Model B rev 2.0 - Revision 000e according to cpuinfo
Added features / changes in v7.103.276 @ 2019-05-07
1. moved setGPIO command into execcommands. that reduces delay with older RPI ie RPI1
2. now all pibeacon logfiles on the RPI are in ONE file: /var/log/piBeacon.log
it looks like:
date module debuglvl message
20190507-12:56:30 copyToTemp L:-1= killing copyToTemp.py
20190507-12:56:30 sunDial L:-2= move return due to: direction1, inFixBoundaryMode:0 cap switch sens: 0; switch sensor:0
20190507-12:56:30 sunDial L:-3= 1100 === 34 1
20190507-12:56:31 master L:-1= IP find:::: wifiIP >><<; eth0IP: >>192.168.1.39<<; hostnameIP >>['192.168.1.39']<<; ipAddressRead >>192.168.1.39<<
20190507-12:56:31 sunDial L:-2= move return due to: direction-1, inFixBoundaryMode:0 cap switch sens: 0; switch sensor:0
20190507-12:56:31 sunDial L:-3= 1300 === 85 -1
20190507-12:56:31 master L:-1= master can ping indigo server at ip:>>192.168.1.50<<
20190507-12:56:32 installLibs L:-1= installLibs starting
20190507-12:56:32 installLibs L:-1= installLibs no opsys upgrade requested
20190507-14:59:04 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': True, u'command': u'down', u'pin': u'26'}
20190507-14:59:04 execcommands L: 1= next cmd: "down"
20190507-14:59:04 execcommands L: 0= setGPIO pid=16700, command :{'startAtDateTime': u'1557259144.27', 'values': {}, 'pin': '26', 'debug': 3, 'inverseGPIO': True, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190507-14:59:04 execcommands L: 0= msg: 156x-6-api_IN_14x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"high"}}},"program":"execcommands","ipAddress":"","pi":"14","ts":{"tz":"CDT","time":1557259144.16}}
20190507-14:59:04 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': True, u'command': u'down', u'pin': u'5'}
20190507-14:59:04 execcommands L: 0= setGPIO pid=16707, command :{'startAtDateTime': u'1557259144.36', 'values': {}, 'pin': '5', 'debug': 3, 'inverseGPIO': True, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190507-14:59:04 execcommands L: 0= msg: 156x-6-api_IN_14x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"high"}}},"program":"execcommands","ipAddress":"","pi":"14","ts":{"tz":"CDT","time":1557259144.29}}
20190508-10:21:51 receiveCommands L: 2= len of buffer:409
20190508-10:21:51 receiveCommands L: 2= len of buffer:0
20190508-10:21:51 receiveCommands L: 2= len of package:409
20190508-10:21:51 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "4"}
20190508-10:21:51 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}
20190508-10:21:51 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}
20190508-10:21:51 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}
20190508-10:21:51 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}
20190508-10:21:52 receiveCommands L: 2= len of buffer:235
20190508-10:21:52 receiveCommands L: 2= len of buffer:0
20190508-10:21:52 receiveCommands L: 2= len of package:235
20190508-10:21:52 receiveCommands L: 1= cmd= {"restoreAfterBoot": "0", "startAtDateTime": 0, "pin": "24", "inverseGPIO": false, "devId": 1128735305, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "device": "OUTPUTgpio-1", "command": "pulseUp"}
20190508-10:21:52 receiveCommands L: 1= cmd= {"restoreAfterBoot": "0", "startAtDateTime": 0, "pin": "18", "inverseGPIO": false, "devId": 1128735305, "values": {"analogValue": 0.0, "pulseDown": 0.0, "pulseUp": 600.0, "nPulses": 0}, "device": "OUTPUTgpio-1", "command": "pulseUp"}
20190508-10:21:58 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'4'}
20190508-10:21:58 execcommands L: 1= next cmd: "down"
20190508-10:21:58 execcommands L: 0= setGPIO pid=8819, command :{'startAtDateTime': u'1557307318.59', 'values': {}, 'pin': '4', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:21:59 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'17'}
20190508-10:21:59 execcommands L: 1= next cmd: "down"
20190508-10:21:59 execcommands L: 0= setGPIO pid=8821, command :{'startAtDateTime': u'1557307319.34', 'values': {}, 'pin': '17', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:21:59 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307318.75}}
20190508-10:21:59 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'27'}
20190508-10:21:59 execcommands L: 0= setGPIO pid=8823, command :{'startAtDateTime': u'1557307319.81', 'values': {}, 'pin': '27', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:22:00 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307319.48}}
20190508-10:22:00 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'22'}
20190508-10:22:00 execcommands L: 1= next cmd: "down"
20190508-10:22:00 execcommands L: 0= setGPIO pid=8825, command :{'startAtDateTime': u'1557307320.47', 'values': {}, 'pin': '22', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:22:00 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307319.94}}
20190508-10:22:00 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'23'}
20190508-10:22:00 execcommands L: 0= setGPIO pid=8827, command :{'startAtDateTime': u'1557307320.64', 'values': {}, 'pin': '23', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:22:00 execcommands L:-1= next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'24', u'inverseGPIO': False, u'devId': 1128735305, u'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, u'device': u'OUTPUTgpio-1', u'command': u'pulseUp'}
20190508-10:22:00 execcommands L: 1= next cmd: "pulseUp"
20190508-10:22:00 execcommands L: 0= setGPIO pid=8829, command :{'startAtDateTime': 1557307320.843068, 'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, 'pin': '24', 'debug': 3, 'inverseGPIO': False, 'cmd': u'pulseUp', 'devId': 1128735305, 'PWM': 1}
20190508-10:22:00 execcommands L:-1= next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'18', u'inverseGPIO': False, u'devId': 1128735305, u'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, u'device': u'OUTPUTgpio-1', u'command': u'pulseUp'}
20190508-10:22:01 execcommands L: 0= setGPIO pid=8831, command :{'startAtDateTime': 1557307320.998413, 'values': {u'analogValue': 0.0, u'pulseDown': 0.0, u'pulseUp': 600.0, u'nPulses': 0}, 'pin': '18', 'debug': 3, 'inverseGPIO': False, 'cmd': u'pulseUp', 'devId': 1128735305, 'PWM': 1}
20190508-10:22:01 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307320.55}}
20190508-10:22:01 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307320.76}}
20190508-10:22:58 receiveCommands L: 2= len of buffer:573
20190508-10:22:58 receiveCommands L: 2= len of buffer:0
20190508-10:22:58 receiveCommands L: 2= len of package:573
20190508-10:22:58 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "4"}
20190508-10:22:58 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "17"}
20190508-10:22:58 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "18"}
20190508-10:22:58 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "27"}
20190508-10:22:59 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "22"}
20190508-10:22:59 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "23"}
20190508-10:22:59 receiveCommands L: 1= cmd= {"device": "OUTPUTgpio-1", "inverseGPIO": false, "command": "down", "pin": "24"}
20190508-10:23:05 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'4'}
20190508-10:23:05 execcommands L: 1= next cmd: "down"
20190508-10:23:05 execcommands L: 0= setGPIO pid=8927, command :{'startAtDateTime': u'1557307385.61', 'values': {}, 'pin': '4', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:06 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'17'}
20190508-10:23:06 execcommands L: 1= next cmd: "down"
20190508-10:23:06 execcommands L: 0= setGPIO pid=8929, command :{'startAtDateTime': u'1557307386.24', 'values': {}, 'pin': '17', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:06 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307385.75}}
20190508-10:23:06 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'18'}
20190508-10:23:06 execcommands L: 0= setGPIO pid=8931, command :{'startAtDateTime': u'1557307386.77', 'values': {}, 'pin': '18', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:06 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307386.37}}
20190508-10:23:06 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'27'}
20190508-10:23:07 execcommands L: 1= next cmd: "down"
20190508-10:23:07 execcommands L: 0= setGPIO pid=8933, command :{'startAtDateTime': u'1557307387.05', 'values': {}, 'pin': '27', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:07 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'22'}
20190508-10:23:07 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307386.89}}
20190508-10:23:07 execcommands L: 0= setGPIO pid=8935, command :{'startAtDateTime': u'1557307387.45', 'values': {}, 'pin': '22', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:07 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'23'}
20190508-10:23:07 execcommands L: 0= setGPIO pid=8937, command :{'startAtDateTime': u'1557307387.52', 'values': {}, 'pin': '23', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:07 execcommands L:-1= next command: {u'device': u'OUTPUTgpio-1', u'inverseGPIO': False, u'command': u'down', u'pin': u'24'}
20190508-10:23:07 execcommands L: 0= setGPIO pid=8939, command :{'startAtDateTime': u'1557307387.67', 'values': {}, 'pin': '24', 'debug': 3, 'inverseGPIO': False, 'cmd': u'down', 'devId': 0, 'PWM': 1}
20190508-10:23:07 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307387.19}}
20190508-10:23:08 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307387.59}}
20190508-10:23:08 execcommands L: 0= msg: 154x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307387.57}}
20190508-10:23:08 execcommands L: 0= msg: 153x-6-api_IN_4x-6-a{"outputs":{"OUTPUTgpio-1-ONoff":{"0":{"actualGpioValue":"low"}}},"program":"execcommands","ipAddress":"","pi":"4","ts":{"tz":"BST","time":1557307387.8}}
