Can never seem to get WiFi to work with Pi?
Mon Dec 24, 2018 2:50 pm
mpovolo offline
I did the localization options, eventually got it working, connected again to the ref and power cycled, but when I disconnected from Ethernet and power cycled it still doesn’t connect. I just be doing something wrong. I even tried to ash directly to the pi and go through the wifi confit in Raspi-config and still nothing. Only connects on Ethernet. Any ideas?
Thx
Mon Dec 24, 2018 4:10 pm
Re: Can never seem to get WiFi to work with Pi?
You have to set the proper config files supplicant etc there are many web pages that can walk you through.
I use the graphical interface to do it.
... Its outside the pibeacon setup.
The only thing pibeacon does : if in rpi device edit you have set WiFi off it will switch WiFi off when Ethernet is present and working to avoid 2 active connections.
Mon Dec 24, 2018 4:56 pm
mpovolo offline
Oh. Duh. Lol
