New release supporting Windows and Window Coverings
Tue Jul 12, 2016 11:33 pm
webdeck offline
I have added support for windows and window coverings with new configs - treatAsWindowIds and treatAsWindowCoveringIds.
To get the new version, just update:
sudo npm update -g homebridge
sudo npm update -g homebridge-indigo
and restart your instance of homebridge.
This update also fixes a bug where the state of doors and garage doors were not updating their displayed state in HomeKit if you opened or closed them.
Wed Jul 13, 2016 2:45 am
Re: New release supporting Windows and Window Coverings
Does it support % open? When I set it to say 10% open it seems to just toggle between 0% and 100%? (It may be a iOS 10 bug, I'll test it on a non updated device later :)
Wed Jul 13, 2016 8:31 am
webdeck offline
No, it only supports binary on/off mapped to open/closed.
Wed Jul 13, 2016 10:18 am
DGJ offline
I've updated and included my curtains in the config file & all seems well, running Sierra & iOS10.
The only issue is that my curtains are "on" when closed & "off" when open, so back to front at the moment.
Wed Jul 13, 2016 10:46 pm
webdeck offline
I had a 50/50 chance of the on=open off=closed mapping being the right way for everyone. :) If you can't flip it in Indigo, then you'll need to create a virtual device that acts the opposite way for now.
Wed Jul 13, 2016 10:54 pm
webdeck offline
FYI, I just pushed version 0.2.14 which has a minor bug fix so that a lock's display gets updated when you change the state of a lock.
Sat Jul 16, 2016 2:34 am
davinci offline
Thanks for adding support.
Do you think it's possible to ask Siri if the coverings are open or closed? Also it would be nice to use the brightness as a command as well.
Sat Jul 16, 2016 8:52 am
webdeck offline
HomeKit is able to query if they are open or closed, so it should be possible to ask Siri, but I don't know if it's in Siri's vocabulary. Does it work if you try?
I just pushed version 0.2.15 that adds the ability to partially open windows, doors, and window coverings if the underlying Indigo device supports dimming.
Sat Jul 16, 2016 12:37 pm
davinci offline
Hmm if I set it to 15 % ist just opens to 100%. Might be a bug, I guess?
Maybe I don't know the syntax for asking Siri but she always tells me there are not devices..
Thanks for the improvements.
Sat Jul 16, 2016 1:13 pm
webdeck offline
Did you update homebridge-indigo and restart it?
Does the device you're using in Indigo support dimming? If it doesn't, then there is no way to set a percentage through the RESTful API. I tested it with a switchlinc dimmer and it worked correctly - I don't have any real blind/window/door devices to test with.
Sat Jul 16, 2016 2:24 pm
Works perfectly for mine, although like DGJ mine shows as closed when it's open and open when it's closed! Don't think I can make a virtual device for that as I don't think they support % do they?
Sat Jul 16, 2016 3:28 pm
webdeck offline
HomeKit defines door/window/window covering position as a percentage between 0% and 100%, with 0% meaning fully closed and 100% meaning fully open. I mapped that directly to brightness, so fully closed is 0% brightness (off) and fully open is 100% brightness (fully on).
So do your devices interpret it the opposite way, where 0% means fully open and 100% means fully closed?
Sat Jul 16, 2016 4:41 pm
Yeah, although it'd be a very simple fix to rewire the motors to the inverse of what they currently are. My only concern would be if Indigo 7 contains definitions of devices like blinds and would then show the opposite of that! What's the word matty boy? ;)
Sun Jul 17, 2016 2:58 am
davinci offline
I guess I was still on the old version, even though I updated over Terminal.
I reinstalled and it works!
I also updated Node.js, maybe this was related.
Btw. The wiring is defined by your module and the motor. So there has to be a wiring issue. I would just change the wires on the module to fix this properly.
Sun Jul 17, 2016 4:39 am
Yeah I wasn't sure about the wiring.. 50/50 chance of getting it right!!
