Multiple rows per page in display regular monitor
Fri Nov 16, 2018 2:22 pm
Sam offline
I'm a new user of pibeacon and love the plugin so far. I have begun experimenting with the display function and wondering how to create multiple rows when viewed per page. I have just tested with a regular monitor via hdmi and would like to create a header and maybe the information from a variable from Indigo below. It is possible through the plugin?
/Sam
Fri Nov 16, 2018 3:37 pm
Re: Multiple rows per page in display regular monitor
Yes. Will send you my command for a clock and sensor info.
Fri Nov 16, 2018 3:55 pm
1. Create device pibeacon output display device , use that ID
2. put this into an action, replace the device ids etc with yours
if not plug.isEnabled(): return
plug.executeAction("Display" ,   props ={
   "outputDev":"1196962895" # <---put your  output device ID here
  ,"device":"OUTPUT-Display"
  ,"restoreAfterBoot":"False"
  ,"intensity":""
  ,"repeat":"9999999"
  ,"resetInitial":""
  ,"scrollxy":""
  ,"showDateTime":"0"
  ,"startAtDateTime":"0"
  ,"scrollPages":""
  ,"scrollDelay":""
  ,"scrollDelayBetweenPages":""
  ,"command":'['+
      '{"type":"rectangle", "position":[720, 0, 1280, 300],   "width":300, "fill":[0, 70, 0], "offONTime":[0, 999999999, 0], "display":"wait", "reset":[50, 50, 50]}'+
     ',{"type":"rectangle", "position":[720, 400, 1280, 700], "width":300, "fill":[70, 0, 0], "offONTime":[0, 999999999, 0], "display":"wait"}'+
     ',{"type":"text", "position":[730, 10],  "width":140, "fill":[0, 255, 0], "font":"Arial.ttf", "text":"%%d:1336842918:Temperature%%[ºF]",   "offONTime":[0, 2, 6], "display":"wait"}'+
     ',{"type":"text", "position":[730, 410], "width":140, "fill":[255, 0, 0], "font":"Arial.ttf", "text":"%%d:1062219179:Temperature%%[ºF]",   "offONTime":[0, 2, 6], "display":"wait"}'+
     ',{"type":"text", "position":[730, 10],  "width":140, "fill":[0, 255, 0], "font":"Arial.ttf", "text":"%%d:1336842918:Humidity%%[%H]",      "offONTime":[2, 2, 4], "display":"wait"}'+
     ',{"type":"text", "position":[730, 410], "width":140, "fill":[255, 0, 0], "font":"Arial.ttf", "text":"%%d:1062219179:Humidity%%[%H]",      "offONTime":[2, 2, 4], "display":"wait"}'+
     ',{"type":"text", "position":[730, 10],  "width":140, "fill":[0, 255, 0], "font":"Arial.ttf", "text":"%%d:864053974:illuminance%% ",       "offONTime":[4, 2, 2], "display":"wait"}'+
     ',{"type":"text", "position":[750, 200], "width":90,  "fill":[0, 255, 0], "font":"Arial.ttf", "text":"[Lux]",                              "offONTime":[4, 2, 2], "display":"wait"}'+
     ',{"type":"text", "position":[730, 410], "width":140, "fill":[255, 0, 0], "font":"Arial.ttf", "text":"%%d:1062219179:Pressure%%",          "offONTime":[4, 2, 2], "display":"wait"}'+
     ',{"type":"text", "position":[750, 595], "width":90,  "fill":[255, 0, 0], "font":"Arial.ttf", "text":"[mBar]",                             "offONTime":[4, 2, 2], "display":"wait"}'+
     ',{"type":"text", "position":[730, 10],  "width":130, "fill":[0, 255, 0], "font":"Arial.ttf", "text":"%%d:375541516:directionText%% at",   "offONTime":[6, 2, 0], "display":"wait"}'+
     ',{"type":"text", "position":[730, 150], "width":130, "fill":[0, 255, 0], "font":"Arial.ttf", "text":"%%d:375541516:avgSpeed%%[mph]",      "offONTime":[6, 2, 0], "display":"wait"}'+
     ',{"type":"text", "position":[730, 410], "width":100,  "fill":[255, 0, 0], "font":"Arial.ttf", "text":"AirQ:%%d:1062219179:AirQuality%%[%]", "offONTime":[6, 2, 0], "display":"wait"}'+
     ',{"type":"text", "position":[730, 595], "width":100,  "fill":[255, 0, 0], "font":"Arial.ttf", "text":"pm2.5: %%d:91799756:pm25_standard%%",   "offONTime":[6, 2, 0], "display":"wait"}'+
     ',{"type":"dateString", "position":[10, 700], "width":95, "fill":[255, 255, 255], "font":"Arial.ttf", "text":"%a, %b  %d, %Y", "offONTime":[0, 999999999, 0], "display":"wait"}'+
     ',{"type":"analogClock", "position":[355, 350], "width":64, "font":"Arial.ttf", "offONTime":[0, 999999999, 0], "display":"immediate", "box":{"on": "circle", "width": "30", "fill": [100, 100, 100]}, "mm":{"fill": [0, 255, 0]}, "ticks":{"fill": [150, 150, 150]}, "ss":{"fill": [0, 0, 255]}, "hh":{"fill": [255, 0, 22]}, "radius":[340, 340], "mode":"lineRound,,TicksNumbers"}]'
instead of "%%d:375541516:directionText%% ... you could use also %%v:variableID or names work to. and you can add text before or after the dev/state info : %%d:1336842918:Humidity%%[%H]", shows 55[%] if it is 55% ret humidity
All this can also be down in a menu or a regular indigo action .
this will show an analog clock on the left,
date at the bottom
and 2 blocks of sensor data on the right hand side, those will switch every 2 seconds ( "offONTime":[2, 2, 4], == 2 sec off, 2 sec on, 4 sec off)
Screen Shot 2018-11-16 at 15.58.27.png (132.42 KiB) Viewed 1637 times
Sat Nov 17, 2018 1:52 am
Sam offline
Very cool, just what I wanted to achieve.
Thanks for the help!
/Sam
