Found I think a bug in BLE connect
Mon Jan 21, 2019 7:36 am
mpovolo offline
If you use the status up down for any actions, when my iPhone setup as BLE, if it leaves and is no longer connected, the software continually switches to on and off then on and off as it checks for status of the device. I would have expected continual checks to see if it is active but not to toggle the status to on while doing so and then flipping it back off.
thanks
Mon Jan 21, 2019 11:50 am
Re: Found I think a bug in BLE connect
Will check
So when eg switching the phone off
You see
Status going down up down ... several times while the phone is still off?
Mon Jan 21, 2019 12:31 pm
mpovolo offline
I haven’t turned off my phone but did try Bluetooth off. Status keeps cycling on and off.
Mon Jan 21, 2019 2:59 pm
yes its a bug.. fixing it
Mon Jan 21, 2019 3:09 pm
mpovolo offline
thank you
Mon Jan 21, 2019 7:31 pm
its ready, plugin store refuses my uploads right now.. did not pay my dues :? .. here the new version on GitHub https://github.com/kw123/pibeacon/releases/tag/v7.100.267
[edit]all on plugin store now
Tue Jan 22, 2019 10:26 am
mpovolo offline
Thank you
Tue Jan 22, 2019 11:16 am
my iPhone has been up now for > 18 hours w/o being charged. - also overnight.- exp timer set to 120 secs
using 10 RPI to test the BLEconnect presence of the phone.
Wed Jan 23, 2019 8:16 am
mpovolo offline
I tested and I think it’s better but still one minor thing. If you use a trigger that acts on any status change, the trigger keeps going when your phone is not connected. While the device status no longer toggles on and off, it seems to toggle a null state which triggers any action with status change. It would work if I set the trigger to be status on do some action. But if the condition is status change, it also continually runs over and over. So it seems when you disconnect completely the status doesnts stay off and only off until it finds you again.
Wed Jan 23, 2019 7:59 pm
the plugin only updates with up/down/expired. not NULL... Could you post the exact trigger you are using .. ie screen shots.
Wed Jan 23, 2019 9:15 pm
mpovolo offline
Ok so there is no Null. However I did conclude that during the period at which you set your BLE device to transition from Up to Down to expired, the status keeps flipping to On/active for a brief second while it checks if you are there. After that timer expires it leaves the device as expired and the trigger stops happening.
triger.tiff
triger.tiff (56.98 KiB) Viewed 2941 times
Wed Jan 23, 2019 9:32 pm
Ok I can check for this.
How many rpi do you have > 1 ?
This might be some timing issue when one rpi thinks it’s away and the other still thinks it’s there. There might be some few seconds where that can happen
Wed Jan 23, 2019 11:07 pm
I am adding a time window after the last status change of 2 secs where it can not change the status again. That should take care of it.. I still need to test this a little further.
Thu Jan 24, 2019 10:50 am
mpovolo offline
Thanks. Sorry for the delay. I now have 5 Pi's.
Fri Jan 25, 2019 4:04 pm
Will publish later tonight. Still locking at one issue.
