Can't use launchctl
Fri Feb 12, 2016 8:04 am
dnomode offline
Re: Can't use launchctl
Hey Mike,
I've reset it several times already. I noticed some errors in the log files. "Dubious permissions on file (Skipping):" Please check out the picture below. I thought It was fixed using chmod 644 com.webdeck.homebridge.plist however it seems that its still not working. :cry:
I tried chmod 644 com.webdeck.homebridge.plist again, however it's still giving me the same error.
Sat Feb 13, 2016 12:10 am
webdeck offline
Those console errors are from before when the launch agent plist file was put into the top level directory instead of the one in your home directory. To make those go away, unload and remove that file:
launchctl unload -w /Library/LaunchAgents/com.webdeck.homebridge.plist
rm -f /Library/LaunchAgents/com.webdeck.homebridge.plist
Homebridge errors wouldn't be in your console log. The homebridge log file will be located in ~/Library/Logs/homebridge.log (that's the Logs folder inside the Library folder in your home directory.)
-Mike
