): Tree House LED Bulb
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/devices/Xmas%2 ... eLinc.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered ICON Appliance (ID 1315451421): Xmas tree2 ApplianceLinc
[9/15/2016, 8:49:20 AM] [MacMini] Discovered ApplianceLinc (ID 1067053831): Xmas tree3 ApplianceLinc
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/actions.json/
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/actions/Indoor ... 20Off.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Action (ID 25408721): Indoor Lights Off
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/actions/Indoor ... %20On.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Action (ID 1395596758): Indoor Lights On
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/actions/Outdoo ... 20off.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Action (ID 863357014): Outdoor Lights off
[9/15/2016, 8:49:20 AM] [MacMini] Indigo request: http://192.168.0.21:8176/actions/Outdoo ... %20ON.json
[9/15/2016, 8:49:20 AM] [MacMini] Discovered Action (ID 105422946): Outdoor Lights ON
[9/15/2016, 8:49:20 AM] [MacMini] Created 31 accessories
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Back Door Sensor'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Bonus Rm Dimmable Switch-011'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Bonus Rm LED Bulb'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Chicken Coop ApplianceLinc'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Chicken Run LED Bulb'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Crawl Space Door Sensor'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Crawl Space Leak Sensor'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Deck Dimmable Switch- 003'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Front Porch Dimmable Switch-008'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Garage LED Bulb'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Gayles garage Sensor'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Hottub Relay Power Switch 20A-010'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Indoor Lights Off'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Indoor Lights On'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Kitchen Cabinet Lamplinc'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Kitchen Dimmable Switch -006'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Livingroom Lamplinc '...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Multisensor - Motion Sensor'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Network'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Office Dimmable Switch-004'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Outdoor Lights ON'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Outdoor Lights off'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Patio LampLinc '...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Roaming Appliancelinc'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Shed LED Bulb'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Side Porch Dimmable Switch-007'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Stairs LED bulb'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Steves Garage Sensor'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Tree House LED Bulb'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Xmas tree2 ApplianceLinc'...
[9/15/2016, 8:49:20 AM] [MacMini] Initializing platform accessory 'Xmas tree3 ApplianceLinc'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
[9/15/2016, 8:49:20 AM] Homebridge is running on port 51826.
Energy monitoring
Thu Sep 15, 2016 5:11 pm
scs offline
MacMini:.homebridge admin$ cat config.json
"bridge": {
"name": "Homebridge",
"username": "CC:22:3D:E3:CE:30",
"port": 51826,
"pin": "031-45-154"
"description": "This is an example configuration file to configure the Indigo platform plugin. See README.md for more details.",
"platforms": [
"platform": "Indigo",
"name": "MacMini",
"protocol": "http",
"host": "192.168.0.21",
"port": "0000",
"path": "",
"username": "user",
"password": "password",
"includeActions": true,
"treatAsSwitchIds": [ "13579", "24680" ],
"treatAsLockIds": [ "112233", "445566" ],
"treatAsDoorIds": [ "224466", "664422" ],
"treatAsGarageDoorIds": [ "223344", "556677" ],
"treatAsWindowIds": [ "123123", "456456" ],
"treatAsWindowCoveringIds": [ "345345", "678678" ],
"thermostatsInCelsius": false,
"accessoryNamePrefix": ""
"accessories": [
Energy monitoring
Thu Sep 15, 2016 6:07 pm
scs offline
Cool, I just killed homebridge, installed the Update for the iOS 10 Home app , and then restarted .
Then I went back to the Home app. and deleted the Homebridge (which also deletes all the devices ) and you start with a clean slate.
Once I reconnected the Home app to the homebridge, it looked and behaved totally different and all the devices can be controlled from the app, or by Siri commands.
Sweet app, thanks Mike.
Energy monitoring
Thu Sep 15, 2016 7:21 pm
webdeck offline
Glad it's working!
