Evohome error
PostPosted: Wed Dec 06, 2017 3:59 pm
by Jamesb
Im new to this home automation stuff and I'm really struggling to understand so please help :D, Im struggling to get anything after installing the evohome plugin and this is what happens when I open the log :-
sensor update to 46%
Z-Wave received "Utility Humidity" sensor update to 33%
Evohome Refreshing zone data
Evohome Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 66, in runConcurrentThread
File "plugin.py", line 94, in refreshZones
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Evohome.indigoPlugin/Contents/Server Plugin/evohomeclient2/__init__.py", line 19, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Evohome.indigoPlugin/Contents/Server Plugin/evohomeclient2/__init__.py", line 69, in _login
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Evohome.indigoPlugin/Contents/Server Plugin/requests/api.py", line 107, in post
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Evohome.indigoPlugin/Contents/Server Plugin/requests/api.py", line 53, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Evohome.indigoPlugin/Contents/Server Plugin/requests/sessions.py", line 468, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Evohome.indigoPlugin/Contents/Server Plugin/requests/sessions.py", line 576, in send
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Evohome.indigoPlugin/Contents/Server Plugin/requests/adapters.py", line 426, in send
ConnectionError: ('Connection aborted.', error(54, 'Connection reset by peer'))
Evohome Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
where am I going wrong please?
Re: Evohome error
PostPosted: Wed Dec 06, 2017 4:13 pm
by jay (support)
[MODERATOR NOTE] moved to the Evohome developer's forum.
Re: Evohome error
PostPosted: Thu Dec 07, 2017 1:45 am
by howartp
Hi James.
I should retire this plugin; it’s superseded by the Honeywell Plugin by NLagaros.
If you can’t find the link I’ll post it later.
Peter
